MartinLogan Motion Owners Thread - Page 42 - AVS Forum | Home Theater Discussions And Reviews
 305Likes
post #1231 of 1244 Old 10-30-2019, 08:37 AM
gajCA's Avatar
Quoted: 9267 Post(s)
Liked: 6373
Originally Posted by canadian411 View Post
Should I leave both Front and Surround speakers Small ?
If you are using a subwoofer then yes.
Geoff A. J., California
gajCA is offline
post #1232 of 1244 Old 10-31-2019, 04:12 AM
Quoted: 82 Post(s)
Liked: 9
Thanks !
gajCA likes this.
KEF R900 (coming), Martin Logan Motion 40, 50XT, 15s, LX16. Dual SVS SB13. Dual PSA 3611s (coming)
Marantz SR5009, Yamaha A-S2100, MX-A5000, OPPO HA-1, Burson HD-160
Headphone : HD800 / Fostex TH900 mk1 / TH610 / Beyerdynamic T5p.2 / HE6 / LCD 2.2 / Denon AH-D7100/AH-D600
canadian411 is offline
post #1233 of 1244 Old 11-04-2019, 04:18 AM
Quoted: 82 Post(s)
Liked: 9
Sorry in advance if this question was asked before.
How I mount the Motion 15 or 35XT on the stand ? both speakers doesn't have holes on the bottom.
post #1234 of 1244 Old 11-04-2019, 06:31 AM
Craig Peer's Avatar
Quoted: 7114 Post(s)
Liked: 8466
I used “ Earthquake Putty “ and mine haven’t moved in over 6 years !
canadian411 likes this.
[email protected] JVC RS4500, Lumagen Radiance Pro, Panamorph Paladin DCR lens, Stewart Luxus Model A ElectriScreens - 128" diagonal 2.35:1 ST130 & 122" diagonal 16:9 Cima Neve, Denon X8500, Parasound A 52+ amp, Martin Logan Motion series 9.4 speakers, four SVS subs, Panasonic UB820, Oppo 203, PFP M1500 UPS
Craig Peer is offline
post #1235 of 1244 Old 11-04-2019, 07:08 AM
Quoted: 82 Post(s)
Liked: 9
Thanks !
post #1236 of 1244 Old 11-04-2019, 07:54 AM
Craig Peer's Avatar
Liked: 8466
The stuff really works ( LX16's on a Sanus Steel stand ) -
Name:	Martin Logan Motion 40 and Motion LX16 speakers.JPG
ID:	2636284   Click image for larger version
Name:	Martin Logan Motion 40 and LX16.JPG
post #1237 of 1244 Old 11-05-2019, 03:54 AM
Quoted: 82 Post(s)
Liked: 9
Hi Craig,
Is that 30 in tall stand ?
Thanks !
post #1238 of 1244 Old 11-05-2019, 09:04 AM
Craig Peer's Avatar
Liked: 8466
Hi Craig,
Thanks !
It is - https://www.sanus.com/en_US/products...r-stands/sf30/
post #1239 of 1244 Old 11-05-2019, 06:16 PM
Quoted: 33 Post(s)
Liked: 9
Interesting.
Their measured frequency response tells a completely different story.
Top chart is frequency response for the 35xt, below it is the Motion 40.
https://www.soundstagenetwork.com/in...=16&Itemid=140
Any chance Martin Logan had repaired their lumpy frequency response in the new Motion 40i? I doubt it. Looks like mostly cosmetic changes, for hundreds of dollars more. It's possible to repair the FR problems with an EQ, but I wonder how good the crossover is, as well, between bass and midrange, despite bold "Vojtko" crossover design claims. Sure enough, the low point is right at 500 Hz.
The 60XT had problems of its own, as described by Brent Butterworth in 2015: this heavy speaker's resonant frequency is high enough that it ends up muddying vocals if you don't use a sub with it. The AMT crossed over just above 2000 Hz sounds super, however, and you can't do that with a ribbon. Again though, I would expect the speaker's low frequency problems to carry over into the new model.
Overall, I now see Martin Logan as a marketing driven company, and probably won't be buying any of their products.
dan3952 is offline
post #1240 of 1244 Old 11-06-2019, 08:38 AM
Craig Peer's Avatar
Liked: 8466
Well, for my use ( home theater ) the Motion 40's sound very good in my theater, dip at 500HZ or no. And I do use a subwoofer - 4 in fact !
post #1241 of 1244 Old 11-06-2019, 09:19 AM
gajCA's Avatar
Liked: 6373
IDK, their new subwoofers are very well engineered with good price/value and no need to buy a tower when the 35XT measures so well.
My LX16s, (same as the Motion 15s), don't measure particularly well but sound great even in 2.0.
I'd been running mine in 2.2 with good success but my friends will be running them 2.0 using my old resurrected Sansui 881 receiver from the 70s and darned if that combination didn't sparkle in 2.0 with a bit of tweaking on the Sansui's bass and midrange controls.
The fact that their LX16s look stunning in the Cherrywood finish is a bonus.
Far better looking than mine in gloss black.
gajCA is offline
post #1242 of 1244 Old 11-07-2019, 05:21 AM
Quoted: 82 Post(s)
Liked: 9
If their new "i" serie is just for the cosmetic change I am one lucky guy !
I was able to get the brand new 15s and 35XTs for $379 USD (pair) and $606 USD (pair) respectively.
post #1243 of 1244 Old 11-09-2019, 06:39 AM
Quoted: 33 Post(s)
Liked: 9
I might look at the 35XT again.
Incidentally, I just saw the old Motion 40 on the floor as an open box special for $409 each at a DFW Best Buy. I had studied the old and the new boxes carefully and had come to the same conclusion as before.
dan3952 is offline
post #1244 of 1244 Old 11-12-2019, 04:26 AM
Quoted: 82 Post(s)
Liked: 9
Sure ! let me know what you think
Reply Speakers
