I am wondering how to set speakers to ''Large'' with no remote? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 06-01-2013, 06:12 AM - Thread Starter
Kamran000's Avatar
Hi all. I have come into the possession of a JVC TH-S55 home theater system. I have replaced the front L R with some larger kenwood speakers, however i do not know how to set the speakers to large. I have the remote but only the volume buttons work which renders it relativity useless. Can anyone help me on how to set the speakers to large or at least increase the bass sent to the speakers? Is it even possible?
Kamran000 is offline
post #2 of 16 Old 06-01-2013, 06:15 AM
4DHD's Avatar
Quoted: 206 Post(s)
Liked: 114
If that system is a HTiB, then there is probably no provision to change speaker settings.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 16 Old 06-01-2013, 06:18 AM
commsysman's Avatar
Quoted: 1122 Post(s)
Liked: 587
Download and print out the manual from the JVC website.
It is listed under Product Support/ User manuals at JVC.com.
It looks like all of the control functions are available on the front panel of the unit.
commsysman is offline
post #4 of 16 Old 06-01-2013, 06:24 AM
bladerunner6's Avatar
Quoted: 30 Post(s)
Liked: 59
Here is a link to the manual.
http://www.jvc.co.uk/files/instruction_manual/gvt0152-001a.pdf
There is something mentioned about speaker set up but I think you are going to have an issue without the remote working.
bladerunner6 is offline
post #5 of 16 Old 06-01-2013, 08:46 AM - Thread Starter
Kamran000's Avatar
post #6 of 16 Old 06-01-2013, 08:47 AM - Thread Starter
Kamran000's Avatar
post #7 of 16 Old 06-01-2013, 08:52 AM
crn3371's Avatar
Quoted: 318 Post(s)
Liked: 274
Just because you now have larger speakers doesn't necessarily mean they should be set to large in your avr.
crn3371 is offline
post #8 of 16 Old 06-01-2013, 09:38 AM - Thread Starter
Kamran000's Avatar
I think that I would get more out of my system, a fuller, richer bass note if I did so.
post #9 of 16 Old 06-01-2013, 09:38 AM
afrogt's Avatar
Quoted: 2326 Post(s)
Liked: 1520
True, if you have a subwoofer the fronts probably shouldn't be set to Large.
Afro GT
afrogt is online now
post #10 of 16 Old 06-01-2013, 09:49 AM
afrogt's Avatar
Liked: 1520
post #11 of 16 Old 06-01-2013, 10:48 AM - Thread Starter
Kamran000's Avatar
I do have a sub, however I just feel that my fronts are severely underused, they have so much potential you see.
post #12 of 16 Old 06-01-2013, 10:51 AM - Thread Starter
Kamran000's Avatar
I have looked into that, but I do not understand the code aspect?
post #13 of 16 Old 06-01-2013, 10:55 AM
afrogt's Avatar
Liked: 1520
you're gonna need a remote to do anything with that receiver.
Afro GT
post #14 of 16 Old 06-01-2013, 10:59 AM - Thread Starter
Kamran000's Avatar
I have the remote, but only the volume (up) (down) buttons work. This leads me to believe that the rest of the buttons do not work, I could be wrong? Perhaps there's something that I could do to get the other buttons working like activate them or something? I have cleaned the inside of the remote twice and have seen no improvement.
post #15 of 16 Old 06-01-2013, 10:20 PM
NuSoardGraphite's Avatar
Quoted: 543 Post(s)
Liked: 494
Purchase a Universal Remote that you can program. You might be able to find a cheap Harmony ($50 maybe) that would do the trick.
Stand tall and shake the heavens...
NuSoardGraphite is offline
post #16 of 16 Old 06-02-2013, 03:20 AM - Thread Starter
Kamran000's Avatar
Will any universal remote do?
Reply Speakers
