AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Speakers (https://www.avsforum.com/forum/89-speakers/)
-   -   Help with kinda budget HTS? (https://www.avsforum.com/forum/89-speakers/1504336-help-kinda-budget-hts.html)
Bw1016 12-08-2013 12:36 AM
Hey, im looking for a nice HTS setup for under 650$. I'm currently looking at the Sony STRDH540 for a receiver because of the 5.2 and the Yamaha  NS-SP1800 for speakers  and will buy another sub for the set. Any opinoins or advice? I mainly watch movies ( fairly loud ) and blast my music. My Media room is about 12x12 feet and i dont need a super high end set im just looking for some speakers that will fill my room plenty loud. Thanks in advanced! Or should i just buy the Samsung HT-F5500? Figured Custom set would be better.
bladerunner6 12-08-2013 04:40 AM
That is a really tight budget. Really tight.
I would recommend starting with a 3.1 system then adding rears later.
But if you insist on this budget.
These for speakers:
http://www.amazon.com/Jamo-426-HCS-WENGE-5-Piece/dp/B003GGXGU6
This for a sub:
http://www.nextwarehouse.com/item/?825111_g10e
And this for a receiver:
http://www.accessories4less.com/make-a-store/item/DENAVRE300/DENON-AVR-E300-5.1-3D-Networking-Receiver-AirPlay/1.html
Do you live near a Fry's? They often have awesome deals on Denon receivers and Infinity Primus speakers.
Buying some Andrew Jones Pioneer Speakers on sale might also work.
Buy three pairs of these, use two pairs for the front and rears and then one of the third pair for a center.
http://www.newegg.com/Product/Product.aspx?Item=N82E16886983001
Or a couple pairs of the refurbished Pioneer bookshelf speakers and this for a center:
http://www.frys.com/product/7285763?source=googleps&gclid=CMuV7r_QoLsCFdEWMgodDQIAgg
If it were me for your budget and room, I would go with two pairs of the Pioneer bookshelf and the matching center, plus the BIC sub and the Denon 300 from ACL.
Others I am sure will throw out some ideas but you do have a very tight budget.
One upside is that you have a small room, so you don't have to spend a huge amount on towers, etc.
Also, looking at used speakers can be a valid idea.
zieglj01 12-08-2013 06:11 AM
I prefer phase (2) Pioneer for the fronts
Look at 1 pair Pioneer BS22 speakers
and Pioneer C22 center
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Delectronics&field-keywords=pioneer+speakers&rh=n%3A172282%2Ck%3Apioneer+speakers
For surrounds, the B21 < on the same Amazon page >
(if you want to save a few dollars, then get them from Newegg)
Mordaunt Short subwoofer
http://www.accessories4less.com/make-a-store/item/MORDCARN9BLK/MORDAUNT-SHORT-Carnival-9-10-100w-Powered-Subwoofer-Black/1.html
Denon 1613 receiver
http://www.accessories4less.com/make-a-store/item/DENAVR1613/DENON-AVR-1613-5.1ch-Networking-Receiver-w/AirPlay-3D-ready/1.html
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
