Please help with speakers I just got (semi-urgent) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-30-2013, 05:03 PM - Thread Starter
FunkyGodzilla's Avatar
buying my first setup. got the Ascend acoustic 340's
and a SVS SB-1000 sub
then bought a Yamaha rx-v375
please note I'm very limited in my knowledge of speakers and receivers, and the jargon for them.
put the wires in front left and front right on the back of the Yamaha receiver
ran them to the speakers, oh what do you know, life is complicated, there is 4 things i can put wire into
on the top it says tweeter input (high frequency)
on the bottom it says Woofer input (low frequency)
each having a black and red, positive negative, from left to right.
what do I do?
FunkyGodzilla is offline
post #2 of 6 Old 12-30-2013, 05:22 PM
GTZ
GTZ's Avatar
Life isn't complicated. On the back of the speaker where the binding posts are you'll notice a gold colored piece of metal connecting the black to black and red to red. You can hook your speaker wire to either the top or bottom, just leave that gold piece in place. Remove it only if/when you bi-amp your Ascends. Remember to keep polarity correct. Speaker wire has one wire with a mark, ribs, or something to distinguish it from the other wire. On mine there is a '+' mark on the wire and nothing on the other wire. I hook the '+' to the red connection of my receiver and the red posts on my speakers. Nice choice on your speakers!
GTZ is offline
post #3 of 6 Old 12-30-2013, 05:27 PM - Thread Starter
thanks so I just connected them to the top and kept the bridge on.
actually have one more question. I plugged my sub wire in the back of the receiver, it clearly is marked "sub" or whatever on the yamaha.
but I go to the sub and there's like 4 different spots i can plug the cable...?
post #4 of 6 Old 12-30-2013, 05:44 PM - Thread Starter
wait got it got it. they sound good.
post #5 of 6 Old 12-31-2013, 07:37 AM - Thread Starter
thanks for the help.
post #6 of 6 Old 12-31-2013, 05:48 PM
charmerci's Avatar
Quoted: 413 Post(s)
Liked: 309
Hey, wait a minute!
I'm following this!
charmerci is offline
Reply Speakers
Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Yamaha Rx V375 5 1 Channel Av Receiver , Ascend Acoustics Cmt 340 Se Center
