JBL 'M2' Master Reference Monitor - Page 148 - AVS Forum | Home Theater Discussions And Reviews
 2188Likes
post #4411 of 4623 Old 01-09-2019, 12:18 PM
12B4A's Avatar
Quoted: 592 Post(s)
Liked: 512
Originally Posted by Gooddoc View Post
No. I don't want to give up the flat panel display. But LG just announced a rollable OLED that will solve my problem I think. Hopefully price is not stratospheric. So maybe, just maybe, a M2 center is in the near future for me.
Is it really rollable or does it just disappear in to a box?
Life is Lambertian
12B4A is online now
post #4412 of 4623 Old 01-09-2019, 02:21 PM
Gooddoc's Avatar
Quoted: 3650 Post(s)
Liked: 3241
Originally Posted by Blackdevil77 View Post
Hopefully one is in my future as well. Probably not a near as you, I have an entire theater room to build from scratch. Moved into the new House in November (finally). This past Friday, the hot water heater went and flooded the basement and of course, it was entombed in a small room that made it a huge job to get out and even harder to get the new one in. Already dealing with these set backs
That sucks! Home ownership is for the birds .
Gooddoc is offline
post #4413 of 4623 Old 01-09-2019, 02:25 PM
Gooddoc's Avatar
Liked: 3241
Haha! Yeah, that thread was a hoot...
Gooddoc is offline
post #4414 of 4623 Old 01-09-2019, 06:49 PM
Blackdevil77's Avatar
Quoted: 477 Post(s)
Liked: 226
It can be a real pain, that's for sure
Blackdevil77 is offline
post #4415 of 4623 Old 01-10-2019, 05:05 PM
jtwrace's Avatar
Quoted: 64 Post(s)
Liked: 65
I'd buy one in a NY minute but sure it will be crazy expensive as the article suggests.
https://www.cnet.com/news/lgs-rollab...e-in-2019-ces/
Gooddoc likes this.
jtwrace is offline
post #4416 of 4623 Old 01-13-2019, 04:57 AM
JonasHansen's Avatar
Quoted: 290 Post(s)
Liked: 132
When using the JBL M2 in a Synthesis system (SDEC + SDA-amps) does anyone know where the presets are applied? In the SDEC (I.e. BSS box) or the SDA-amps (Crown DCi amp)?
This might be a question for John/Rex - I'm not sure how I can tag people.
Home Theater: JBL M2 & SUB18 powered by Crown and BSS.
JonasHansen is offline
post #4417 of 4623 Old 01-13-2019, 06:48 AM
Molon_Labe's Avatar
Quoted: 3072 Post(s)
Liked: 3701
Use the @ followed by their username with no space.
@Rex Anderson
JonasHansen likes this.
Molon_Labe is online now
post #4418 of 4623 Old 01-13-2019, 07:51 AM
Quoted: 839 Post(s)
Liked: 986
Use this link and open the pdf "JBL M2 setup instructions".
https://www.google.com/search?client...iz.zCovC9w3xPQ
There are different ways to get the job done depending on your configuration. Having an SDEC requires Harman calibrators to visit you home. If you have an SDP-75, you can do the files there. You can have them in the amps or in a BSS box.
Rex Anderson is online now
post #4419 of 4623 Old 01-13-2019, 11:05 AM
Quoted: 290 Post(s)
Liked: 132
Thanks. It makes sense that there are multiple options- hence my question
When using ARCOS in a Synthesis system with an SDEC and SDA amps, what Will ARCOS do when M2 and SDA amps are selected when configuring? Will the presets be done set in the SDEC (as if you are using JBL SAM1/2 bi-amped)? And are these presets the exact same as the ones which can be downloaded for the BSS unit in jblpro.com?
Or is it up to the Harman calibrator if the M2 presets should be setup in the SDEC or the SDA amps?
I hope my question makes sense. What I am curious about is if there are different voiced presets for M2 depending on which hardware the presets are loaded to and which 'use case' (Synthesis Vs. Studio) is being used.
Sent from my SM-G960F using Tapatalk
post #4420 of 4623 Old 01-13-2019, 01:37 PM
Quoted: 839 Post(s)
Liked: 986
ARCOS is for JBL calibrators only and is for Room Correction. If you have an SDEC, JBL calibrators will come to your home and calibrate your system. The M2 files are the same no matter what your system consists of. They are based on anechoic data and are just dialing in the crossovers and processing to make the M2 work as designed. Room correction is done after that by whatever you want to use (ARCOS, DIRAC, etc).
https://jblsynthesis.com/syn-arcos.html
http://www.jblpro.com/china/products...em-integration
Watch the tutorial videos in this link: https://www.jblsynthesis.com/product...sdec-3000.html
The first one is a little glitchy, I had to hit play a few times to get it to play.
I am by no means an expert on the M2/ARCOS/SDEC etc. Folks on this thread will be able to advise you better than I can. Sorry, I'm in the process of learning a lot of things and this is one of them.
post #4421 of 4623 Old 01-19-2019, 07:39 AM
pennynike1's Avatar
Quoted: 589 Post(s)
Liked: 531
I have been researching the JBL speakers to utilize with M2's, and the 708p's seem like they are at a decent price point. The JBL Synthesis SCL-3's and SCL's would likely be the most ideal for my system since they are in-walls, and then I found the SCL-2. The SCL-2 seems like quite the speaker, but it has the same price point as the M2's themselves.
Anyone utilizing SCL-2's in their system?
Anyone know of a dealer(s) that sells the JBL Synthesis line of speakers for some quotes?
Thanks all!
For sale: 2 Mackie c200 speakers, 4 Mackie c300z speakers, Sony HW40es projector, Tag Mclaren av32r preamplifier
pennynike1 is offline
post #4422 of 4623 Old 01-19-2019, 07:54 AM
Molon_Labe's Avatar
Liked: 3701
@Rex Anderson
@adidino
Both these guys are top notch and competitive. I have purchased from both and wouldn't hesitate to do it again.
pennynike1 likes this.
post #4423 of 4623 Old 01-19-2019, 07:58 AM
COACH2369's Avatar
Quoted: 1166 Post(s)
Liked: 984
Thanks all!
I have been told by a couple folks, Synthesis dealers, that the SCL-2 can compete with the M2's and 4367's when they are setup correctly. The price point also seems to support that. Apparently they are a great LCR option.
Gooddoc and pennynike1 like this.
COACH2369 is offline
post #4424 of 4623 Old 01-19-2019, 08:10 AM
pennynike1's Avatar
Quoted: 589 Post(s)
Liked: 531
SCL-2's
Thanks! Utilizing the SCL2's as mains hadn't previously occurred to me, but that it is something that I would very much like to test out.
post #4425 of 4623 Old 01-19-2019, 08:44 AM
mmiles's Avatar
Quoted: 801 Post(s)
Liked: 411
@COACH2369 glad to see you posting. Thought you left the country.
Mike Miles
[email protected]
mmiles is offline
post #4426 of 4623 Old 01-19-2019, 11:12 AM
COACH2369's Avatar
Liked: 984
Who said I didn't....
post #4427 of 4623 Old 01-20-2019, 05:06 PM
Snowmanick's Avatar
Quoted: 455 Post(s)
Liked: 630
I use SCL-2’s as mains with SCL-4’a for center, surrounds, and surround backs. They create a very good sound field and are great with music as well. Powering the SCL-2’s with an ATI AT542NC.
COACH2369 and pennynike1 like this.
Snowmanick is offline
post #4428 of 4623 Old 01-21-2019, 07:33 AM
Snowmanick's Avatar
Quoted: 455 Post(s)
Liked: 630
Originally Posted by Molon_Labe View Post
Just curious, why did you not go matching across the front? How are you liking the in-walls?
I have a dual screen setup. The -2 would have been too tall to use vertically and in wall plumbing ruled out using it horizontally.
Fitero likes this.
post #4429 of 4623 Old 01-26-2019, 07:53 AM
javierschmidt's Avatar
Liked: 27
Hi:
Hopefully somebody can help me with this.
I currently run my JBL M2 with Itech 5000 HD and wanted to change to DCI 4/1250N.
Using audioarchitect I have no issue with the Itechs (I open the program and seconds later it is already "discovered"). That does not happen with the DCI, I use the other program, net setter, and discovers the DCI but remains on a loop "discovering". The main difference that I see is that with the Itech it appears with with a default gateway but with the DCI remains 0.0.0
Anybody knows how to solve this issue? I am assuming that has something to do with manual input of a new adress, but which one?
SOLVED. A HARD FACTORY RESET AND SOLVED
JS
javierschmidt is offline
post #4430 of 4623 Old 01-28-2019, 07:45 AM
Quoted: 290 Post(s)
Liked: 132
Originally Posted by javierschmidt View Post
Hi:
JS
Glad to hear that you fixed the problem. I'm very interested in hearing about how you perceive the differences between the two amplifiers (i.e. how M2 sounds).
post #4431 of 4623 Old 01-28-2019, 07:51 PM
Liked: 27
Hi
Tha main difference might be SPL. It was very obvious when I switched from one amp to the other.
Regarding quality. Maybe, but only maybe I sensed some differences. My wife said that it was the same and she is always right....
One of the best things is the fan noise. There is a huge difference, not ideal, but the DCI is much quieter.
pennynike1 and JonasHansen like this.
post #4432 of 4623 Old 01-30-2019, 11:37 AM
thebland's Avatar
Quoted: 2178 Post(s)
Liked: 1383
ANYONE USING DCi 2/1250 amps with their M2s? Debating between a 2/1250 stereo amp for each M2 or a 4/600 (SDA 4600) bridged for each speaker. Any issues with hiss for either?
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is online now
post #4433 of 4623 Old 01-30-2019, 12:48 PM
Kain's Avatar
Quoted: 1931 Post(s)
Liked: 807
Originally Posted by forin View Post
Yesterday was bittersweet to say the least. My Pair if M2s arrived and then immediately went into storage for a few weeks. Wish I could have played with them but no such luck. Oh well, Guess I’ll have to wait a little longer
Hey,
Any updates? Were you able to try out the M2s? If yes, any thoughts on how they compare to your 708Ps?
Kain is offline
post #4434 of 4623 Old 01-30-2019, 12:51 PM
Kain's Avatar
Liked: 807
@notnyt
Would 22" of space between M2s as LCR be too little? Would it cause any issues? Just to be clear, I mean this: M2 <--22"--> M2 <--22"--> M2.
Kain is offline
post #4435 of 4623 Old 01-30-2019, 02:16 PM
Jsin_N's Avatar
Quoted: 442 Post(s)
Liked: 192
It seems like someone said something about bridging amps decreases the damping factor or has a detrimental affect on noise. Can't remember.
Jsin_N is offline
post #4436 of 4623 Old 01-30-2019, 02:21 PM
notnyt's Avatar
Quoted: 3725 Post(s)
Liked: 3691
Originally Posted by Kain View Post
@notnyt
It'd be pretty much the same with any speaker. It's a narrow stage.
notnyt is offline
post #4437 of 4623 Old 01-30-2019, 02:57 PM
Quoted: 839 Post(s)
Liked: 986
Here are some comments from John after spending time today calibrating, balancing and adjusting phase on the subs in his system. He used Dirac EQ and a mini-DSP to tweak them all from one output blended as mono.
"HOLY S***!!! Just recalibrated my theater using a MiniDSP to properly balance and phase align the subs. Bass is incredibly deep and tight - much more than any previous calibration I've done here. WOW! And I still haven't done SFM yet. The SCL2s sound freaking fantastic! The dynamics are off the charts and have a much more open sound compared to 708s and M2s. Seriously - anyone looking at M2s should really consider the SCL2s instead. Just huge and spacious sounding. With the new acoustic treatments in here they sound even more open and wide."
Can you tell he's excited?
post #4438 of 4623 Old 01-30-2019, 02:58 PM
DonH50's Avatar
Quoted: 3103 Post(s)
Liked: 3047
Bridging an amplifier ideally quadruples the power output, doubles the output impedance (so halves the damping factor), and improves SNR by 3 dB. If bridging results in so much output/gain that you need to turn down the input levels you could get higher hiss (and potentially won't be using all of the output). You also need to make sure all the common (-) terminals are floating and not tied together to a common ground or you may blow the output of the bridged amplifier (not usually an issue but just in case). Both outputs of a bridged amplifier are usually floating.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #4439 of 4623 Old 01-30-2019, 11:39 PM
Quoted: 290 Post(s)
Liked: 132
Personally I would always go for non-bridged to put the least stress possible on the amplifier. As I recall the 15" on the M2 is 6 ohms and the bridged amp will see this as 3 ohms. Not an easy load.
post #4440 of 4623 Old 01-31-2019, 09:41 AM
thebland's Avatar
Liked: 1383
All good information. Thanks!
Hiss is my biggest concern here. Both amp options will drive the speakers.
Anyone notice inordinate hiss with their M2s?
Reply Speakers
