Behringer Eurolive B215XL 15" 2-Way as L/R Mains - Page 81 - AVS Forum | Home Theater Discussions And Reviews
 1811Likes
post #2401 of 4174 Old 08-04-2015, 01:04 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2726
Originally Posted by pitviper33 View Post
This is tangential to the current discussion (at best), but you caught my eye with this mention. What are the dual inputs for on a passive speaker like this? Are you meant to wire 2 channels to a single speaker? If so, I wonder how the dual inputs are wired inside.
Great question !
I assume daisy chain 4 or two pair ? Idk. Just guessing.
It doesn't seem to matter which one you plug into. Result is the same. If you wanted to go active it would be easy to hardware the tweet and woof directly.
Mfusick is offline
post #2402 of 4174 Old 08-04-2015, 01:08 PM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 119
Great question !
Well if anybody pulls one open, I'd love to see how they're doing it. I'm struggling to come up with a way to combine 2 channels of amplified signal. But that's a topic for another thread.
pitviper33 is offline
post #2403 of 4174 Old 08-04-2015, 01:11 PM - Thread Starter
Mark Henninger
imagic's Avatar
Quoted: 9159 Post(s)
Liked: 16150
I posted pics of the crossovers some pages back.
Mark Henninger
Editor, AVS Forum
imagic is offline
post #2404 of 4174 Old 08-04-2015, 01:38 PM
Gary Lightfoot's Avatar
Quoted: 1302 Post(s)
Liked: 1054
AFAIK, the two speakons are in parallel so you can do as mfusic said which is daisy chain another speaker to the single, making a pair, and halving the impedance. If you wanted to use them to convert the speaker to active, you'd have to rewire them - disconnect them from each other and the crossover, then wire each one to one of the drivers, and mark up the rear panel to show which speakon goes to which driver.
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
post #2405 of 4174 Old 08-04-2015, 09:40 PM
hypez604's Avatar
Quoted: 112 Post(s)
Liked: 93
Just bought 3 x 215xl's on fleabay for $500, they getting delivered Thursday. Gonna install them in the mancave (1200sq ft brick wall 4-car garage) which currently has a 2.2 setup with some old kenwood mains and 2 x dayton 15 dvc subs. Gonna turn it into 5.2 with the kenwoods as surround speakers and berrys for LCR. I will post my opinion about the 215xl's a few days after I put them into use. For reference my main setup is a 2.2 with JBL 4722n LR and a pair of 12" peerless subs which will soon be replaced by a pair of B&C 21's
eng-399 likes this.
hypez604 is offline
post #2406 of 4174 Old 08-05-2015, 04:50 AM
DrDyna's Avatar
Quoted: 168 Post(s)
Liked: 150
If I was going to do something like that, I'd opt to swap one SpeakON for a 4 pole version, just to eliminate the possibility of forgetting which is which. My current speakers are active, and the 4 pole speakon is just plain easier.
Also, then if you were to accidentally plug the wrong one in, you'd only be connected to the woofer 1+/1- so you wouldn't have to worry about cooking the HF driver with lows.
Gary Lightfoot likes this.
DrDyna is offline
post #2407 of 4174 Old 08-05-2015, 05:28 AM
femi's Avatar
Quoted: 284 Post(s)
Liked: 322
Hi guys, I just purchase 5 B215XL. How do you connect them to AVR? On the back of the B215XL they are 4 connect connections. And there is a diagram above them indicating “All inputs parallel/speaker connectors: +1 pos/-1 Neg”.
I was planning on using regular speaker wire to connect them to my Denon 4520 for the pos and neg on the Denon. Then I was going to connect the pos and neg to Neutrik NL2FX Speakon Connector 2 http://www.amazon.com/gp/product/B00...ilpage_o00_s00 , then connect it to one of Speakon port on the B215XL show in the pic below(Professionl speaker inputs wired in parallel.)
I guess my real question is it okay that the pos and neg connected for the Denon should be going to one Speakon port on the B215XL?
femi is online now
post #2408 of 4174 Old 08-05-2015, 05:32 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2726
I used normal 14 guage speaker wire and just put a speakon terminal on the end of the wire on the Berry end. I used banana plugs for the AVR end, but bare wire works just fine too.
DrDyna likes this.
Mfusick is offline
post #2409 of 4174 Old 08-05-2015, 05:32 AM
corradizo's Avatar
Quoted: 1534 Post(s)
Liked: 1594
Yep. Either one is fine. The extra is for daisy chaining multiples. In the manual you should see a diagram showing connection options.
corradizo is offline
post #2410 of 4174 Old 08-05-2015, 07:17 AM
WayneJoy's Avatar
Quoted: 142 Post(s)
Liked: 105
I bought a 1/4 inch to 1/4 inch speaker cable and one of http://www.amazon.com/Hosa-BNP116BK-...to+banana+plug
WayneJoy is offline
post #2411 of 4174 Old 08-05-2015, 09:29 AM
hypez604's Avatar
Quoted: 112 Post(s)
Liked: 93
I would suggest those http://www.amazon.com/gp/product/B00LW8VLRU with some 12awg speaker wire.
hypez604 is offline
post #2412 of 4174 Old 08-05-2015, 10:09 AM
suresh6877's Avatar
Quoted: 14 Post(s)
Great ! will look forward for your impressions.
suresh6877 is offline
post #2413 of 4174 Old 08-05-2015, 11:16 AM
eng-399's Avatar
Quoted: 2428 Post(s)
Liked: 5004
Matt's going to open one up, measure and also maybe reverse engineer the crossover. I'm sure he's going post pictures once he gets that far.
Gary Lightfoot and Mfusick like this.
eng-399 is offline
post #2414 of 4174 Old 08-05-2015, 12:18 PM
mtg90's Avatar
Quoted: 782 Post(s)
Liked: 1609
All the measurements are done. On/off axis for the B212XL & B215XL. Crossovers reverse engineered. Individual driver measurements with/without the crossover. I'll provide crossover files for XSim with the stock crossover in place so anyone can go right in and start playing around with it (still have to create those files).
I'll post up the info soon. Some preliminary findings:
The CD used is not a titanium diaphragm as they say but either a poly or mylar one (diaphragm is a clear material). This is from the B212XL, I did not open the CD from the B215XL but it appears to be the same.
B212XL measures worse then the B215XL on axis.
Acoustic crossover points of both designs are ~1800-1900hz.
mtg90 is offline
post #2415 of 4174 Old 08-05-2015, 12:42 PM
eng-399's Avatar
Liked: 5004
Thanks for doing this Matt!!! Looking forward to seeing the measurements. Your Da man
Matt since you had the berrys for a few days if ya want to trade those for your Synergy Horns I would be ok with that.
Just kidding lol. haha
eng-399 is offline
post #2416 of 4174 Old 08-05-2015, 12:58 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2726
Interesting the 15" measures better on axis.
I look forward to your post.
Mfusick is offline
post #2417 of 4174 Old 08-05-2015, 03:38 PM
mtg90's Avatar
Quoted: 782 Post(s)
Liked: 1609
Post B215XL Measurements
The B215XL measurements, here we go.
On axis SPL & Phase @ 1m & 2.83v 4pi:
Distortion 2.83v 1m indoors:
Off Axis measurements, these are gated and with 1/6th octave smoothing to clean up hash and make it easier to differentiate between the curves, loss of resolution below 400hz or so. Taken at roughly 1.5 meters and level was lowered as not to blast neighbors with lots of loud sweeps.
Horizontal (0-90 degrees in 10 degree increments):
Normalized horizontal polar graph:
Vertical response (5 degree increments to 20 degrees, then 10 degree increments to 90)
Below axis:
Above Axis:
Crossover functions, normal, reversed polarity and individual driver response:
Files attached include crossover files zip for Bill Waslo's XSim and measured T/S specs of the woofer with DATS v2.
B212XL results and more pictures to come soon...
mtg90 is offline
post #2418 of 4174 Old 08-05-2015, 04:13 PM
eng-399's Avatar
Liked: 5004
Wow you really did a lot of measurements with these speakers thanks once again for the detailed post on these!
Matt what do you think can be done to make these sound better... Maybe better crossover parts... What do you think.
What do you guys think of the graphs???
eng-399 is offline
post #2419 of 4174 Old 08-05-2015, 08:15 PM
lefthandluke's Avatar
Quoted: 181 Post(s)
Liked: 334
mtg...
nice job brother...!
thanks for takin the time...
at the zenith of his nadir...
lefthandluke is offline
post #2420 of 4174 Old 08-05-2015, 08:20 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1358
Thanks for the measurements mtg90. I have a question, do you think the off-axis dip at around 1500 kHz is a consequence of the crossover? If so, what effect would lowering the crossover be? I am guessing it might help as some of the dip may be due to beaming with such a high crossover for a 15" woofer? I imagine breakup would be an issue as well. You know a hell of a lot more about speakers than I do, what is your assessment and where are areas for improvement for this speaker?
ahblaza likes this.
shadyJ is offline
post #2421 of 4174 Old 08-06-2015, 01:24 AM
hondakilla98's Avatar
Quoted: 25 Post(s)
I've had 3 B215XL's as my LCR for a couple weeks now. They are such an improvement over my Wharfedale Zaldek LCR(not surprising I know). I don't have any experience with high end home speakers(other than Bose). Most of my audio experience has been in cars. But these get loud, they are clean and I don't say "What did they say?" when I'm watching a movie anymore. The big matching center channel is great. I wish I'd upgraded sooner. They are crossed at 80hz and my ported sonosub takes care of everything under that. I bought mine from Amazon in the warehouse deals. I paid $475 shipped for all three, and they are one of the best bang for the buck upgrades I've done. And with my acoustic screen, I don't have to look at the ugly yellow triangle on the grill.
These things are big. It's not very often I look average size in a picture at 6'4", 300.
Here's one next to what it replaced.
hondakilla98 is offline
post #2422 of 4174 Old 08-06-2015, 05:08 AM
DrDyna's Avatar
Quoted: 168 Post(s)
Liked: 150
My kneejerk reaction is they valued high power handling and spl above DI, a reasonable thing for them to do, considering the goals. In a home setting, sacrificing some power handling to drop the crossover point a little bit might prove to be better.
Very nice set of measurements!
DrDyna is offline
post #2423 of 4174 Old 08-06-2015, 05:27 AM
lemonslush's Avatar
Quoted: 925 Post(s)
Liked: 455
If its firing right at your face its not so bad but, off axis es no Bueno.
lemonslush is offline
post #2424 of 4174 Old 08-06-2015, 06:00 AM
Archaea's Avatar
Quoted: 3868 Post(s)
Liked: 3678
Elaborate on at what point off axis you think it gets bad @lemonslush .
Archaea's 9.8.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is offline
post #2425 of 4174 Old 08-06-2015, 07:15 AM
tuxedocivic's Avatar
Quoted: 2301 Post(s)
Liked: 2229
You're on the money. Lower the XO to fix directivity and woofer breakup. Pretty nice results though.
tuxedocivic is offline
post #2426 of 4174 Old 08-06-2015, 07:16 AM
Liked: 2229
Certainly anything past 50* will have a hole in the midrange. Not so much about the direct sound as the reflected sound. They won't match very well.
post #2427 of 4174 Old 08-06-2015, 08:10 AM
Hifisound's Avatar
Quoted: 126 Post(s)
Liked: 32
I wonder why can't Behringer mould a SEOS like waveguide into the cabinet!
Hifisound is offline
post #2428 of 4174 Old 08-06-2015, 08:31 AM
Liked: 2229
Here's my shot at something people could try for probably under $10 if using an electrolytic cap on the woofer. Reuse the 2.25mH inductor, buy a couple resistors, a decent tweeter cap, and a lytic woofer cap. Probably prudent to buy a few extra resistors like 2, 2.2, 2.4, 2.6, 2.8ohm to try in the R4 position. They're cheap, so why not. Maybe someone will try this. Interested to see what other people come up with though.
Note that the tweeter polarity is reversed, which is what Matt had shown on the stock XO, so just hook it up as it was so to speak.
An expensive XO could be worked up, but passive parts can get very expensive, like $70 per speaker, and without listening to the results you are spending a lot of money on something unproven. Maybe Matt will come up with something nicer. The native frequency responses aren't very kind to XO design. A bit lumpy.
mesasone, ahblaza, shadyJ and 1 others like this.
post #2429 of 4174 Old 08-06-2015, 08:35 AM
Liked: 2229
The SEOS doesn't have much acoustic gain (horn loading). It doesn't make a very good PA device, which would probably get cut from a speaker like this in the planning stages.
mesasone and Hifisound like this.
post #2430 of 4174 Old 08-06-2015, 09:28 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2726
Wait you mean I was right all along ? No way... That can't be true...
Mfusick is offline
Reply Speakers
Behringer B215xl Passive Speaker Pair , Pioneer Elite Sc 55 Sc55 9 1 Channel 3d Ready A V Receiver , Pioneer Andrew Jones Sp Fs52 Flr Stand Loudspeaker , Behringer , B 52 Lx 1515v3 1000w Dual 15 Pa Speaker , B 52 , Behringer Eurolive B212d Active 550 Watt 2 Way Pa Speaker System With 12 Inch Woofer And 1 35 Inch C
