Originally Posted by
Ted C
Hi Mark!
Over my dead body!
I think they're absolutely amazing, been spending many hours over the last two months, listening trying to learn all about them, and their behaviors under different conditions and placements. They are simply ridiculous when properly placed in a professional control room environment. I've had several Grammy level recording engineers hear them in here and nearly cry (one actually did).
Its so right its just stupid.
This really says it all. A million words can't really characterize the M2 better than that. It's just "right"
Ted C
Also, any of you gents that have M2's need to go get this record. It is amazing and will tell you a lot about your whole setup top to bottom. Crank Track
#8. If you're setup is right, it will blow your mind. You'll be giddy after you pick yourself up off the floor
The rest of the record will help isolate any problem areas you have. This record was extremely will executed at all levels. Its truly a "diamond in the rough".
"Rippington's- Black Diamond"
https://www.amazon.com/Black-Diamond.../dp/B000000NNK
That is an excellent recording and sounds very good in my room, but I have room issues without a doubt. I know it and hear it. I have heard the M2's in better rooms than mine and I know they are not at their full potential. But I can hear through much of my room issues at this point, although that doesn't make it a good thing, lol.
I really, really would like to hear the M2's in a great room like yours and I will have that for my M2's in the not too distant future.
Ted C
Yes you and Brad need to come down and hear these in 2- channel mode before I change it all.
After listening for many hours and both amps, I feel comfortable saying the 4600 sounds better than the 8300 on the M2's. its not just a power issue. The midrange voicing of the 4600 really brings out the full potential of the D2 driver. I had a bridged 8300 driving them for about a month, then switched over to 2- bridged 4600's, 1200w x 2 per side. They are really "phase locked" now. Its truly startling. I've had some very serious monitoring in my day, but this is something one step beyond... Of course it helps not having a 16' wide, "boundary interfering", recording console in the way! And yes with 2400w per side, they will flat get loud too.
I would be curious as to how the I-Tech 5000HD's would sound compared to the DCi's. It is said to have a better integration of the DSP hardware.
Anyhow, I am very glad to read you are very happy with them Ted. We had quite extensive discussions on the M2's and 7 series, which I greatly enjoyed BTW! But I am always nervous to give my opinion and descriptions of a speaker that might sway someone's decision to move forward with a purchase. I would have felt terrible if you reported back that they sucked, or were even medoicre. I did talk them up quite a bit as I recall, lol! But all truth as I heard it.
I really need a break and Oklahoma is not so far as I recall. And there has to be some skiing around there, no? So close to Colorado as I recall. Anyway, I'll PM you about all that.
Edit:
And you were right! After further quite extensive evaluations, it will indeed be mostly all 7- Series beyond the M2 LCR's (31- total drivers in the room using all 32- chnls of the SDP-75)
If I recall you were at a 7 speaker base layer last we talked....
. And yeah, figured I would quote the part where you say I was right, haha!
