Are Polk Audio RTI A3 recommended over B&W 686? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 86 Old 01-17-2014, 01:22 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
Originally Posted by mark62 View Post
I think you would be better off with the PB-1000.
you would be using it in a bedroom right? room size?
and since you are using this with a stereo receiver, would you know how to hook it up? i ask this because your speaker wire post suggest that you seem overwhelmed with pretty simple things dealing with hooking things up.
Yes, that's right a bedroom. I don't know the size of my bedroom. And no I won't be overwhelmed, but no, I don't know how to hook it up, but if you or someone would be happy giving step by step directions meaning writing all the steps in one post than I would be very happy doing it myself.
BTW, does my Integra DTM 5.9 have a sub output?
And with a sub, also get those Klipsch speakers as well?
php111 is offline
post #32 of 86 Old 01-17-2014, 01:35 PM
mark62's Avatar
Quoted: 21 Post(s)
Liked: 99
no, i dont think it has a sub output so that makes it that much more difficult to hook up.
as far as the as the klipsch, you really should try to listen to them first as posted above they really arent more sensitive as the polks or Focals listed above.
also if you have been satisfied with the low end output of the B&W's then the new speakers you get with a bigger mid-bass driver will most likely will output more bass.
mark62 is offline
post #33 of 86 Old 01-17-2014, 01:44 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
I just looked at the manual to verify and it does have a sub output. Please see page 13.
http://onkyo-audio.pl/uploads/files/ins/integra/dtm-5.9.pdf
php111 is offline
post #34 of 86 Old 01-17-2014, 02:09 PM
mark62's Avatar
Quoted: 21 Post(s)
Liked: 99
i see the sub output, but i dont see how you set it up in the receiver.
mark62 is offline
post #35 of 86 Old 01-17-2014, 02:13 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
Does Integra offer email support, and where's the contact page?
php111 is offline
post #36 of 86 Old 01-17-2014, 02:15 PM
mark62's Avatar
Quoted: 21 Post(s)
Liked: 99
http://www.integrahometheater.com/prod_support.cfm
mark62 is offline
post #37 of 86 Old 01-17-2014, 02:17 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
Thank you! I'll email email them and let you know their response normally about 24-48hrs longer if a delay.
php111 is offline
post #38 of 86 Old 01-17-2014, 02:26 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
I don't see an email for them. I see a phone number.
php111 is offline
post #39 of 86 Old 01-17-2014, 04:14 PM
mark62's Avatar
Quoted: 21 Post(s)
Liked: 99
mark62 is offline
post #40 of 86 Old 01-17-2014, 04:30 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
I sent it and thank you!
php111 is offline
post #41 of 86 Old 01-18-2014, 02:36 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
I'm still waiting on a reply. I'll write back and let you know what they say.
In the meantime, does Polk or Klipsch work better with rock music something like let me see the man in the box song off of the Facelift album which is rock I guess. So, do those speakers hold up well with rock and which ones do better with rock music?
php111 is offline
post #42 of 86 Old 01-18-2014, 06:24 PM
crazyrob425's Avatar
Quoted: 451 Post(s)
Liked: 343
Both will hold up well.
Have you gone a an audio store where you can demo and listen to either of those speakers?
If you give us your exact budget we might be able to suggest more speakers.
crazyrob425 is offline
post #43 of 86 Old 01-18-2014, 07:11 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
No, I don't know of any audio stores around me. And a budget in the prince rang of the Polks RTI A3.
php111 is offline
post #44 of 86 Old 01-18-2014, 07:15 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
BTW, I edited that post. I actually put an "i" so I took it out and it should be "man in the box" I doubt my system would handle hard rock like that when it can't even handle a movie with scenes made to be loud.
php111 is offline
post #45 of 86 Old 01-18-2014, 07:18 PM
zieglj01's Avatar
Quoted: 3103 Post(s)
Liked: 3019
Your budget is somewhat confusing, because of your other thread.
https://www.avsforum.com/t/1512723/would-this-be-very-high-end-quality
Who AM I
zieglj01 is online now
post #46 of 86 Old 01-18-2014, 07:18 PM
Geoff4RFC's Avatar
Quoted: 469 Post(s)
Liked: 1652
I'm a Polk guy, but I've heard that Klipsh are better H.T. than music speaker due to the horns. The RTiA series make great speakers in both areas.
Set up:
Marantz AV8802A w/Pangea Premium XLR's-Source: Oppo 103-CD Player: Emotiva ERC 3 w/Pangea Premium XLR's
Display: Samsung QLED 65F-Amplification: Emotiva XPA-DR3, XPA-2 x 2
Mains: PolkAudio LSiM707, C 706, SS 702, RS RTiA9
Geoff4RFC is offline
post #47 of 86 Old 01-18-2014, 07:21 PM
mark62's Avatar
Quoted: 21 Post(s)
Liked: 99
Best Buy should have polks and klipsch to listen to. there's one is whitehall and easton pa.
http://stores.bestbuy.com/1403/
Audio Concepts
1302 E Tilghman St
Allentown PA 18109
Best Buy
1504 Macarthur Rd
Whitehall PA 18052
Serious About Sound LLC
2096 Route 212
Coopersburg PA 18036
Current Home Systems
36 E Goepp St
Bethlehem, PA 18018
(610) 653-497
EZ TV & Audio
Bethlehem, PA 18017
(610) 248-4411
http://www.integrity-audio.com/
http://www.yellowpages.com/bethlehem-pa/home-audio-store
mark62 is offline
post #48 of 86 Old 01-18-2014, 07:24 PM
mark62's Avatar
Quoted: 21 Post(s)
Liked: 99
it is because you are over driving your receiver trying to play your inefficient speakers LOUD
mark62 is offline
post #49 of 86 Old 01-18-2014, 07:26 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
I did say at the beginning of that thread I far have enough, right? And I was asking if that would be very high quality hence what I said at the beginning of the thread I don't have enough and was only asking, right?
php111 is offline
post #50 of 86 Old 01-18-2014, 07:27 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
Audio Concepts
1302 E Tilghman St
Allentown PA 18109
Best Buy
1504 Macarthur Rd
Whitehall PA 18052
2096 Route 212
36 E Goepp St
Bethlehem, PA 18018
(610) 653-497
EZ TV & Audio
Bethlehem, PA 18017
(610) 248-4411
Thank you!
php111 is offline
post #51 of 86 Old 01-18-2014, 07:41 PM
zieglj01's Avatar
Liked: 3019
Go to Best Buy and check out entry level Klipsch and Polk - however, I do
not think you will find the RTi or Klipsch Reference lines there.
I still recommend the Focal 706 or the JBL L830, which are not entry level.
JBL, Focal, Polk RTi or a used/older Klipsch Reference - may give you the
slap in your ear sound that you desire - till you get a sub.
Who AM I
post #52 of 86 Old 01-18-2014, 07:48 PM
mark62's Avatar
Quoted: 21 Post(s)
Liked: 99
these are very nice speakers for $450 reg. price $700 as suggested by zieglj01 and they should play loud for you....
http://www.musicdirect.com/p-41246-focal-chorus-706v-bookshelf-speakers-pr.aspx
mark62 is offline
post #53 of 86 Old 01-18-2014, 07:55 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
Or what about this? How good is the quality? I suppose its less than about $11,000 worth from my one thread. So, would this be a better option? Would anyone advise this? Denon X2000+pair of Revel M12 speakers+SVS sub? Yes, that is excellent quality? Or no means its poor?
php111 is offline
post #54 of 86 Old 01-18-2014, 08:04 PM
mark62's Avatar
Quoted: 21 Post(s)
Liked: 99
why would you want a 7.1 receiver for 2 channel stereo? unless you later want to move to that direction.
those speakers are in line with the Focals or Rti's or klipsch...IMO... depends on what you prefer. also the sensitivity on the Revels is only 87dB so you would only be gaining 3dB over your current speakers
and the svs pb-1000 is a great sub.
i think we all are getting a might bit confused on what you are trying to accomplish here.
mark62 is offline
post #55 of 86 Old 01-18-2014, 08:11 PM
mark62's Avatar
Quoted: 21 Post(s)
Liked: 99
mark62 is offline
post #56 of 86 Old 01-18-2014, 08:23 PM
zieglj01's Avatar
Liked: 3019
+1
this is not balancing out with the current need and the so-called budget.
Who AM I
post #57 of 86 Old 01-18-2014, 08:24 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
Never mind about everything I'm asking. Alright, here is the reasons why I'm asking. Someone on Audio Holics told me that the KEF would be very high end and he told me that the next one under the KEF R series would be high quality would be the Revel setup. Is he proving me false information and I shouldn't take his advice? That's the reason why I was asking about KEF, Denon, Revel, and all of that.
This what I want http://www.klipsch.com/rb-61-ii-bookshelf-speakers-pair/details and this http://www.amazon.com/gp/aw/d/B00AF88C0M/ref=mp_s_a_1_2?qid=1390104950&sr=8-2&pi=SX200_QL40 and could I buy when I'm ready without doing a demo listen at a store?
And I still don't how to setup the sub in my receiver.
php111 is offline
post #58 of 86 Old 01-18-2014, 08:37 PM
zieglj01's Avatar
Liked: 3019
The guy at Audioholics, is just giving you his personal preference - there is no so-called
the best speaker - it is what is best or perfect for you.
Who AM I
post #59 of 86 Old 01-18-2014, 08:37 PM
mark62's Avatar
Quoted: 21 Post(s)
Liked: 99
the pb-1000 would be better in general than the sb-1000 for the sub
the klipsch's wont play any louder than the Focals for instance as klipsch inflates their sensitivity numbers.
klipsch would not be my first choice and probably since you have not heard them should not be yours either. klipsch has a sound characteristic or signature that people tend to love or hate, i do not like them. but you might like them, if you dont buy them from a place you can return them without hassles.
the Focals would be a safer bit IMO. or even the JBL listed above.
my advice take it one at a time and get speakers, the new speakers may be good enough for you without a sub as the ones listed go deeper and play louder.
also as to the advice given elsewhere, you posted about your problem with the receiver shutting down due to over driving it, so you want more efficient speakers and those Revels altho may be fine speakers are only a little bit better in their sensitivity rating than yours are.
mark62 is offline
post #60 of 86 Old 01-18-2014, 08:41 PM - Thread Starter
php111's Avatar
Quoted: 18 Post(s)
Without what was mentioned in here or what was already mentioned, what would be "your" first speaker choice in your preference?
php111 is offline
Reply Speakers
Polk Audio Rti A3 Bookshelf Speakers , Klipsch Rb 61 Ii Reference Series Bookshelf Loudspeakers Black Pair , Focal 706v Chorus Loudspeakers , Jbl L830 3 Way 6 Inch Bookshelf Loudspeaker Pair Black
