Official Power Sound Audio Speaker Thread - Page 175 - AVS Forum | Home Theater Discussions And Reviews
 9341Likes
post #5221 of 8803 Old 07-13-2016, 02:40 PM
tang7969's Avatar
Quoted: 309 Post(s)
Liked: 212
Originally Posted by Hopinater View Post
Come on Tang don't leave us hanging like that. Are the 210T's growing on you or what's the story?
Yes they are!!! I think you said the mid bass was better,It definitely is better. I also like the look of tower speakers. They make quite the statement
Originally Posted by Brian Fineberg View Post
guess the towers ended up wow'ing you haha nice!
WOWZERS
Hopinater and Roadwar like this.
SONY XBR-65X900F - Sony UDP X800- PSA 210T L/R -PHANTOM CENTER -ENERGY RC-10 SURROUNDS -PSA S3000i - MARANTZ SR6013 - APPLE TV -DIRECTV HR44 -HARMONY ELITE
BASEMENT SETUP- SAMSUNG UN466500- ENERGY RC50'S L/R-ENERGY RC LCR- DENON-AVR-3311CI- PS3 -APPLETV- MINI GENIE
tang7969 is offline
post #5222 of 8803 Old 07-13-2016, 08:09 PM
Quoted: 138 Post(s)
Liked: 121
AVS,
I need your additional support. Together with my significant other, I just auditioned the speakers in STEREO as follows:
- Polk Monitor 70 (inner, silver)
- PSA MTM-210T (middle, rock solid tower)
- Polk RTi-A9 (outside, the "beauties" according to my GF)
In pure stereo, no sub involved, the A9's sound round and sound - until a certain level, then the start screaming & yelling, still providing an rather deep bass. But not to forget, being powered with an XPA5.
The Monitor 70 sound more flat, less deep and less crisp'n'clear than the A9 - considering the cost for one of these speakers though, they do an pretty amazing job.
The 210s - WOW.
WOW.
Did I say WOW already??
Crisp, clear, punchy mids and simply vocal until (almost) reference, simply, because reference is too much in my home and for my ears. In pure stereo w/o any sub, I would not be sure if I'd go with the 210s despite their clearly well advanced crispiness and clarity, but then, what life would that be without a subwoofer? Or two, in my case ...
Engaging my two little fellas V1800, the combo unfolds their true strength: clear, crisp, loud, more headroom than imaginable (and needed) and spot-on with whatever thrown at them. Replacing at the same levels the 210s by the A9s, it just feels as if something is missing - something on all ends though: kick punch, clarity, crispness and clearness of voices. The deep bass provided by the A9s is simply not recognizable due to the shear power of the V1800s ;-)
I only can say WOW! Tom and his team from PSA designed a absolutely great combo! Thank you for this!
My next steps are to really and properly integrate the 210s into my HT. Therefore, the following questions are coming up:
- How far away from wall / wall / corner shall I position them? Angle to MLP?
- What is the best cut-off FQ on the AVR I should run them at? Currently, I've set them to 60Hz and am quite happy.
- Should I adjust the EQ to increase the punchy mid-bass more? If so, at what FQ?
- Not being used to the compression driver yet, I find them sometimes a slight notch to be too crisp & clear. Would you recommend engaging the EQ in the AVR and if so, at what Hz-range would you start to adjust to make them a little more "smooth"?
- I have set my V1800s to small room, cut-off at around 70Hz and gain at 11 o'clock on them, running the sub-out on the AVR at -5db. Any input on these settings?
Any further advice about how to most properly integrate the 210s, driven by the XPA5, along with the V1800s into my HT are greatly appreciated.
Thank you,
K
Yamaha CX-A5100 | 2x Emotiva XPA-5 & XPA-3 | PSA MTM-210T | PSA-MTM210C | PSA-MT110SR | 2x PSA V1800 | AM 8033-SII
Sony 65" 4K| Apple-TV | Network stuff | a lot of wires | Understanding & forgiving GF - priceless!
Kevin Grimm is offline
post #5223 of 8803 Old 07-13-2016, 09:12 PM
Roadwar's Avatar
Quoted: 73 Post(s)
Liked: 159
@Kevin Grimm
Congratulations! I don't know how long you've played them but I felt that mine "loosened" up some after a few hours of playing at moderate levels and I didn't worry much about positioning until after that. I know positioning away from the front wall isn't so critical since these have no rear ports. I have mine one foot from the front wall and toed in at 15 degrees but mine are only eight feet apart. You will want to experiment with toe in with consideration to distance to the listening position in your room. I have mine crossed over at 80 Hz.
They are great speakers. Enjoy!!
Kelly
smit1001 likes this.
Sources: Oppo UDP-203, Roku Ultra, Fire TV
Processor and Amps: Emotiva XMC-1, XPA-DR2, XPA-5
Speakers: PSA 210Ts, 210C, dual S1500s, Polk surrounds
Roadwar is offline
post #5224 of 8803 Old 07-14-2016, 03:24 AM
MysticalJet's Avatar
Quoted: 81 Post(s)
Liked: 158
Originally Posted by Kevin Grimm View Post
AVS,
The 210s - WOW.
WOW.
Thank you,
K
Hey K,
I am leaning heavily towards the MTM-210 for my theater. This is based on all the reviews and shootouts I've read about and their generous return policy.
Is your front wall treated at all? Mine are with 2" OC703 and the LCR will be placed behind an AT Screen. Due to the configuration/size of my room, the speakers will pretty much be up against the wall with a couple/few inches from the screen. I contacted Tom and he didn't see an issue with my set-up.
I recommend you connect with him and ask your questions (he's always on the chat on their website) and I'm sure he'll answer your questions.
Good luck and let us know how it works out.
smit1001, ahblaza and Roadwar like this.
MysticalJet is offline
post #5225 of 8803 Old 07-14-2016, 09:24 AM
Hopinater's Avatar
Quoted: 3506 Post(s)
Liked: 10896
I have mine about a foot away from the wall and toed in to cross about three feet behind the MLP. I tried all sorts of toe in and in my room this sounded best. I started with them crossing in front of the MLP and didn't like it.
I cross over at 80 but I have also used 100 and even 110. They all sound good to me but for over all purposes I find 80 works best in most circumstances.
If you like more mid bass and you can EQ it in such as way that you like how it sounds then go for it. Mid-bass is usually in the 60 to 150 range IIRC.
I found that the crispness took a little getting used to coming from the mellow sound of my Polk RTi-A7's. Now that I'm used to it other speakers sound muddy to me.
I have my subs set to Large Room, the gains are at 9:00 and the crossovers on the subs are maxed out. Audyssey set my Trim in the AVR at -9.5 and I'm running it 9 dB hot.
But most of this will be dependent on your room and your ears so YMMV.
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is online now
post #5226 of 8803 Old 07-14-2016, 11:51 AM - Thread Starter
basshead81's Avatar
Quoted: 324 Post(s)
Liked: 9318
@KevinG rimm
If you compare speakers without sub you need to boost the 210's about 3-4db around 30hz if you can. Then I think you would they are solid in 2ch only. However with quality sub's there is no need.
Congrats!
basshead81 is offline
post #5227 of 8803 Old 07-23-2016, 08:46 PM - Thread Starter
basshead81's Avatar
Quoted: 324 Post(s)
Liked: 9318
post #5228 of 8803 Old 07-23-2016, 09:59 PM
Sekosche's Avatar
Quoted: 1439 Post(s)
Liked: 3634
Originally Posted by basshead81 View Post
Crickets.....
Haha, I almost posted yesterday asking someone to get things rolling on this thread again. Maybe everyone is on summer vacation or spending time grilling in the 100+ degree heat or just enjoying their groovy PSA systems.
I wish the smaller PSA surround speakers were coming out a little sooner just for something shiny and new to consider for atmos, but I understand good things take time.
After the upfiring dolby enabled modules failed to work for my room, I just ordered some white (hoping for slightly better WAF) atmos/height speakers for my front wall. Almost everything audio I've done for the sake of WAF has backfired in a way, because she has mostly given in and doesn't care what I do. But I still try my best to compromise...fingers crossed. :smiley:
Just adding 2 atmos channels for now, and placing them maybe 8-10' off the floor above the L/R speakers. I hope they blend well enough with the PSA setup and can keep up. I'm very much looking forward to hearing what the dolby surround upmixer brings (hear great things) and true Atmos tracks. If all the supplies arrive this week, I should have everything up next weekend.
ahblaza, gbreda and Hopinater like this.
Sekosche is offline
post #5229 of 8803 Old 07-24-2016, 11:35 AM
raynist's Avatar
Quoted: 2126 Post(s)
Liked: 2305
Crickets.....
Hopefully I will have something to add later this week. Moved my PSA speakers into the bedroom a few weeks ago but have been too busy to set them up. Hopefully will have time later this week next weekend.
raynist is offline
post #5230 of 8803 Old 07-24-2016, 01:04 PM
Hopinater's Avatar
Liked: 10896
I don't know if this counts but I went to the Crutchfield Outlet Tent Sale this weekend and picked up a new Samsung 65" 9000 series SUHD for an incredibly insane deal (over 50% off). Anyway, the new TV makes my PSA speakers sound even better!
That's step one into 4K High Def.
post #5231 of 8803 Old 07-24-2016, 01:37 PM
gbreda's Avatar
Quoted: 569 Post(s)
Liked: 1042
Hows the new display? I am still using a 2009 Kuro with nor hurry to replace it yet, except its only a 50". It was huge in 2009, now its entry level size
oneeyeblind likes this.
gbreda is offline
post #5232 of 8803 Old 07-24-2016, 02:27 PM
laserjock II's Avatar
Quoted: 1300 Post(s)
Liked: 737
Hey, a new product for PSA.
Self powered speakers for TV viewing.
I bet it could be done and sound great.
laserjock II is online now
post #5233 of 8803 Old 07-24-2016, 05:51 PM
Hopinater's Avatar
Liked: 10896
Absolutely incredible!
I've been playing around learning the different picture settings but to be honest not much has needed to be tweaked. The TV up converts your source material and even old DVD's look much better on it. Next step is my new receiver. I'm looking at the Denon X4200 when they go on clearance later this fall and then I'll start considering getting the Samsung 4K UHD blu-ray player (I think its the only one out right now).
I have spent the last three years building the audio part of my HT while ignoring the visual part so when I saw this deal I decided it was time to focus a little on the visual again. Going from a 52" to a 65" screen is fun.
ahblaza and gbreda like this.
post #5234 of 8803 Old 07-24-2016, 11:12 PM
Sekosche's Avatar
Liked: 3634
Two years ago I was sure I could go 4-5 more years without 4K, since there was almost no content. But I'm a very visual person, and now I'm jealous of all the 4k TV owners, funny how that works. I got a sweet deal on my 60" Vizio M 2014 edition to replace a broken plasma, and it's easily the best picture, dollar for dollar, that I've seen. I only paid half of retail so I tacked on an extended warranty to ensure it makes it to 5 years in my new home and now I've got 3 years to go...lol.
Do I need a better viewing experience to match the amazing PSA sound system? I think so, but it's really going to have to wait a few years as I have no excuse to get another TV...no good excuse anyway. :smiley:
Sekosche is offline
post #5235 of 8803 Old 07-25-2016, 04:46 AM
madhuski's Avatar
Quoted: 1340 Post(s)
Liked: 866
AVS,
The 210s - WOW.
WOW.
Thank you,
K
While I have no advice for integration, I felt compelled to say
1) beautiful room
2) the center is massive! Makes your tv look like a computer monitor
madhuski is online now
post #5236 of 8803 Old 07-25-2016, 10:31 AM
Marc Alexander's Avatar
Quoted: 5477 Post(s)
Liked: 4973
@KevinG rimm
Congrats!
I don't understand this recommendation. After looking at the HTS review and frequency response an 80Hz x-over appears ideal. I don't consider 30Hz mid-bass and I am guessing that a boost at 30Hz could proove detrimental by causing harmonic and IM distortion. Would you mind further explanation?
Marc Alexander is offline
post #5237 of 8803 Old 07-25-2016, 08:14 PM
digler84's Avatar
Quoted: 348 Post(s)
Liked: 582
first off, when you see that x4200 on clearance, give me a heads up. i've eyeballed that for a while but am still fairly content with my good ol' onkyo 805. i would love to have blutooth for music on my phone, and the newer version of audyssey i've heard is worth the upgrade. not to mention, i recently turned an extra bedroom into a video game/movie room for my kids. they have my old yamaha receiver that doesn't even have HDMI capability to it, um....THEY could use an upgrade to my 805. yeah, that's it...THEY need the upgrade.
second, i currently have a 65" panny plasma that i absolutely love. simply amazing picture. HOWEVER, if you guys haven't seen the new LG oleds in person....hang on to your hats. beyond stunning. it's been a long time since i have been so floored by the picture on a TV. i was seriously fixated on staring at it.
digler84 is offline
post #5238 of 8803 Old 07-25-2016, 08:38 PM
bgtighe23's Avatar
Quoted: 1846 Post(s)
Liked: 1231
He probably means 2channel without a sub.
As in comparing speakers with no sub when going back to the original post about this topic.
So boosting the low end to make up for the lack of output because of lack of extension, but I'm also with you because these high sensitive speakers from PSA aren't exactly meant or ideal to run without a sub(s).
Receiver : Denon x5200
Front Stage : L/R - Statements by Jim Holtz
Surround Speakers : Klipsch RF-82II x 4 / RP-280F x 2
Subwooferage : 6 UM18/4 HT18 Subwoofer Log
bgtighe23 is offline
post #5239 of 8803 Old 07-25-2016, 08:47 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3015
Why wait?
Fry's Email Promo: Denon AVR-X4200W 7.2 Channel 4K Audyssey XT32 A/V Receiver - $897 + Free S&H
http://slickdeals.net/f/8955567-fry-...-897-free-s-h?
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #5240 of 8803 Old 07-26-2016, 03:49 AM
lizrussspike's Avatar
Quoted: 1226 Post(s)
Liked: 1832
Originally Posted by cel4145 View Post
Why wait?
Wow cel4145, perfect timing! Great chance for a 4K receiver for those in the market.
lizrussspike is offline
post #5241 of 8803 Old 07-26-2016, 05:50 AM
Sekosche's Avatar
Liked: 3634
Why wait?
That is a very nice receiver; I bought one recently with a 5 year square trade warranty for $900, couldn't pass that up.
It has jump started my journey into Atmos, and I'm rehanging the rear surrounds a couple feet lower today to better accommodate the 5.1.4 setup that'll hopefully be done within a week. At least working with the MT110-SR at ground level should be a piece of cake compared to hanging off a ladder while one arm juggling those behemoths; they are deceptively heavy, built like tanks.
I'm curious if I'll notice much of a difference for 5.1 tracks just lowering the surrounds, because I think the MT110-SR sounds fantastic even with them almost 7' high angled at the MLP. I know it'll add better separation for atmos. Eh, what's a few more holes to patch for finally doing it right? :smiley:
ahblaza and lizrussspike like this.
Sekosche is offline
post #5242 of 8803 Old 07-26-2016, 05:56 AM
majek 60's Avatar
Quoted: 157 Post(s)
Liked: 116
Congrats on the new display Hop!
Toys, Toys, Toys................
Isn't it great!
Hopinater likes this.
majek 60 is offline
post #5243 of 8803 Old 07-26-2016, 07:05 AM
Hopinater's Avatar
Liked: 10896
Why wait?
Man that looks tempting. But there are a couple of reasons why I need to wait. First I need to recover a little financially from the TV purchase. Second I get Crutchfield reward points that I can use towards saving money on future purchases. Third I use my Discover cash back credits at Crutchfield and that's saves even more. My goal is to walk away spending less that $600 on the receiver when all is said and done.
Another awesome perk with living near the Crutchfield store is if a receiver has an issue all I have to do is walk into the store, give it to them and they give me a loaner while they send it off for repairs under the warranty. Hassle free and no shipping costs. Crutchfield has customer service very much like PSA.
I love good customer service. Once I find it I stick with it whenever possible.
post #5244 of 8803 Old 07-26-2016, 07:56 AM
Sekosche's Avatar
Liked: 3634
I used to love crutchfield magazines in the 90s, with their informative how-to articles and tech reviews. It was what got me and all my friends into car audio for our first vehicles and probably helped fuel my home A/V passion at a young age.
Sekosche is offline
post #5245 of 8803 Old 07-26-2016, 09:42 AM
Liked: 1832
Well Hopinater, hopefully Thanksgiving will be the right time for that to happen.
post #5246 of 8803 Old 07-26-2016, 02:13 PM
Sekosche's Avatar
Liked: 3634
Moved one surround down 2 feet and one to go!
cel4145 likes this.
Sekosche is offline
post #5247 of 8803 Old 07-26-2016, 03:46 PM
Batman61405's Avatar
Quoted: 208 Post(s)
Liked: 210
Hey everyone,
been lurking on the forums for a while now. I got a dedicated theater room. in the near future I wanna upgrade my speakers. I have polk tsi series and one svs pb2000 now. another pb2000 will come eventually, but I want to get better speakers.
I was thinking of trying the SVS Primes and others like them in that price range, but high efficiency speakers have grabbed my attention. I love watching my movies at about -10db.
So heres my question:
should I stick with speakers like the SVS primes and other like it in that price range, or just say screw it and get 3 MTM110s for the front and add the surrounds later?
-would the 210s be of any advantage in my room (I do like the look of the 210c better then the 110c)
I'm sure high efficiency speakers are in a whole different league than other speakers.
here's my room:
any input?
Polk CS20Polk Tsi 500'sPolk Tsi 200'sDenon AVR 3300WSilver Ticket 92'' 16;9 White ScreenBenq HT2050 ProjectorXbox OneWii UPanasonic DMP-BDT 210SVS PB-4000Auralex MoPAD Paragon 4oz Theater Pop Popcorn MachineLogitech Harmony Elite
Batman61405 is offline
post #5248 of 8803 Old 07-26-2016, 04:10 PM
raynist's Avatar
Liked: 2305
Bad part is they probably charge tax if you live in the same state.
raynist is offline
post #5249 of 8803 Old 07-26-2016, 06:24 PM
Hopinater's Avatar
Liked: 10896
This is true.
But it gets made up for in the other ways.
post #5250 of 8803 Old 07-26-2016, 06:31 PM
Hopinater's Avatar
Liked: 10896
Originally Posted by Batman61405 View Post
Hey everyone,
here's my room:
https://www.youtube.com/watch?v=DF8nDuPGiaE
any input?
My input is if High Efficiency speakers have grabbed your attention then I would grab the either the 110's or the 210's. The 210T's will give more mid-bass punch but other than that (and the fact they look AWESOME) you won't hear a ton of difference.
So for price purposes I would choose the 110's. However, if mid-bass is important to you then I would consider the 210's.
Reply Speakers
