I think I was dumb before, help me not be dumb again! - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 43 Old 01-02-2014, 05:39 PM
Reference_head's Avatar
Quoted: 144 Post(s)
Liked: 731
Originally Posted by MJMcMahon View Post
thoughts about the suitability of the Klipsch RC-42 II as a replacement for the KC-25? My TV console limits the space available for the center and the RC-42 will fit. If not the RC-42, suggestions on an alternative that will fit into a 19"x8" area?
Mike
So you have no way to go bigger? The rc42ii would be an upgrade. But i would pass on anything less then a rc52ii.
And really the rc62ii is a giant leap and will be a huge upgrade for your whole system. Thats what i would try and work into your system if you can. The older rc62 can be had for around 275 used.
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
post #32 of 43 Old 01-02-2014, 08:34 PM - Thread Starter
MJMcMahon's Avatar
Liked: 24
Reference_head -
So here's the deal - my center sits inside the center shelf of a Sonax TV cabinet (the ML-3609 if you're curious). The RC52 is about an inch-and-a-half too wide for the space (max width: 19"). I stopped by RCWilley on the way home and grabbed the RC42-II and have been listening to it tonight. It does seem significantly cleaner than the KC-25 that was previously in the position, but that may be at least partially due to the fact it's got the adjustment post which allows it to be pointed at my listening position properly. The KC-25 barely fit in the space (18.75" wide) and really didn't have enough vertical space to allow it to be pointed properly. I'd considered moving the speaker into the position above the shelf, but doing so would block the lower part of the television. I could mount it above the television but I have some reservations about that too.
I do have a couple of weeks to toss this around. The Sonax cabinet has given me some problems (sagging in the center) and I'm working with the manufacturer to see what can be done about it. We'll see whether they'll replace it or not. If the opportunity presents itself, I'll look at going a different direction on the speaker placement and going to the RC-52 or RC-62. Why the RC-52/62? Is it a better 'match' for the KF-28's?
The other question that I've been unable to find a good answer for: does placing the center inside another cabinet (especially a tight one) affect the sound output from the speaker? Could that accentuate the muddy performance of the KC-25?
MJMcMahon is offline
post #33 of 43 Old 01-02-2014, 08:50 PM
zieglj01's Avatar
Quoted: 3206 Post(s)
Liked: 3113
Having something outside of a tunnel, can give you better sound
http://www.crutchfield.com/shopsearch/center_bracket.html
Who AM I
zieglj01 is online now
post #34 of 43 Old 01-02-2014, 09:46 PM - Thread Starter
MJMcMahon's Avatar
Liked: 24
I actually had been looking at those...my concern is that the CSB-1210 (http://www.centerstagebracket.com/1210.html) is rated to support 25 pounds. The RC-62 is rated at 30 and the CSB-3006 appears to have been discontinued. Have either of you guys used this thing and is it likely to support a heavy center?
Also, my TV is an LG 60PK550 which has no plastic bezel around the screen....it's glass. While I can certainly put something in between the shelf and the glass to avoid scratching it, I wonder about the effect of the pressure on the glass?
Thanks again for all your patience and suggestions, guys...I realize I'm a noob when it comes to this stuff, but I'm trying smile.gif (hopefully more than your patience! wink.gif)
post #35 of 43 Old 01-02-2014, 11:10 PM
Quoted: 144 Post(s)
Liked: 731
MJ what your hearing is the rc42ii is just a better speaker than what you had. The drivers, cab, and even the xover are all better.
The 52 or 62 would not match better it would just be better. And it would set you up for a perfect upgrade down the road.
Can you wall mount your tv and place a center where the tv was?
post #36 of 43 Old 01-02-2014, 11:19 PM - Thread Starter
MJMcMahon's Avatar
Liked: 24
Reference_head -
the TV is capable of wall mounting but I have not done so to date because I may relocate the TV within the room. I've sent requests for information to CSB's customer service as well as Crutchfield's to confirm whether the CSB-1210 will hold the RC-62-ii. If I can work out a way to mount it above the TV without damaging the TV or threatening the stability of the speaker, I'll do so. I know that RCWilley had the RC-52-ii in stock and I'll call them tomorrow to confirm whether they have the RC-62-ii. It's a good probability that I'll swap the RC-42-ii out for one or the other tomorrow.
Other reading on AVS has helped me to discover that I'd done my Audyssey setup and had some settings in my amp set incorrectly as well. Amazing how much better things sound when you do a little research and follow the directions. biggrin.gif
I haven't forgotten about the sub...it'll likely happen in the next few months, after our tax return comes back.
Thanks again for all the help...I'll let you know how things come together.
post #37 of 43 Old 01-03-2014, 01:33 PM - Thread Starter
MJMcMahon's Avatar
Liked: 24
Okay - time for the big and tough question: is the RC-62-ii so much better than the -52-ii that it's worth another $250? I know value is very subjective, but it's a pretty big jump from $299 to $549.
post #38 of 43 Old 01-03-2014, 01:49 PM
AlexanderDelarg's Avatar
Quoted: 223 Post(s)
Liked: 270
Also -
I was looking at the SVS PC12 NSD...it's small footprint might minimize the chances of little hands playing with it, especially if I can continue to hide it in a corner. Thoughts?
A very nice sub. The free shipping and 45 day in home trial with great customer service is hard to beat.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | Hulu | Roku Ultra | Monoprice 12AWG |
AlexanderDelarg is offline
post #39 of 43 Old 01-03-2014, 02:40 PM
Kini62's Avatar
Quoted: 2743 Post(s)
Liked: 2570
I'm using what is essentially a RC-52 with my RF62s and have been nothing but impressed with it. Keeps up with the towers just fine. I'm sure the 62 is a step up, but for me the price was too high in comparison and it was too big to fit on the center stage bracket I use on top my TV.
If you can afford it and have the space, always get the most you can afford.
As for the PC12, I have the Plus version and it's awesome. It seems really big at first but it pretty much just disappears into the corner after a while. Very unobtrusive.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #40 of 43 Old 01-03-2014, 05:14 PM
Quoted: 144 Post(s)
Liked: 731
I have owed both and to me the 62 is worth every penny more. But if you chose the 52 I'm sure you will still be happy.
I found this pic rc-62ii on the left the rc-52 (old version) next it.
post #41 of 43 Old 01-03-2014, 05:16 PM
Quoted: 144 Post(s)
Liked: 731
post #42 of 43 Old 01-09-2014, 11:17 PM - Thread Starter
MJMcMahon's Avatar
Liked: 24
Thanks so much for everyone's help...I wound up going to a local store over the weekend and brought home a B&W front set (685 bookshelves and stands, and an HTM-62 center) and a Martin Logan Dynamo 700W sub. Things are sounding great and I'll be selling the Klipsch Icons.
Many thanks for all the advice...it turns out you all were right: better fronts and a decent sub are making a big difference in how the sound fills the room and even make the Klipsch surrounds sound better. smile.gif
post #43 of 43 Old 01-10-2014, 06:12 AM
flyng_fool's Avatar
Quoted: 190 Post(s)
Liked: 172
Thanks Javk...I'll take a look at the Ascends. My room layout may be contributing to the lack of surround as well. The wall behind my seating area is probably 15' away. I'll try and draw something up.
That may be your surround issue right there. Those tiny Icons 15' away will struggle to fill in the surround when the fronts are playing loud.
Television: Vizio E70iA3
Processor: Emotiva MC700
Surrounds: AT 2200 LR Sub: Danley DTS-10Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
Reply Speakers
Klipsh Icon Kf 28 Floorstand Speaker , Onkyo Tx Nr809 , Velodyne 10 Subwoofer Dps 10 , Psb Speakers Image T5 Tower , Psb Speakers Image C5 Centre , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Hsu Vtf2 Mk4 , Rythmik Audio Lv12r
