JBL 'M2' Master Reference Monitor - Page 139 - AVS Forum | Home Theater Discussions And Reviews
 2256Likes
post #4141 of 4705 Old 10-16-2018, 01:34 PM
Kain's Avatar
Quoted: 1932 Post(s)
Liked: 811
At least please tell me you have something very enjoyable to listen to currently... If you are system-less for this long while you are evaluating your choices, I feel bad for you. I'd go crazy.
I am not system-less. I currently have a quite enjoyable system (especially for movies but music performance could be better) that could blow my ear drums out if need be as the speakers are quite large for the room size they are in.
Right now I have the original (2001) Klipsch RF-7 mains, RC-7 center, RS-7 surrounds, and a single SubMersive.
Kain is offline
post #4142 of 4705 Old 11-11-2018, 07:23 AM
Quoted: 45 Post(s)
Liked: 2
I've gone through this forum quite a bit, but still confused about what makes this speaker special...
Could someone explain why this speaker is better or why you would pick this speaker over the Revel Ultima Studio/Salon's vs the JBL Everest vs the JBL 4367?
Or really any speaker from another manufacturer?
From what I've gathered is its phenomenal off axis response and even directivity across the freq. spectrum, which is what we predominantly hear in a room.
Presumably all of the Revel/Harmon/JBL speakers focus on this, so not sure why this speaker is so well regarded relative to the other JBL speakers.
rrahman is offline
post #4143 of 4705 Old 11-11-2018, 07:24 AM
thrang's Avatar
Quoted: 2506 Post(s)
Liked: 2028
Originally Posted by rrahman View Post
I've gone through this forum quite a bit, but still confused about why makes this speaker special...
It has a nice aroma...
JonasHansen likes this.
UPDATED 4/29/17 Thrang's Home Theater (for now...)
Sony VPL-VW5000es • Panamorph Paladin DCR • Trinnov Altitude 16 • Crown DCIn amplifiers • JBL M2 (LCR-LW-RW) • JBL S2S-EX subwoofers x2 • JBL SCL-4 (side/rear surrounds) • JBL SCS12 (x4) SCS8 (x2) TH/RH/TM • Lumagen Radiance Pro • Panasonic UB820 • Apple TV 4k • Synology RAID (45 TB total storage) • RTI control system
thrang is offline
post #4144 of 4705 Old 11-11-2018, 07:56 AM
Gooddoc's Avatar
Quoted: 3687 Post(s)
Liked: 3279
What makes the M2 special (IMO) is its combination of outstanding neutrality, active crossovers, and big clean SPL output capability. The other speakers you listed don't check all those boxes.
But they're all great speakers. The Salon2 and Everest are more expensive, with the Everest priced and targeted most of all to the big pocket audiophile. They're more about owner prestige than SQ IMO and I'm not sure the Everest is even a better speaker than the M2 despite its cost. The M2 has more clean SPL capability than the Salon2 if that matters to you, although the Salon2 likely has adequate clean output in most typical residential room sizes and likely edge out the M2 in listening preference for many. The M2 is active and requires specific electronics vs. the 4367 which is passive. Objectively, the M2 measures a little better than the 4367, but the 4367 has more limited vertical dispersion which some may prefer. I think these two speakers are likely VERY similar in SQ overall, although I haven't heard the 4367's.
It's a question of what's important to you.
Gooddoc is offline
post #4145 of 4705 Old 11-11-2018, 08:07 AM
jtwrace's Avatar
Quoted: 64 Post(s)
Liked: 65
I've heard the 4367 and purchased the M2's after hearing them. Personally, IMO, there is no comparison between the two. I now use the M2's with a BSS BLU 50 and (2) Hypex NC502MP amps. My Crown DCi 4 1250N is for sale for a steal and it's loaded with the M2 tuning files and I'm even including the interconnect cables and power cord with 15A plug ready to go.
Motorola Modem sb6141> Emo Systems EN-70HD > (5) eero > Synology 1813+ (DSM 6.2), 4TB Seagate NAS Drives, 4GB RAM & Zero Surge & APC XS BX1000G/backup to Synology DX513) > Emo Systems EN-60KDS  > Roon > Mola Mola Tambaqui > BSS BLU 50 > (2) Hypex NCore NC502MP > JBL M2 Master Reference
jtwrace is offline
post #4146 of 4705 Old 11-11-2018, 12:14 PM
Gooddoc's Avatar
Liked: 3279
I'm curious, what is the difference between them in your opinion?
Gooddoc is offline
post #4147 of 4705 Old 11-11-2018, 01:01 PM
jtwrace's Avatar
Quoted: 64 Post(s)
Liked: 65
Been a couple of years at this point. I clearly remember listening to the 4367's of a kind member here. Then when I went to Harman and heard the M2's there was no comparison of detail and dynamics. The Harman M2 room is far from ideal in many ways too. The M2 polar plots just tell the story. On top of that though, I've listened to the S2's several times and don't get the draw to them either so take it all with a grain of salt. I'm a huge fan of compression driver with a proper CD Waveguide.
jtwrace is offline
post #4148 of 4705 Old 11-11-2018, 03:11 PM
Quoted: 864 Post(s)
Liked: 1035
Few and far between.....
Rex Anderson is offline
post #4149 of 4705 Old 11-11-2018, 05:16 PM
Jsin_N's Avatar
Quoted: 442 Post(s)
Liked: 195
From the looks of it, someone with a ton of money bought most of these speakers you listed plus SCL-3's, auditioned them all, and stayed with the Everest and sold/is selling everything else.
There must be something to the Everest after all?
Jsin_N is offline
post #4150 of 4705 Old 11-11-2018, 05:37 PM
Gooddoc's Avatar
Liked: 3279
Maybe. I would like to see Everest spins, but I don't think that is ever going to happen. Measurements don't matter to potential Everest clientele.
Gooddoc is offline
post #4151 of 4705 Old 11-16-2018, 06:09 AM
jtwrace's Avatar
Quoted: 64 Post(s)
Liked: 65
For sure, I've had GedLee Abbeys, JBL M2 and JBL 708P so I'd say I've had them.
jtwrace is offline
post #4152 of 4705 Old 11-16-2018, 06:17 AM
JonasHansen's Avatar
Quoted: 291 Post(s)
Liked: 134
Do you experience any audible difference (except for the fan-noise ) between the DCi and the Hypex amp?
Home Theater: JBL M2 & SUB18 powered by Crown and BSS.
JonasHansen is online now
post #4153 of 4705 Old 11-16-2018, 06:25 AM
jtwrace's Avatar
Quoted: 64 Post(s)
Liked: 65
My subjective side says yes, the engineer in me says that I wouldn't be able to pick out the Hypex in a blind test.
jtwrace is offline
post #4154 of 4705 Old 11-16-2018, 06:26 AM
Quoted: 291 Post(s)
Liked: 134
Haha, I'm an engineer myself but the audiophile devil in me tries to make me buy another amp
What differences do you subjectively hear between the two?
post #4155 of 4705 Old 11-16-2018, 06:33 AM
jtwrace's Avatar
Quoted: 64 Post(s)
Liked: 65
If you want to buy another Crown, see mine.
You asked! As for subjective comparison, I do feel the Hypex is actually "warmer" with more micro detail. It's IMO a better presentation with a much lower noise floor. I couldn't be happier with this combo. I run the dac direct to the BSS which of course goes to the amps.
jtwrace is offline
post #4156 of 4705 Old 11-16-2018, 06:44 AM
Quoted: 291 Post(s)
Liked: 134
Noise floor is easily measurable though - so that could make the engineer in me happy.
Are you going analog into the BSS and using it's internal AD/DA? I did read somewhere that the A/D part is the weak link in the BSS but I don't know if this is audiophile rumours or not. I got a DBX TR1616 cheap which then does the A/D to D/A in my system digitally connected to the BSS to do M2 crossover. Specs are better but don't know if it's audible or not.
post #4157 of 4705 Old 11-16-2018, 06:50 AM
jtwrace's Avatar
Quoted: 64 Post(s)
Liked: 65
Take a look at the Hypex NC502MP and the Crown DCi 4 1250 specs and let me know.
Yes, analog into the BSS BLU 50 and use its internal conversion. If I were to do anything I'd use Audiolense but I'll only use that for subwoofer integration and load the convolution filter into Roon. The M2's sound just fine to me using the BSS and quite frankly I enjoy pressing play and listening and less tinkering.
jtwrace is offline
post #4158 of 4705 Old 11-17-2018, 09:31 AM
Liked: 0
Is the signal path in dci analog series pure analog?
Got a nice price on 2x DCi 4/1250
Going to use it with bss Blu 160 analog in/out and 3xJbl M2.
Little worried that I made the wrong choice and not got the N version and used Blu link from my Blu 160....
Skickat från min LON-L29 via Tapatalk
beatelund6 is offline
post #4159 of 4705 Old 11-17-2018, 09:42 AM
adidino's Avatar
Quoted: 507 Post(s)
Liked: 354
You'll be fine. Of course it's better to remain in the digital domain as as much as possible which is the advantage of a DSP amp like the DCI-N but it's not uncommon to use the BSS Blu especially for clients that want to keep their own amps. JBL had a demo a couple of years ago showing the M2 with Mark Levinson amps + BSS Blu. Sounded great.
AudioXtream
Authorized Dealer:
Trinnov, Anthem, SVS, Triad, Genelec,
Revel, JBL Synthesis/JBL Pro, Paradigm, Kaleidescape, PS Audio, JVC,
Panamorph, LG
adidino is offline
post #4160 of 4705 Old 11-19-2018, 04:09 AM
Liked: 0
Hope you're right!!
Somebody know if it is possible to use Audio Architect instead of London Architect (LA) with M2 and Bss dsp?
The M2 files on jbl website only support LA.
I want to use the new program to control it with my Ipad
post #4161 of 4705 Old 11-19-2018, 05:23 AM
Quoted: 291 Post(s)
Liked: 134
Not possible audio Architect does not support macros.
Sent from my SM-G960F using Tapatalk
post #4162 of 4705 Old 11-19-2018, 06:34 AM
Liked: 0
Ok. Have you spoken to Jbl about it?
It cannot be just us who want that to work.
LA is a bit old these days and M2 are still for sale. So I think support for AA should be provided by JBL
post #4163 of 4705 Old 11-19-2018, 12:17 PM
Liked: 1
I`m using BSS Blu-USB as a source its a New toy from BSS
It has USB input and with BLU Link goes DA to Bss blu-50, so no need for DA-AD,
It`s cheap and can be used as BLU Link source to N versions of Crown Dci amps
It works better than any other way I tried
agronk is offline
post #4164 of 4705 Old 11-19-2018, 03:01 PM
ganduy's Avatar
Quoted: 41 Post(s)
Liked: 48
My stereo setup consists of M2, one JBL Sub 18, and three Crown ITech 5000. I wish to expand this into a multi channel arrangement to take advantage of my sizable collection of 5 channel SACD. I am mainly interested in getting more musical involvement from two additional real channels and don’t see a need for a center channel since movie watching will not be involved, only music. I also would not access the discrete sub channel. I would plan to use a 7 channel Parasound pre amp driving the 3 Crowns of my current setup, but also driving 2 JBL 708P for the rear channels. Does this make any sense?
ganduy is offline
post #4165 of 4705 Old 11-19-2018, 05:38 PM
torii's Avatar
Quoted: 3322 Post(s)
Liked: 1875
does the M2 have a mini desktop version?
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #4166 of 4705 Old 11-19-2018, 05:54 PM
m. zillch's Avatar
Quoted: 4671 Post(s)
Liked: 3470
Sort of. My desktop speakers: LSR 305
"Image Control Waveguide:
• The Image Control Waveguide was developed for JBL’s new flagship M2 Master Reference Monitor and
with the introduction of the JBL 3 Series, is now included for the first time in an affordable, compact
reference monitor. "
= JBL
Psst: For black Friday it may be as little as $100/ea.. There's also a mk 2 version.
torii likes this.
m. zillch is offline
post #4167 of 4705 Old 11-19-2018, 08:38 PM
Quoted: 1191 Post(s)
Liked: 662
Yes.
http://www.jblpro.com/www/products/r...i#.W_OPrRZOnDs
torii likes this.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #4168 of 4705 Old 11-21-2018, 11:51 AM
Roger Dressler's Avatar
Quoted: 2926 Post(s)
Liked: 1681
Good idea. Multichannel hi-res music recordings are often quite rewarding. You will be fine without a center speaker.
Do you currently use the Sub 18 with the M2s in a bass managed setup? Or how?
I do not understand this. The LFE channel is sometimes important in 5.1 music recordings (but yes, sometimes it is not used at all). I just see no point in discarding it. What's the reason?
The 708's ought to work swell, especially if well matched (EQ-wise) with the M2s.
The Parasound ought to handle the downmixing to phantom center nicely for you, as well as the bass management, whether you configure the system with or without a subwoofer, and whether you configure all speakers as large or not. Of course all this assumes feeding the Parasound with a digital signal. If that's not your plan, these duties will shift to the SACD player (Oppo??).
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win7 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is offline
post #4169 of 4705 Old 11-22-2018, 05:19 AM
Quoted: 864 Post(s)
Liked: 1035
Originally Posted by DS-21 View Post
Also available in a powered version as the LSR 705P. And, if you want something bigger (8" woofer instead of 5") look at the LSR 708i or LSR 708P.
post #4170 of 4705 Old 11-22-2018, 10:46 AM
green giant's Avatar
Quoted: 114 Post(s)
Liked: 112
Blu
Has anyone put together a quick "how-to" with the various Blu offerings?
Does JBL use a separate DSP programing etc to set them up?
green giant is offline
Reply Speakers
