Best in ceiling speakers for Atmos? - Page 42 - AVS Forum | Home Theater Discussions And Reviews
 856Likes
post #1231 of 2987 Old 02-28-2016, 08:45 PM
bombertodd's Avatar
Quoted: 224 Post(s)
Liked: 138
For those in SoCal, Monaco in Pasadena has a bunch of the KEF products. Including some in ceiling speakers in their demo room. They sure sounded good to my ears.
hatlesschimp likes this.
Klipsch RF-82II, RC-62II
2x Dayton Ultimax 12, Behringer iNUKE3000DSP
Denon 2113ci
New Theater Under Construction
bombertodd is offline
post #1232 of 2987 Old 02-28-2016, 10:14 PM
R8der's Avatar
Quoted: 78 Post(s)
Liked: 41
Originally Posted by PrestigeAudio View Post
Don't angle them. They are engineered to be flush to the ceiling for best performance. They are flush, but KEF's Uni-Q driver gives incredible dispersion. That speaker is THX Ultra2 certified, mounted flush/flat in the ceiling... even for LCR use!
The perfect box would have .71 cubic feet or larger. I say "or larger" because after .71 cubic feet the box becomes invisible to the speaker and does not matter in terms of sound quality or performance.
Tomorrow, I can attach KEF's sheet they sent to me as a dealer showing minimum & maximum boxes for best performance in their architectural speakers. A KEF engineer is the one who noted the "or larger" to me, so that is accurate. Basically, as long as you don't have the speaker mounted up in a tiny space, you are good to go.
So if I have them mounted in the ceiling with an attic above do you see a benefit to adding a backer box? I'm open to experimentation. However, they already sound great without backer boxes!
Marantz AV8802A, Sunfire Signature Grand (425W x 5), Sunfire TGA-7201 (200W x 7), Oppo UDP-203, Vizio P-75, Phase Technology PC8.5 (FL, FR, SL, SR), Phase Technology PC-Center, Phase Technology PC-60 (RSL, RSR), KEF Ci200rr (FHR, FHL, RHR, RHL), Epik Tower Sub
R8der is offline
post #1233 of 2987 Old 02-29-2016, 04:16 AM
Quoted: 298 Post(s)
Liked: 184
Nope! No sonic benefit at all. Open attic space is much larger than .71 cubic feet so you are good to go.
If there are other concerns: Debris getting in them, weather (incredibly cold or incredibly hot, etc. etc.) then a back box might help with that. But as long as the box is larger than .71 cubic feet there is no performance benefit.
PrestigeAudio is online now
post #1234 of 2987 Old 02-29-2016, 11:31 AM
Carbo's Avatar
Quoted: 291 Post(s)
Liked: 158
Just installed RSL C34E's this weekend. I only did two for now. I didn't want to open four holes till I knew I liked them and they matched well with my Wharfedale JADES.
I can now say these are great speakers and anyone looking at them should not hesitate.
Very easy Install and they match well with my Speakers. Even hooked up in stereo they can hold their own and have a nice sound when matched with a sub. Audyssey crossed them over at 120 and that sounds about right, maybe you could drop them to 100, but I see no reason. I tried them with a Marrants AV7702mkii and I also have a Yamaha 5100 on hand I'm going to try them with(still trying to decide between which receiver). The Main speakers ran through a Outlaw 7900 Amp and the Atmos are running through my older Integra DTA-70.1 Amp(which gives me plenty of room to add more Atmos down the road).
I'm not sure how they would compare to the Mica's or the KEF's(The only KEF's I have heard are LS50's and while they sound great, even if the in-ceilings sound similar, I see no reason to spend that kind of money for ATMOS in ceilings, unless you already have KEF"s, when the RSL's sound this good), But for someone looking to spend somewhere in the middle, these RSL C34E's are great at $125 each. I was waffling between getting either Wharfedales in-ceiling speakers for the same price(but they looked like a old design and were not edgeless or KEF's for double to triple the price. I'm glad I went with the RSL.
Carbo is offline
post #1235 of 2987 Old 02-29-2016, 11:49 AM
Quoted: 1007 Post(s)
Liked: 801
How wide are the dual drivers and are they powerful enough if u crank it?
Primary set-up 5.1.4; Yamaha A2050, Paired w/Parasound P5 & ATI 500NC 2 channel amp
Revel F206 fronts & Revel M16 rears; Outlaw X12 Sub & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polk LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
yanks1 is offline
post #1236 of 2987 Old 02-29-2016, 03:08 PM
Jahjd2000's Avatar
Quoted: 50 Post(s)
Liked: 81
Glad you like the RSLs! I agree with everything you said. I'm very happy with the RSLs. For Atmos duty they do extremely well and they are only $125 each to boot.
Dolby Atmos 5.1.4
Denon x6200
Ascend Acoustics Towers and Horizon Center (NrT)
RSL 34CE in-ceilings (4)
Rythmik E15HP
Jahjd2000 is offline
post #1237 of 2987 Old 02-29-2016, 03:33 PM
quamosa's Avatar
Quoted: 100 Post(s)
Liked: 79
If anyone is still interested in Micca speakers at this point , and are looking for similar specs in angled versions, 6.5" inch, frameless, and square or round grills it looks like Russound's RS series Mica speakers might fit the bill. Well at 3 times the bill but might be worth a look.
My First Build Ever in progress
quamosa is offline
post #1238 of 2987 Old 02-29-2016, 04:12 PM
Carbo's Avatar
Quoted: 291 Post(s)
Liked: 158
They can hold their own against the Jades. The Jades crank and are very detailed. It's one of the best speakers I have heard. The RSL kept up with no problem no matter how much I cranked it up. They excellent speakers.
I'm no expert on ATMOS, but I think what you want is a wide dispersion and allot of detail in the mid and high frequencies. I'm not sure any in-ceiling is going to give great lows and I don't think you should be looking for that. I watched a couple of Atmos movies and RSL really shined. They play loud with no problem and are very detailed. The dispersion is great also. Even though the dual drivers are angled, if stand in front of them they still disperse in that direction a good distance. Far more than you would sit.
I'm not sure what you mean by how wide? They are 4 1/2 inches. They are separated by about 1/2 inch(with my eye). Hopefully this answers your question.
I have no complaints, they are worth every penny and I have already ordered two more.
Carbo is offline
post #1239 of 2987 Old 02-29-2016, 04:30 PM
healthnut's Avatar
Quoted: 922 Post(s)
Liked: 908
Appreciate the review. I would have been surprised if you hadn't liked them. They're one of the few ceiling speakers designed specifically for Atmos, and RSL is a reputable company. I would expect them to be a nice upgrade from the Micca's.
healthnut is online now
post #1240 of 2987 Old 02-29-2016, 05:15 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 983
I wouldn't completely agree.............
I use an angle of 10 degrees which is fine for all intent and purposes...............................geometry is what it is. You can angle baffle to some degree, but design of speaker was meant to be set at 0 degrees...............................
doublewing11 is offline
post #1241 of 2987 Old 02-29-2016, 05:25 PM
Quoted: 229 Post(s)
Liked: 983
The only reason for backer boxes is to contain sound to other rooms or in my case, I have my four Kef's in a sealed, soundproofed room. I didn't cut holes into the dampen, soundproofed ceiling...........rather I attached directly to ceiling backer boxes inside room to alleviate the back wave near ceiling boundary. If you are ok hearing sound 70 ft away in another room, then you should be fine as these speakers were designed as infinite baffle. Backer boxes have their application...................if you don't plan on building backer boxes and are fine with your sound containment situation, no reason to build backer boxes.
post #1242 of 2987 Old 02-29-2016, 05:37 PM
Liked: 801
Carbo; thx a lot for response. Sounds like I may buy these, but I'm also looking at the Micca & Yamaha 8" speakers on sale at AC4L.com for $119 I think.
Tough choice.. Hmmm
yanks1 is offline
post #1243 of 2987 Old 02-29-2016, 07:54 PM
darrellh44's Avatar
Quoted: 1035 Post(s)
Liked: 500
Does anyone have dispersion numbers/graphs on the RSL and KEF ceiling speakers? I haven't been able to find any.
darrellh44 is online now
post #1244 of 2987 Old 03-01-2016, 06:33 AM
Carbo's Avatar
Quoted: 291 Post(s)
Liked: 158
Here is the RSL:
Carbo is offline
post #1245 of 2987 Old 03-01-2016, 06:35 AM
Carbo's Avatar
Quoted: 291 Post(s)
Liked: 158
Yanks; Good luck. It's tough picking Atmos speakers. We need a Master Thread with speakers people have tried.
hatlesschimp, yanks1 and pmeintel like this.
Carbo is offline
post #1246 of 2987 Old 03-01-2016, 09:09 AM
ChldsPlay's Avatar
Quoted: 1115 Post(s)
Liked: 630
Here is the RSL:
I have no idea how to read this as far as dispersion goes. I get the directivity that is being shown, but I don't know about dispersion. That could be a 20 degree cone or 120 degree as far as I can tell.
The Hodor Theater - Now with Atmos
Projector - JVC D-ILA NX7/Panasonic PT-AE8000U; Receiver - Yamaha Adventage A3050
LCR speakers - JTR Noesis 228 HT (3); Surr./Back - Klipsch Pro Cinema KPT-8000M (4)
Atmos In-ceiling - Niles DS8HD (4); Subs - Passive JTR Captivator Pro (2)
ChldsPlay is offline
post #1247 of 2987 Old 03-01-2016, 09:22 AM
Carbo's Avatar
Quoted: 291 Post(s)
Liked: 158
If the speaker is the center of the graph, those are db and freq in each direction. Top being the front of the speaker. The RSL is angled/aimed.
Carbo is offline
post #1248 of 2987 Old 03-01-2016, 09:25 AM
ChldsPlay's Avatar
Liked: 630
At what distance?
post #1249 of 2987 Old 03-01-2016, 09:36 AM
Carbo's Avatar
Quoted: 291 Post(s)
Liked: 158
It depends what db your playing at. The distance changes.
Carbo is offline
post #1250 of 2987 Old 03-01-2016, 10:02 AM
bombertodd's Avatar
Quoted: 224 Post(s)
Liked: 138
That type of graph doesn't show the whole picture. Off axis response plots are a much better indicator.
Denon 2113ci
post #1251 of 2987 Old 03-01-2016, 11:27 AM
Liked: 2
hi....i am installing a 7.1.4 home theater....for both dolby atmos and dts x......and was looking at lots of different ceiling speakers.....but i think i am going to install 4 of these speakers ( rsl c34e in ceiling speakers)but i cant seem to find anywhere who sells them.....im in ireland...any advice and help would be great guys
rayh271 is offline
post #1252 of 2987 Old 03-01-2016, 12:30 PM
healthnut's Avatar
Quoted: 922 Post(s)
Liked: 908
I believe you order direct from RSL. You'd need to find out if they ship overseas. Best of luck!
post #1253 of 2987 Old 03-02-2016, 03:12 AM
dmercer3's Avatar
Quoted: 788 Post(s)
Liked: 420
couple months into having my klipsch 5800's (4 total). I am interested in the angle debate going as I pretty much maxed the angle of the woofer (90%) to point them directly at the MLP. I then slightly angled the tweeter (15%) towards the MLP as well.
I wonder if I am 'supposed' to not angle them and just rely on dispersion?
I will add at $400 per on these things, I probably should have spent less, hearing the success here of much cheaper options.
Video: 75X940E/60E8000 Plasma (Formerly; 78JS9500/58c8000/75hu8550/78ju7500) BD Player: OPPO UDP-203
Audio: Marantz 7010 / SVS PB-13 Ultra / Klipsch RF-7ii RC-64ii Polk M70's IC-5800 (5.1.4)
dmercer3 is offline
post #1254 of 2987 Old 03-02-2016, 06:35 AM
vitod's Avatar
Quoted: 287 Post(s)
Liked: 165
For Atmos, IC speakers are for effects. They're not the mains. That's why I chose the Micca. Based on a ton of positive reviews and member usage, it made for an easy choice. If they didn't sound that good, no biggie. I'd upgrade. But man, you spent $1600! You should've been blown away! But first, try the non angled position. I really hope it works.
Panasonic AE-8000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
post #1255 of 2987 Old 03-02-2016, 06:51 AM
dmercer3's Avatar
Quoted: 788 Post(s)
Liked: 420
what do you mean they are not the mains?
My marantz set them up at upper front left and right and upper rear left and right, I still have a LCR and Rear surround, all togethor is a 5.1.4 configuration identified by my marantz as the proper Atmos setup.
Are you saying if you put the upfiring speakers rather than in ceilings and then config the amps appropriately you will get 'more' information for atmos?
sounds a bit crazy.
To my point, if that were the case the dolby atmos demos would not sound good at all.. right?
dmercer3 is offline
post #1256 of 2987 Old 03-02-2016, 07:05 AM
vitod's Avatar
Quoted: 287 Post(s)
Liked: 165
You talked about dispersion and that you angled the speakers. I said to adjust the IC to regular position and see if dispersion works better.
vitod is offline
post #1257 of 2987 Old 03-02-2016, 07:31 AM
Quoted: 298 Post(s)
Liked: 184
As a former Klipsch dealer I can offer my opinion having worked a fair amount with the line. Their basic in-ceilings and in-walls tend to overlap and blend between each other in terms of discernible quality. I really did not see large performance or technical differences between the price jumps when comparing a model up or down within the same size series.
To clarify: I found only a slight differences between the 5800 and the 3800, and a slight difference between the 2800 and the 1800.
That is not to say there wasn't obvious difference between the entry level 1800 or 2800 and the 5800 or 3800 - because there is, but within a series of each other the differences were subtle depending on what the application is. For ATMOS, I could see the 3800 or 5800 being a cleaner sound than the models below them either of them. They would also offer better low end performance or power handling without breaking up if you listen loud. But the 3800 & 5800 would kind of be splitting hairs between the two.
Even though there are tonal and output differences between the models, they all present sound in the traditional Island dome in front of a woofer way. I could see the MICCA speaker and the 2800 model Klipsch being very similar.
sounds a bit crazy.
I can't speak for the guy you quoted, but most people refer to "MAINS" as the front Left, Center, & Right.
In a perfect world all of the speakers in a multi-channel audio system would be voice matched identically or of the same series depending on size requirements or desired dispersion. Some guys do not adhere to this ideal and mix and match between the front "MAINS" and all of the surrounds.
To relate that back to your angling questions: High frequencies are much more directional than the low ones. The 8" woofer cone also radiates in a much bigger pattern to start spreading out into the room than the small 1" tweeter. Angling them is always up to the room and seating positions. Maybe if someone couldn't get them close enough over head or in the optimal position, etc etc. it might make sense to angle them more extremely than just the tweeter or the typical 15 degrees.
post #1258 of 2987 Old 03-02-2016, 08:04 AM
aKa DaShiznit's Avatar
Quoted: 448 Post(s)
Liked: 281
I'm having great success and very happy with my Speakercraft aim5 two series 2 that I grabbed off amazon from an authorized dealer for $90 each. I gladly ordered them cause I was impressed with the aim5 one speakers I heard in magnolia at $150 each.
I really wanted the aim5 three series 2 to try to match the same make as my energies cone and tweeter materials but the twos are doing just fine after audyssey xt32 and if they weren't being clearanced out by that specific dealer I would of got the threes that were also a great price but were double what I got the twos for.
I just used the treble booster on them to better match the brighter sound of the energies and I am very happy.
Sony XBR-65X930E (w/luminoodle)/Sony UBP-X700/Apple TV 4K/PS4 Pro/Xbox One X
Denon AVR-X6200W(Surround/Height)/Emotiva XPA-3(L/C/R)/AC Infinity Aircom T8 x2
DefTech SM 65 x3(L/C/R)/DefTech PM 1000 x4(Surround)/DefTech DI5.5R x4(Atmos/DTS X)
SVS PC-2000 x2(Subs)/Panamax M4300-PM(Main) & MD2(Subs)/Logitech Harmony Elite
aKa DaShiznit is offline
post #1259 of 2987 Old 03-02-2016, 08:17 AM
korkster's Avatar
Quoted: 56 Post(s)
Liked: 25
Thanks for posting your thoughts. I was looking forward to this since I knew you were doing the install over the weekend. Sounds like you're very happy, and I'm not surprised. I'll probably be going the same route.
Now I'm looking forward to your thoughts related to the comparison of the Yamaha vs the Marantz. Will you be posting that somewhere? I'm going down that same road as well.
korkster is offline
post #1260 of 2987 Old 03-02-2016, 08:22 AM
vitod's Avatar
Quoted: 287 Post(s)
Liked: 165
Now, I can take your observation more seriously. I know you haven't heard the Micca, but at least you can see the similarities between the 2800 and the Micca in design. Tonal differences, I'm sure. And that was my point from the get go. The Micca costs way less than the 2800.
Micca-$40
2800- $150-$200
vitod is offline
Reply Speakers
atmos , ceiling speakers
