Advice for new 5.1 setup using cat6 wiring - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-18-2014, 03:00 PM - Thread Starter
MattRK's Avatar
My house is pre-wired with shielded cat6. There is a drop in each location around my living room where my speakers will be placed. I can replace the wire for the surrounds easily but the fronts and center are placed on an external wall that would be extremely hard to replace. The runs are about 50ft to the receiver in my AV closet. I plan on using two pairs (twisted together) for the + and the other two pairs (twisted) for the -. The room in question is an "open style" living room / kitchen. The living room area measures about 16 x 14.
Here is what i'm thinking o purchasing:
Fronts: Two Polk Audio RTi A5
Center: Polk Audio CSI A4
Surrounds: Two Polk Audio RTi A1
Sub: SVS PB-1000 OR Polk Audio PSW505
This would be powered by the Denon AVR-1613 i already own.
My questions:
1) Will i be losing out (significantly) on quality using the above speakers with Cat6 cable instead of real speaker cable? Would i be better off purchasing cheaper speakers since i can't replace the wiring?
2) Will my Denon AVR-1613 be able to drive the above speakers?
Here is a drawing of the room in question:
MattRK is offline
post #2 of 3 Old 02-18-2014, 10:22 PM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 165
Hum are you sure you can't pull speaker wire?
Access from underneath?
I'd opt for some patch and paint work before I used cat cables for speaker level signals.
Cat cable for speakers level is a bad idea for many reasons.
Lack of sufficient gauge, high impedance....
trans_lux is offline
post #3 of 3 Old 02-19-2014, 07:27 AM
Bill Fitzmaurice's Avatar
Liked: 5778
Use this to calculate the required gauge:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
A 50 foot run needs at least 18 gauge, which is the equivalent of three 23 ga. wires.
Bill Fitzmaurice is offline
Reply Speakers
Polk Audio Rti A5 Floorstanding Speaker Single Black , Polk Audio Csi A4 Center Channel Speaker Single Black , Polk Audio Rti A1 Bookshelf Speakers , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Denon Avr 1613 Receiver
