Klipsch opinion: RF-52 ii towers or RB-61 ii bookshelves? With RC-52 ii or RC-62 ii center? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-28-2013, 08:28 PM - Thread Starter
barberfunny's Avatar
Hello all,
I know there are numerous threads with similar questions, but mine is very specific so I hope you all don't mind.
Considering either RF-52 ii or RB-61 ii for my new fronts in my medium sized room, stepping up from my old Synergy SF-1 with SC-1 center.
I have read that the RB-61 ii actually have punchier mids than the RF-52 ii, and with these towers' dual 5.25 drivers, I'm not too surprised.
I plan to buy an RC-52 ii center, although I have considered the RC-62 ii.
If I get the RF-52 ii, I'll be surely getting the RC-52 ii for the center.
If I get the RB-61 ii, I would likely still get the RC-52 ii, but I realize I could consider stepping up to the RC-62 ii, given that the drivers would then be 6 1/2 across my front stage.
I'm seated centrally about 8-10 feet from a 50" plasma. I could be moving around a few times the next few years, so with my upgrade I'm planning for a medium-size setup as a compromise.
My receiver is a Yamaha RX-V675.
For a sub, I'm looking at the SVS SB12-NSD.
Which of these combos would you vote for and why:
1. RF-52 ii with RC-52 ii
2. RB-61 ii with RC-52 ii
3. RB-61 ii with RC-62-ii
I imagine the RC-62 ii would not be a good center if I go with the RF-52 ii, and I think the RF-62 ii, although awesome, are just beyond my needs.
Yamaha RX-V675
Klipsch SF-1 x2
Klipsch SC-1
Klipsch Quintet II satellite x2 side surrounds
Panasonic TC-P50ST60
Panasonic BDP-230
XBOX 360
Apple TV 2
barberfunny is offline
post #2 of 8 Old 12-28-2013, 08:32 PM
crazyrob425's Avatar
Quoted: 451 Post(s)
Liked: 343
No need for towers with a subwoofer especially with a quality subwoofer like you have
I would go with the RB-61 with the matching center with with same size drivers
crazyrob425 is offline
post #3 of 8 Old 12-28-2013, 08:35 PM - Thread Starter
Thanks, I'm leaning that way.
Yamaha RX-V675
Klipsch SF-1 x2
Klipsch SC-1
Panasonic BDP-230
XBOX 360
Apple TV 2
post #4 of 8 Old 12-29-2013, 03:28 AM
Reference_head's Avatar
Quoted: 144 Post(s)
Liked: 731
3 is the best pick because it has the better center. I would say the rb61ii and rf52ii are really close. If you go towers I would get at least the rf62ii.
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
post #5 of 8 Old 12-29-2013, 11:11 AM
Prime316's Avatar
Quoted: 190 Post(s)
Liked: 207
I agree that the towers aren't a necessity if you have a good sub. I am just partial to towers.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 4
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #6 of 8 Old 12-29-2013, 01:05 PM
Quoted: 144 Post(s)
Liked: 731
I as well. Towers have a bigger box and usually more power handling. So at loud levels the towers are working less than a bookshelf.
Note.. That is my opinion if the two are of the same quality and design.
post #7 of 8 Old 12-29-2013, 03:22 PM
csgamer's Avatar
Liked: 33
Not a fan of MTM horizontal centers. Would pick none of your options. If going klipsch bookshelf, would get 3 rb-61's or 3 rb-81's for the front.
5 rb-81's are kind of pricy if eventually going 5.1. So would go for 6 rb-61's, then sell one off. I prefer direct firing surround for improved multichannel stereo performance.
csgamer is offline
post #8 of 8 Old 12-29-2013, 03:32 PM
Quoted: 144 Post(s)
Liked: 731
That would be good too. The rc-62 is a great center though. Regardless of how it sits. biggrin.gif
Reply Speakers
Klipsch Rf 52 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rb 61 Ii Reference Series Bookshelf Loudspeakers Black Pair , Klipsch Rc 52 Ii Reference Series Center Channel Loudspeaker Black Each
