Newbie help please! Energy take classics in a 16x18 room? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 82 Old 03-02-2014, 12:23 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4802
I usually check Amazon prime first since I've already paid for shipping that way. I just look around for a good deal at the time. Monoprice can be good but there are other sources including your local Lowe's or Home Depot. Surrounds don't need a lot nor need to be matched so even a lightweight pair of speakers can do well as surrounds, I usually use whatever speaker has been pushed aside by bigger/newer speakers (I have 7.3 in living room, 5.1 in bedroom, 3.1 in garage and am setting up two more rooms soon smile.gif. Two of my Take Classics are used as surrounds in my bedroom. A good cheap speaker like this might be an idea http://www.parts-express.com/dayton-audio-b652-6-1-2-2-way-bookshelf-speaker-pair--300-652
lovinthehd is offline
post #32 of 82 Old 03-02-2014, 01:22 PM - Thread Starter
Gpc777's Avatar
Thanks again guys. So just to be sure about this, I'm gonna hook the Denon up to all of the speakers I have, and via Audyssey it's just gonna figure out the best setup for the speakers I have, right? As far as how to set the front speakers crossover, 80-120hz or whatever, and how the sub should be set, etc?
Gpc777 is offline
post #33 of 82 Old 03-03-2014, 07:24 AM
crazyrob425's Avatar
Quoted: 451 Post(s)
Liked: 343
After you hook of the speakers and run Audyssey it should set the speakers up correctly. An 80hz crossover would be good for the BS-22-LR and matching center channel.
If you have any questions after you run audyssey feel free to post back here what settings Audyssey set for your speakers and we might be able to help from here
crazyrob425 is offline
post #34 of 82 Old 03-03-2014, 07:56 AM - Thread Starter
Gpc777's Avatar
Thanks again. Ordered everything yesterday, including an extra set of the BS-22-LR's for my surrounds. Should be the best system/setup/sound I've ever had for sure. Peace.
Gpc777 is offline
post #35 of 82 Old 03-03-2014, 09:03 AM
Sting5920's Avatar
Originally Posted by Transmaniacon View Post
With the rest, I would recommend the Pioneer Andrew Jones speakers, you can listen to them at Best Buy, but they are regarded as one of the best budget speakers out there. I would start with a 2.1 set, and add a center and surrounds later on. You can get a pair of the towers for $250, and then add a NXG BAS 500 sub to give you a great starting point.
May I please also ask a newbie question on this
Is there a great disadvantage to hiding all this BLACK of speakers standing in the room with say a thin fabric of light colored cloth  - like a pillow case for a tower speaker ??
Thank-you in advance!
HDTV: LG 47LA7400
Blu-Ray Player: BP530 3D Surround
Keyboard: Logitech K400R
OTA only - Antenna: Ebay junk - [works great]
AV Receiver: Denon AVR 1713 5.1 3D
Center Speaker: Cambridge Audio S50
Front Left Right: Cambridge Audio S70
Surround: Acoustimass® 5 Series II system
Sub-woofer:  Yamaha
Sting5920 is offline
post #36 of 82 Old 03-03-2014, 09:08 AM
Transmaniacon's Avatar
Quoted: 1788 Post(s)
Liked: 1629
I would just buy nicer looking speakers instead... There are plenty with nice wood veneers or gloss finishes.
5.1: Samsung PN60F5300 | Sony BDP-S1700 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
2.0: Oppo DV-980H | Apple Airport Express | Topping D30 | Parasound HCA-1500a | Chane A1.4
Transmaniacon is offline
post #37 of 82 Old 03-03-2014, 09:13 AM
Sting5920's Avatar
I guess that's my problem - I never bought nice speakers so I don't know what to substitute
looking for a lighter color but not wood.
HDTV: LG 47LA7400
Sub-woofer:  Yamaha
post #38 of 82 Old 03-03-2014, 09:14 AM
Liked: 1629
There are a good number of speakers in a gloss white finish, I don't think you will find many colors between white and black.
post #39 of 82 Old 03-03-2014, 09:16 AM
Sting5920's Avatar
Will a wired sub perform as well as a wireless  sub? Will the audio cable to this sub affect the signal?
HDTV: LG 47LA7400
Sub-woofer:  Yamaha
post #40 of 82 Old 03-03-2014, 09:19 AM
Liked: 1629
There are many wireless sub kits available, Rocketfish makes one and I believe Outlaw does as well. I would rather stick with a wired connection because there is some delay with the wireless signal, but Outlaw makes very good subs so I would wager if it's good enough for them it should be for most people.
Sting5920 likes this.
post #41 of 82 Old 03-03-2014, 09:31 AM
Sting5920's Avatar
I guess I will need to get out a can of spray paint LOL
HDTV: LG 47LA7400
Sub-woofer:  Yamaha
post #42 of 82 Old 03-03-2014, 09:43 AM
Liked: 1629
What color are you looking for?
post #43 of 82 Old 03-03-2014, 11:16 AM
Sting5920's Avatar
If I had my druthers = ivory
but something white or off white would be more acceptable than black or dark grey
HDTV: LG 47LA7400
Sub-woofer:  Yamaha
post #44 of 82 Old 03-03-2014, 11:25 AM
Liked: 1629
http://www.nhthifi.com/Absolute-Zero-White?sc=12&category=3772#image-3
NHT makes some white speakers.
post #45 of 82 Old 03-03-2014, 11:29 AM
Sting5920's Avatar
Wow - Those are nice - but I had my heart set on floor standing towers
Come to think of it - I don't know why but I thought that's what I wanted
Maybe the sock idea isn't too far out into left field - maybe not as far a paint???
HDTV: LG 47LA7400
Sub-woofer:  Yamaha
post #46 of 82 Old 03-03-2014, 11:42 AM
zieglj01's Avatar
Quoted: 3351 Post(s)
Liked: 3248
I will take the MB Quart Alexxa B 1 - over some budget friendly towers
http://shop.mbquart.com/p/as-b1pw-pair?pp=24
Who AM I
zieglj01 is offline
post #47 of 82 Old 03-03-2014, 11:49 AM
Sting5920's Avatar
That would work if I built something [ stable enough ] to raise them up
is it "safe" to leave the black screens off?
HDTV: LG 47LA7400
Sub-woofer:  Yamaha
post #48 of 82 Old 03-03-2014, 11:58 AM
Liked: 1629
You can buy speaker stands at various heights, and many of them allow you to fill the tubes with some kind of weighted material like sand, to help anchor the stands and increase speaker decoupling. You can definitely leave the screens off, they aren't supposed to affect the sound one way or another, and many people like to see the drivers.
post #49 of 82 Old 03-03-2014, 01:28 PM
Sting5920's Avatar
Ill have to go back to the threads and see now if I can find guidance away from tower speakers and look at things to put on tube stands.
Thank-you for showing the way!
HDTV: LG 47LA7400
Sub-woofer:  Yamaha
post #50 of 82 Old 03-03-2014, 03:12 PM
lovinthehd's Avatar
Liked: 4802
Some DIY stand ideas here https://www.avsforum.com/t/1165749/ultra-cheap-diy-speaker-stands-with-lots-of-pics
I take it you don't have curious fingers in your household? Seems when I was 4 I still managed to mangle one of my dad's speakers, though smile.gif
post #51 of 82 Old 03-03-2014, 04:02 PM
ScooterMcTavish's Avatar
Quoted: 16 Post(s)
Liked: 33
Also, depending on your level of enterprise, you can buy different color grille cloth for speakers on eBay. I was actually thinking of changing mine from black to silver to match a unit, then changed my mind when my wife replaced the unit.
http://www.ebay.com/itm/GC3BK-SPEAKER-GRILL-CLOTH-BLACK-66-X-36-16-5-SQUARE-FEET-/131106955349
Trust me, you'll be happy you have the grilles on at least once.
And fingers find their way in, even if they're not your kids. I've had to pull out a few dustcaps because my wife was visiting with a friend, and their little monster pushed some in. My kids were trained early to "respect the gear".
Music: Musical Fidelity A3.2, Soliloquy 6.2, CEC/White (original AT-10 cartridge) Turntable, H/K CD
HT: Marantz SR5009, Wharfedale Diamond 10.6, Mirage Surrounds, AR MC1 Center, PS3, JVC Jukebox
ScooterMcTavish is offline
post #52 of 82 Old 03-03-2014, 08:10 PM
RayGuy's Avatar
Quoted: 3098 Post(s)
Liked: 2891
Not sure as far as the sub. Transmaniacon had suggested the NXG Technology NX-BAS-500 12" 500-watt Powered Subwoofer for $250, but if the Dayton sub-1200 is close to the same quality for $110, that would be an awesome money savings. Also, how are the pioneer SP-BS22-LR speakers compared to the 52-LR speakers mentioned above? If paired with a nice sub, wouldn't they still blow away the old Onkyo speakers I'm used to? Sorry, just trying to save some money here. Maybe use the 22-LR's with a sub and the matching SP-C22 center channel at first, then buy the 52-LR's at some point, and move the 22-LR's to the back for my surround speakers? What do you guys think? Thanks again!
Get the better sub and the bookshelf Pioneers.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #53 of 82 Old 03-03-2014, 09:54 PM - Thread Starter
Gpc777's Avatar
Yeah Rayguy that's what I did. I'm pumped! Peace.
Gpc777 is offline
post #54 of 82 Old 03-04-2014, 11:52 AM
Sting5920's Avatar
Today I ordered the two tower and the center speakers. Yesterday I ordered the receiver. I have a small powered sub that I would like to use just to get going. I am sure I will want better and still want  to add the two surround units - but I have already spent more on this little hobby than I have on all the AV equipment I have purchased life-2-date LOL
Thank - you to everyone posting in these threads
Kind Regards
Sting
HDTV: LG 47LA7400
Sub-woofer:  Yamaha
post #55 of 82 Old 03-06-2014, 06:20 AM
Busterbvi's Avatar
I'm setting up a new 5.1 surround system in a 16x18 room. I think I've decided on the Denon AVR-E300 receiver, and I'm wondering if the Energy take classics would be a good match for said room size and receiver? My budget for both receiver and speakers is no more than $700. Thanks for your wisdom in advance. Any suggestions would be appreciated as well. My former experience with home theater has been Onkyo HTIB systems. Seemed fairly decent to me, so I'm just wanting to possibly step up a little in quality if possible with the budget mentioned. Thanks again guys!
Just found this thread. I have Energy Take Classics 5.1 connected to a Yamaha RX-V673 in a similar sized room. The sound is awesome, at half volume the sound just blows you away, very happy with these speakers. Watched Dave Gilmour live at the Albert hall on Blue Ray last night and the neighbours down the road complained !!  Highly recommend these speakers, they pack a lot of punch for their small size.
HTPC. Yamaha RX-V673 AVR. Yamaha BD-S 673 BR/DVD. Energy Take Classis 5.1. Ben-Q W1070 Projector. 100" Screen. Four Lazy Boyz.    One serving wench.  Lap dancing facilities.
Busterbvi is offline
post #56 of 82 Old 03-06-2014, 08:50 AM
asssets's Avatar
Will Pioneer speakers good match for Onkyo HT-RC270, I have 19x11 room. This is my first system. I was happy when I got logitech z623, LOL.
asssets is offline
post #57 of 82 Old 03-06-2014, 09:12 AM - Thread Starter
Gpc777's Avatar
Thanks Busterbvi. Wish I would have known this a week ago. Ha. Could have saved me some cash! Already ordered the Pioneers and NXG sub. But if I'm not happy with that stuff, or feel that it's more than I need, I'll consider the Energy speakers again. I know my wife would prefer those for sure due to their small size. Peace.
Gpc777 is offline
post #58 of 82 Old 03-06-2014, 01:52 PM
lovinthehd's Avatar
Liked: 4802
Can't wait for your reaction when you get even better speakers!
post #59 of 82 Old 03-06-2014, 04:11 PM - Thread Starter
Gpc777's Avatar
Yeah I'll definitely post my impressions. Probably won't even get the sub delivered until Tuesday according to the tracking info. Eventually though.
Gpc777 is offline
post #60 of 82 Old 03-06-2014, 10:38 PM
lovinthehd's Avatar
Liked: 4802
Reply Speakers
Denon Avr E300 , Energy Take Classic 5 Pack 5 0 Home Theater Speaker Black , Pioneer Andrew Jones Sp C22 Center Channel Speaker , Dayton Audio Sub 1200 12 120 Watt Powered Subwoofer , Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr
