Need help on surround speaker selection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-25-2013, 03:17 PM - Thread Starter
rv75's Avatar
Quoted: 23 Post(s)
Hello,
I am finally starting to build a small Home Theater in my basement. The dimensions of the room are 23 x 12 x 8.
I have have bought the following speakers used from a very good friend:
2 Klipsch RF-5 & 1 Klipsch RC-7.
Can you recommend 4 budget speakers that would complement the Klipsch setup I'll be using?
Budget is under $1,000 and taking into account that I want to set up a 7.2 configuration.
Also, if you want to throw a recommendation for a budget pair of subs I would greatly appreciate it.
Many Thanks!
rv75 is offline
Reply Speakers
Klipsch Rf 5 , Klipsch Rc 7 Center Channel Speaker
