Poor Speaker Placement? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 02-21-2014, 09:52 AM - Thread Starter
Grenpa's Avatar
Made a thread a week ago or so looking for recommendations for speakers, I was thinking the Monitor Audio RX1's but it might be an issue
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality = 90
I'm going to be using them with my computer, and they'll be on my desk on the sides of my monitor in a desk with a similar setup to this one (Although not as nice haha)
How badly would the sound be affected? I know they're rear ported so the bass might be a little much but if that's an issue I could plug them up
Would there be other negative consequences though being crammed inside something like that?
I know location is key with speakers and this is not ideal at all, but would it be passable? Or should I look for different speakers?
Grenpa is offline
post #2 of 16 Old 02-21-2014, 07:33 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3015
Right. Rear ports are problematic being tucked up in a corner like that.
I can't imagine that the MAs will have any additional difficulty that another speaker might also have with that kind of placement.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #3 of 16 Old 02-22-2014, 09:33 AM - Thread Starter
Grenpa's Avatar
So should I look for front ported ones, or could it be okay?
Grenpa is offline
post #4 of 16 Old 02-22-2014, 10:00 AM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
Don't worry about front ported vs rear ported. The low frequencies from *any* speaker travel in every direction anyhow. So long as a port has a couple of inches of space behind it, it will be fine.
kiwi2 is offline
post #5 of 16 Old 02-22-2014, 11:08 AM
cel4145's Avatar
Liked: 3015
My experience is different. Sometimes ported speakers could use more than just a couple of inches, especially if in a cabinet, like the picture above.
cel4145 is offline
post #6 of 16 Old 02-22-2014, 11:42 AM
sdg4vfx's Avatar
Quoted: 241 Post(s)
Liked: 201
+1
My neighbors all listen to great music. Whether they like it or not.
sdg4vfx is offline
post #7 of 16 Old 02-22-2014, 12:38 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
That could apply to any speaker. Front ported, rear ported, sealed.
kiwi2 is offline
post #8 of 16 Old 02-22-2014, 01:44 PM
buzzy_'s Avatar
Quoted: 134 Post(s)
Liked: 164
Yes, the physics of ports are well defined. A distance of 2-3x the diameter of the port tube minimizes that consideration.
Cabinets, not so much. But it is what it is.
Great speaker and price, but do you really have space for the RX1s? Did you consider the NHT Absolute Zero?
buzzy_ is offline
post #9 of 16 Old 02-22-2014, 04:17 PM - Thread Starter
Grenpa's Avatar
It'll fit with a couple inches breathing room, even if I get a smaller speaker it's still not going to be located much better. Just don't want to get something smaller that I might regret later in the future, might as well get something I really want even if it might not be perfect, that's at least what I think. (Just can't take these computer speakers anymore, really bumming me out)
It'll have to be like that for a while unfortunately, but hey when I do get to get it situated properly in the future I'll be able to appreciate the speakers even more! haha
Grenpa is offline
post #10 of 16 Old 02-24-2014, 03:54 PM - Thread Starter
Grenpa's Avatar
Any more input before I pull the trigger on these speakers?
Grenpa is offline
post #11 of 16 Old 02-24-2014, 04:27 PM
zieglj01's Avatar
Quoted: 3004 Post(s)
Liked: 2909
+2
I have owned many, many rear ported speakers
Who AM I
zieglj01 is online now
post #12 of 16 Old 02-24-2014, 04:28 PM
zieglj01's Avatar
Liked: 2909
I believe that I would chose another option for your set-up.
http://www.musicdirect.com/p-41245-focal-chorus-705v-bookshelf-speakers-pr.aspx
However, your call
Who AM I
post #13 of 16 Old 02-24-2014, 04:47 PM
cel4145's Avatar
Liked: 3015
+1
Oohhh...I forgot about those being on sale. Those Focals would be an excellent choice for that price, and it's front ported, which is much harder to find.
cel4145 is offline
post #14 of 16 Old 02-24-2014, 06:09 PM - Thread Starter
Grenpa's Avatar
However, your call
What about the 706v?
Grenpa is offline
post #15 of 16 Old 02-24-2014, 06:19 PM
zieglj01's Avatar
Liked: 2909
The 706 can/may work for you - however, they are bigger and take up more space.
The 705 can/may image better up close. MusicDirect does have a 30 return policy.
Your call
Who AM I
post #16 of 16 Old 02-25-2014, 07:41 PM - Thread Starter
Grenpa's Avatar
Your call
Hmm yeah the 706v's are just a couple inches too wide, unless I moved my monitor way forward
This is quite a dilemma
Those RX1's look so nice and have favorable reviews, but the rear port is kinda killing that plan for the time being
I just don't want to get something that might be optimal for now and then regret it a year or two down the line when the other option could have been a better choice
Being stuck in pretty much a box how would it change the sound of them? Would it make the bass overwhelming, or muddy the rest of the sound?
Grenpa is offline
Reply Speakers
Monitor Audio
