JBL 'M2' Master Reference Monitor - Page 159 - AVS Forum | Home Theater Discussions And Reviews
 2389Likes
post #4741 of 4910 Old 08-05-2019, 10:09 AM
Gooddoc's Avatar
Quoted: 3772 Post(s)
Liked: 3380
Originally Posted by Jon AA View Post
On the broader question of "screwing things up" by correcting full range, I see very good arguments both ways, but with a really good speaker with well controlled--nearly constant--directivity, I worry much less about it. Since the reflected sound is so similar to the direct sound, the software won't try and correct a speaker directivity issue, screwing up the direct sound in the process, because the speaker doesn't have any directivity issues the software might measure as a problem and mis-diagnose. As long as it doesn't try to correct every narrow dip or bump (as XT32 doesn't seem to, I can't speak to others) the broad changes to the target curve will act more like a tone control of sorts. Of course an inappropriate curve could sure mess things up, just as you could if you went nuts with a set of tone control knobs.
Agreed. The ability to discriminate SQ issues decreases with increasing channel count and although I find RC detrimental if I'm critically listening in 2 channel(depending on the RC brand), the latest versions are so good that it takes some seriously critical listening to hear the problems - even in 2 channel. With the increased channel counts of HT, I believe the benefits can often outweigh any of the negatives.
Just like distortion and resonances, they only matter if you can hear them.
Gooddoc is offline
post #4742 of 4910 Old 08-05-2019, 10:15 AM
Gooddoc's Avatar
Liked: 3380
Originally Posted by JonasHansen View Post
Why compromise in a theater? EQ the LCR for highest sound quality and EQ the surrounds speakers full range and make sure they timbre match the fronts. This will probably require some broad and gentle filters in the high frequencies.
Sent from my SM-G960F using Tapatalk
As I replied above, it's not about compromise. It's whether or not you can actually hear the issues introduced by RC with 11+ channels in the mix. As was mentioned above, I have found that with a speaker like the M2 minimal correction is done with the RC systems. It's only noticeable with critical two channel listening in my experience.
Of course every person's individual room characteristics, speaker types, RC brand, and ears will be a factor. This is necessarily a discussion of generalities, there will always be exceptions.
Gooddoc is offline
post #4743 of 4910 Old 08-05-2019, 10:36 AM
m. zillch's Avatar
Quoted: 5332 Post(s)
Liked: 3846
By writing the post above, you are assuming that Auto EQ systems always do the right thing?
FYI, I do agree that it can be beneficial to add EQ above Shroeder but it should be done with care. EQ'ing fullrange to match a target curve, which many AutoEQ systems do, is not doing it with care.
Modern versions of Audyssey have an option to let you set the target curve yourself if you download their app. I realize not all correction systems do though, true.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #4744 of 4910 Old 08-05-2019, 01:11 PM
Balbolito's Avatar
Quoted: 186 Post(s)
Liked: 252
Originally Posted by m. zillch View Post
If it is true that no EQ above Shroeder is necessary then an auto room correct system won't apply any. Does having it examine those frequencies muck them up? NO.
That's my take and I realize I'm in the minority.
Yup you are right just downloaded it for my phone (android) and will try it out for sure once i set up everything in my HT. it's only 20$
m. zillch likes this.
Processor Marantz AV8805 Amps Crown DCI/N x2 CT8150 x1 Speakers JBL PRO M2 x3 708i x4 328c x6 Subs SVS SB16 x2 Screen SI 160 Slate AT 1.2 Projector Epson TW5600 Media Steiger Dynamics Ikon Cables&Chords Wireworld & Belden
Balbolito is online now
post #4745 of 4910 Old 08-06-2019, 10:04 AM
beastaudio's Avatar
Quoted: 5621 Post(s)
Liked: 5458
If the front stage is done right, with proper room treatment throughout, which I imagine you have done, then REQ software won't have to make but very small changes above schroeder when you start with a quality speaker such as we are discussing. Enter dirac/trinnov who both not only let you create your own target curve, but can allow you limit the amount of actual full range correction can be done to x dB or whatever. I found after some trial and error that only make small adjustments no more than 3dB, and shaping the target curve to be very close to the native curve of my front stage, which was very good to begin with, full range EQ works both for 2 channel critical listening as well as HT multichannel listening.
I do still agree wholeheartedly with this and that MOST REQ doesn't go about things in the right way. Seems Dirac, Trinnov, and even the new ARC genesis are in fact going about things properly. I know audyssey has the app now to help with limiting and target curve manipulation, but I still didn't like the results when I had it on my old 7705
Gooddoc and philipbtz like this.
beastaudio is offline
post #4746 of 4910 Old 08-09-2019, 09:52 PM
luvthefloyd's Avatar
Quoted: 14 Post(s)
I think i've gotten the M2 bug. Reading reviews and specs it sounds like a spectacular speaker without the "audiophile" price. I have some questions but admit I haven't read the entire thread.
I'm transitioning from 5.1 HT to 2.1 with music being the focus. That said I'd still like to use the speakers for tv/movies. It seems like most M2 users on this thread are focused on HT. Are there any users with a similar thesis to mine? Can you speak to the quality of the speaker for primarily music?
Im planning on the Crown/outboard processing route. Is BSS the only option? How difficult is setup going to be for someone who is tech savvy but inexperienced with this kind of equipment/software?
In planning on a new 2 channel audio pre. How difficult will it be to feed audio from Apple tv, and blu-ray back into the system? Will the audio quality be diminished since I'm not using a HT pre?
Can the BSS be connected to a consumer preamp?
Im doing a large remodel on my house soon. Would placing the M2's inside cabinetry (transparent cloth fronts) have a bad effect on the sound? I know its always preferable to float the speakers into the room but in this case its just not possible.
Thanks all.
By Grabthar's hammer.......... What a savings.
luvthefloyd is offline
post #4747 of 4910 Old 08-10-2019, 12:19 PM
Quoted: 1047 Post(s)
Liked: 1243
The M2 was developed with music in mind and is used by professional recording, mixing and mastering engineers. It is a professional full range monitor that many consider to be one of the finest. It is an excellent speaker for music and Home Theater.
Why do you want to use 2.1 for music if you still want to be able to do TV/movies? Phantom center is not ideal. You will be missing the center channel and surrounds. I was stuck with 3.0 for a long time and am finally able to have 5.2 again. I really missed having surrounds and could not imagine not having a center channel for TV/movies. Dr. Toole says not using a center actually diminishes dialogue clarity. The most prominent thing in TV and film mixes is dialog. I listen to music in both stereo and surround and enjoy surround for TV/movies. You say "2.1". Most HT designers recommend at least two subs these days; it helps smooth out bass response in the room. Have you read Dr. Toole's book or the information on the companion website? https://routledgetextbooks.com/textbooks/9781138921368/
You can control M2's with some Crown amps or use a BSS and any amps. You need one or the other because the M2 anechoic data is in them. Most Crown/JBL Synthesis amps for the M2 have noisy fans. People choose to use the BSS if they don't have an equipment room for the amp. If you have to locate the amp in a remote location, you have long speaker cable runs.
Your sources (Apple TV and Blu-ray) feed the preamp so you need to consider how that will be accomplished (are there HDMI inputs on the preamp?). The output of the preamp feeds the BSS that feeds the amps. M2's are passive and require active bi-amping, BSS or amps control processing and crossover functions. Two channels of amp are required for each speaker (woofer and compression driver). Placing M2's in a cabinet is not ideal. You might consider using SCL-2's (designed to be in wall speakers). M2s were engineered to be used in 2 pi or 4 pi space, where the SCL2 was designed to be used in a wall. They have crossovers built in and would make your setup much easier by eliminating the need for the BSS processor/crossover and four channels of power amp vs. two. https://trueaudio.com/st_spcs1.htm
Not sure why you are building things into a cabinet. They are not ideal for audio reproduction and can limit your ability to grow/expand. I have a friend who did one a few years ago. He wanted to get a bigger center channel recently but can't. What if you want a bigger TV down the line? How big is the cabinet and what size TV will it accommodate? Could you elaborate on or show drawings/pictures of your "cabinet"? An empty box cabinet is a nightmare for sound.
Have you considered Revel vs the M2 and have you seen the thread that compares them?
https://www.avsforum.com/forum/89-sp...l#post54632024
John Schuermann says, after many hours comparing SCLs to M2s to Revels he finds the SCL / M2 speakers have more prominent direct sound and sound “drier” than the Revels. Revels sound silkier, smoother on the top end vs. the JBLs. The SCL2s sound more spacious than the M2s, likely due to the waveguide design. He likes how close mic’d brass and percussion sound with the JBLs, but prefers everything else on the Salon2s. The SCL2s sound more spacious and open than the M2s, but aren’t full range down to 20 Hz, which is not and issue if you are using subs. The second most prominent thing after dialogue in any film mix is music.
FWIW, setting up M2s is complex and may be beyond what you want to deal with.
Rex Anderson is offline
post #4748 of 4910 Old 08-10-2019, 12:30 PM
Floyd Toole's Avatar
Quoted: 875 Post(s)
Liked: 3076
Thanks all.
A personal comment. The M2 is indeed one of the great loudspeakers of this time - it is on the cover of the 3rd edition of my book, after all. It performs superbly in stereo or multichannel systems.
However, for the life of me I don't know why in 2019 you are regressing to two channels, when there is an ever increasing supply of excellent multichannel music, video concerts and movies. Most music is delivered in stereo format - unfortunately - but adding tasteful upmixing in 5.1, 7.1 or immersive systems is, in my experience, a significant improvement on raw stereo. It varies from recording to recording, of course. Currently I find Auro-3D upmixing to be highly rewarding, and it allows for subtle adjustments.
Having two M2s up front is an excellent start. Add comparably good center and surround loudspeakers and your quality of listening will be improved. However, don't skimp on the surround speakers - they need to be similarly good, but much smaller. Fortunately there are choices.
A large screen video presentation of a well-recorded multichannel concert is high entertainment. And then there are movies.
I personally don't have M2s, only because of a visual preference for Revel Salon2s in my installation. They are comparably good sounding. This is my system:
https://www.dropbox.com/s/gg5wnct601...02018.pdf?dl=0
Whatever you end up doing, a pair of M2s would make a good entry point
EDIT: I see that Rex Anderson responded as I was composing. His thoughts are on target.
Floyd Toole is offline
post #4749 of 4910 Old 08-10-2019, 12:41 PM
m. zillch's Avatar
Liked: 3846
The common notion, often pushed by marketers and the audio magazines which they advertise in, that "optimal 2ch. audio speakers and home theater speakers are different animals" is complete bull pucky. What makes for a state-of-the-art, front, left speaker for music is exactly the same as what one wants for an optimal, front, left speaker for movies. Same goes for the right speaker, obviously, and the M2s fit the bill.
[Psst, those drivers in the cabinets, and the electrons in the speaker wire? Heck, they don't even know if there is a video display showing moving images concurrently to what they're doing, so how could they perform "differently"? ]
DS-21, philipbtz and patheticloser like this.
post #4750 of 4910 Old 08-10-2019, 12:46 PM
Roger Dressler's Avatar
Quoted: 2973 Post(s)
Liked: 1733
Originally Posted by Balbolito View Post
Any advice for a relay? maybe a link or a name that i could look up.
as in my previous setup it was way easier, 3 emotivas connected with an emotiva trigger device then just a cable to my processor.
I use this device which has a separate circuit to drive the relay coils, so it's very little load for the 12V trigger. Amazon reports it is not in stock, but it may give you some ideas.
Link to AVS post
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win10 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is offline
post #4751 of 4910 Old 08-10-2019, 03:48 PM
Balbolito's Avatar
Quoted: 186 Post(s)
Liked: 252
Link to AVS post
Thank you Roger, appreciate it.
I wouldn't know how to use the relay with it honestly lol.
Is there a turn key solution or something more plug and play? this is a bit confusing to me as i never tried it honestly. even never bought a relay.
post #4752 of 4910 Old 08-10-2019, 09:36 PM
Liked: 1733
The unit I referred is indeed plug and play.
You connect the 12V output of the processor to the green terminals of the unit. Yes, that requires stripping the 2-conductor cable and attaching the connector with a small screwdriver. Then plug the AC cables from the power amps to one or two of the "active on" switched outlets (can use an outlet strip to derive as many outputs as you need).
You can ignore the third outlet as it is is wired as "active off" which simply means it provides power when the other two are off. Can use it to extinguish a room light when the system is turned off, for example.
To you "relay savvy" folks, there is a SPDT relay in the box, and the NO terminal feeds two outlets, and the NC terminal feeds one.
post #4753 of 4910 Old 08-10-2019, 11:16 PM
JonasHansen's Avatar
Quoted: 326 Post(s)
Liked: 142
There is a third M2-configuration option which is often forgotten. Apart from the Crown amps and BSS Soundwebs, one can use the JBL Intonato: https://www.jblpro.com/www/products/...rs/intonato-24
Disclaimer: I have not used it so cannot comment on the end-result. Looking at the manual it looks to be simpler than a BSS Soundweb solution.
Frohlich and Molon_Labe like this.
Home Theater: JBL M2 & SUB18 powered by Crown and BSS.
JonasHansen is online now
post #4754 of 4910 Old 08-11-2019, 06:42 AM
Balbolito's Avatar
Quoted: 186 Post(s)
Liked: 252
Got it thanks! looks fairly easy to use.
But it's sold out, would you know where i could possibly find them?
Regards
post #4755 of 4910 Old 08-12-2019, 01:47 PM
Liked: 1733
I went to the chat area of their website, and they report it will be available again in about 2 weeks.
post #4756 of 4910 Old 08-12-2019, 04:21 PM
Balbolito's Avatar
Quoted: 186 Post(s)
Liked: 252
Thanks! appreciate it
post #4757 of 4910 Old 08-26-2019, 08:09 AM
Dartw's Avatar
Is the M2 Discontinued from Harman?
I got a reply from a Scandinavian dealer today that it is not longer possible to order the M2 from Harman!
Is this correct???!!
Is the model discontinued?
Does this mean that there is a M2 mkII or an M1 ready to launch?
If not it seams like a big loss for both HT and pro audio...
Dartw is offline
post #4758 of 4910 Old 08-26-2019, 12:27 PM
Liked: 1243
Originally Posted by Dartw View Post
I got a reply from a Scandinavian dealer today that it is not longer possible to order the M2 from Harman! Is this correct???!! Is the model discontinued? Does this mean that there is a M2 mkII or an M1 ready to launch? If not it seams like a big loss for both HT and pro audio...
Just spoke with our rep about this. He has not heard anything. We addressed this not too long ago. Not sure what is going on but I'll keep digging.
Update: They are still current but might be back ordered. This is info from Harman, they are not discontinued.
JonasHansen likes this.
post #4759 of 4910 Old 09-03-2019, 04:30 AM
Frohlich's Avatar
Quoted: 2059 Post(s)
Liked: 2269
Well, I have had the M2s up and running for a few days now. Here are some impressions:
Pros:
They truly sound glorious. So clear, precise and effortless. I watched Godzilla and Alita Battle Angle and both movies sounded glorious in the new room. I also watched quite a bit of Dave Mathews and Tim Reynolds blu ray concert as the recording quality is top notch and this sounded SSOOOOOO good.
Cons:
These were not that easy to set-up for me. Certainly not the plug and play I am use to but nothing crazy difficult either. Totally worth it but here are some obstacles I ran into.
*8/600 DCI N amp is 20 amp socket with a different pin configuration so I had to buy converter to 15 amp (traditional grounded outlet pin configuration)
*Had to buy cheapy PC Laptop since my family is all apple laptops and you can't use the Harman software with apple products.
*Setting up the configuration in Audio Architect took me a few tries to make sure it recognized the amp on the network and to make sure I set-up the LF and HF plus bridged the amps correctly (once you do it the first time its easy after that but this is not Apple software experience where its so intuitive, the process is from 1972).
*I was getting some buzzing from the speakers and thought it might be a ground issue and I used a cheater plug to rule out it wasn't a grounding issue. Ended up having to play with the attenuators on the back of the amp to get the buzz to go away.
Frohlich is offline
post #4760 of 4910 Old 09-03-2019, 04:35 AM
Quoted: 326 Post(s)
Liked: 142
M2's have 120x100 dispersion. Do you know how many dB's down? Procella for example specs their P8 as -6db at 1.5khz at 80 degrees.
Is their such a detailed spec for the M2's?
post #4761 of 4910 Old 09-03-2019, 04:36 AM
Quoted: 326 Post(s)
Liked: 142
Pros:
Cons:
Thanks for the review!
What room correction are you using for the speakers?
post #4762 of 4910 Old 09-03-2019, 04:49 AM
Quoted: 1247 Post(s)
Liked: 712
FYI power cords with the correct socket and a 15A plug are available. My ATI AT2007 came with one.
It is annoying that AA does not run on modern computers. That said, a cheapy generic (or Parallels) is a nominal cost increase, except...
Netsetter feels especially archaic to use...
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #4763 of 4910 Old 09-03-2019, 06:31 AM
Gooddoc's Avatar
Liked: 3380
Pros:
Cons:
Thanks for the review! That just might be the most comprehensive hands on review of the M2 I've ever seen. Seriously
Gooddoc is offline
post #4764 of 4910 Old 09-03-2019, 08:37 AM
Gooddoc's Avatar
Liked: 3380
Also, @Frohlich how do the M2's compare to the 4722's? Just general impression. Time, bias, different room, etc. etc. make this nothing more than anecdotal of course. Just curious your thoughts.
shivaji likes this.
Gooddoc is offline
post #4765 of 4910 Old 09-03-2019, 08:58 AM
Frohlich's Avatar
Liked: 2269
I use XT32 in the Marantz 8802A. I do run them with L/R bypass mode so it basically leaves the left and right channel untouched. The main benefit for me is to let Audyssey fix any subwoofer response issues.
As you know from past interactions on the JBL 4722 thread, I loved those speakers. I stand by that they are the "best bang for the buck" HT speakers I have ever heard or owned. They do eat up a lot of space and really require a dedicated room with an AT screen. I would recommend them for anybody on a normal budget that wants to truly get into a dedicated HT room.
The M2s have a quality that is hard to describe. It feels so cliche to say this, but is like a veil was lifted and I can see into the recording in a way the 4722 (and a lot of speakers) just can't do. When I watched Godzilla over the weekend with my brother in law, it was the best my system has ever sounded. Everything was just so natural and effortless and every detail could be heard...every voice through the center channel was crystal clear...I was just in awe how it could get this much better than my previous system at my old house...but it did.
Footnote: I would be remiss if I didn't fully disclose my previous room with the 4722's was a wide open basement space on a cement slab. This new room in the new house is a sealed 18 x 14 room with suspended wood floors above a garage. The room is tapered and so has less right angles so I am likely getting way less boom in my bass because of the room's physical properties. In other words, the new room is part of what I am hearing and is just a better acoustic space.
Frohlich is offline
post #4766 of 4910 Old 09-03-2019, 09:21 AM
Balbolito's Avatar
Quoted: 186 Post(s)
Liked: 252
Congrats looks good!
My setup should be up and running end of next week! *fingers crossed*
post #4767 of 4910 Old 09-03-2019, 09:24 AM
Gooddoc's Avatar
Liked: 3380
Yeah, as you say, hard to describe. But looking into the recording is the same way I would describe it too.
I've no doubt the 4722 is a great speaker.
Gooddoc is offline
post #4768 of 4910 Old 09-03-2019, 02:24 PM
Kain's Avatar
Quoted: 2000 Post(s)
Liked: 888
Spoiler!
Good stuff.
How many subwoofers do you have? I can see two in the pic you posted.
Kain is offline
post #4769 of 4910 Old 09-03-2019, 02:50 PM
filecat13's Avatar
Quoted: 91 Post(s)
Liked: 185
Pros:
Cons:
Congratulations on your perseverance! The end result is truly with it.
We've been debating building a separate space just for the HT. The current room in the house just isn't quite big enough for three M2s and four 18" subs, and we don't want to start tearing down walls, etc., that will affect resale value somewhere down the road. Likely the better idea is to erect a separate building that can be converted back to an ag building or garage when we're done. The design of your room has me thinking an erected steel building (like an old-time quonset hut) might work if we build a separate building within the building. I could do a little ceiling taper if needed.
Anyway, well done on your part! We're all Apple users here, and the need for us to buy a cheap laptop and cope with some decades-old software was a good reminder to me that all-in-all we're pretty fortunate to have such great tools available to us everyday.
What I can afford, when I can afford it...
filecat13 is offline
post #4770 of 4910 Old 09-03-2019, 05:04 PM
Frohlich's Avatar
Liked: 2269
Originally Posted by Kain View Post
Good stuff.
I have two Deep Sea Sound 18s and they can load that room with clean bass no problem. I had dual JTR S2s in the last theater, which was an open space, and these produce more power and bass than those just because the room is sealed and smaller. Not to mention I am running the M2s as full range.
For anybody interested, there are more pictures and details on my thread:
https://www.avsforum.com/forum/29-wh...l#post58509344
Gooddoc likes this.
Frohlich is offline
Reply Speakers
