Official Power Sound Audio Speaker Thread - Page 263 - AVS Forum | Home Theater Discussions And Reviews
 9180Likes
post #7861 of 8725 Old 03-31-2018, 01:41 PM
CNLiberal's Avatar
Quoted: 68 Post(s)
Liked: 65
Originally Posted by mikeyd17 View Post
So you're using a TV swivel mount for your rears, very interesting. With this product, would you be able to mount it flush with the wall, and then swivel a couple inches without the speaker poking out into the room too much?
MikeyD,
The speakers will not sit flush on the wall with these mounts. They do come with screw slots on the back so you can mount them flush. The arm I have will sit proud of the wall about 2".
Fronts: Power Sound Audio MTM-210T | Center: Power Sound Audio MTM-210C | Rears: Power Sound Audio MT-110SR | Sub: JBL PB12
AVR: Denon AVR3312CI
| TV: Sony 65" KDL65W850C | Streaming: nVidia Shield 16GB 2018 | BluRay: PlayStation 3 | HTPC: Kodibuntu
CNLiberal is offline
post #7862 of 8725 Old 04-03-2018, 08:54 PM
serith's Avatar
Quoted: 776 Post(s)
Liked: 805
just purchased my 3rd mtm 210t last week. have been quite busy modifying my room to move from a 110" display to a 135" acoustic transparent setup. i have the wall recessed for the speakers (yes, the l/r openings are slightly larger to account for toe-in), and we just finished getting the initial framing for the faux-wall installed. should finish that framing tomorrow and work on building the spandex screen as soon as the material arrives. very exciting!
serith is offline
post #7863 of 8725 Old 04-04-2018, 08:24 AM
Alan P's Avatar
Quoted: 6144 Post(s)
Liked: 5369
Lookin' good serith!
But, isn't it considered a bad idea to flush mount speakers that were meant to be in free-air?? I could be totally off base here, but I'm sure I read that somewhere....
ahblaza likes this.
Alan P is offline
post #7864 of 8725 Old 04-04-2018, 09:01 AM
serith's Avatar
Quoted: 776 Post(s)
Liked: 805
thanks! they won't be flush though. the recesses i created are only 4" deep. it's just to get the screen as far back from the seating position as possible.
*edit* - they're only 4" deep because that's the depth of the 2x4 framing plus the 1/2" of drywall. i could have went back another 2" but i'd prefer keep the owens corning 2" xps foam insulation.
Alan P likes this.
serith is offline
post #7865 of 8725 Old 04-04-2018, 09:05 AM
raynist's Avatar
Quoted: 2059 Post(s)
Liked: 2215
Flush mounting speakers eliminates the boundary reflections from the back wall. I would do this with any speaker if I was able to. Those reflections will cancel out sound at certain distances. It is often the problem when people say a speaker is lacking in midbass.
Alan P and ahblaza like this.
raynist is offline
post #7866 of 8725 Old 04-05-2018, 08:32 PM
serith's Avatar
Quoted: 776 Post(s)
Liked: 805
i know this is a little off-topic from just being a speaker related question, however i wonder if someone that frequents this thread has done something like this or has seen someone do something similar before.
i built out my faux-wall and the (3) mtm 210t's are in their final resting places (toe-in & all) that will be behind my acoustically transparent screen. should i fill the cavity (the space between the old & new wall) with insulation, or leave it open? i'm just wondering how it will impact the acoustics is all. i guess i can buy some roxul and do some trial & error--it's just time consuming & messy is all.
here are some pictures of what it looks like right now (speakers covered with plastic sheeting for protection from sawdust):
ID:	2385732   Click image for larger version
ID:	2385734   Click image for larger version
ahblaza, Sekosche and OKGeek like this.
serith is offline
post #7867 of 8725 Old 04-08-2018, 08:24 AM
DekPM19's Avatar
Quoted: 189 Post(s)
Liked: 56
Is their an in ceiling speaker for atmos that matches the psa speakers? Or what is the most popular speaker used with the 210t.
Allen
DekPM19 is offline
post #7868 of 8725 Old 04-08-2018, 10:48 AM
jjackkrash's Avatar
Quoted: 2223 Post(s)
Liked: 2328
Allen
Take a look at JBL 328c.
https://www.proaudiola.com/product-p...SABEgK07vD_BwE
jjackkrash is offline
post #7869 of 8725 Old 04-08-2018, 02:03 PM
guiness4me's Avatar
For those looking for a tv stand that will accommodate a mtm 210 center. Budmore 70 inch tv stand from Ashley Furniture. Left and right shelves behind the doors are just wide enough to fit my Outlaw 7125 amp which is 17.25 inches wide.
ID:	2387192   Click image for larger version
ID:	2387200   Click image for larger version
ID:	2387202   Click image for larger version
ID:	2387204   Click image for larger version
guiness4me is offline
post #7870 of 8725 Old 04-08-2018, 02:28 PM
DekPM19's Avatar
Quoted: 189 Post(s)
Liked: 56
Originally Posted by jjackkrash View Post
Yea I have looked at them. If I go that way I would do scs 8 for surrounds to match.
Allen
jjackkrash likes this.
DekPM19 is offline
post #7871 of 8725 Old 04-20-2018, 09:54 PM
serith's Avatar
Quoted: 776 Post(s)
Liked: 805
got all 3 towers recessed in the wall & the new 135" frame built. just waiting on the spandex material to arrive to put it all together
serith is offline
post #7872 of 8725 Old 04-22-2018, 07:26 PM
BryceDH's Avatar
Quoted: 174 Post(s)
Liked: 158
Im looking at getting 5 psa speakers to replace my first set of speakers. Im wanting to go 210ts and a 210c up front. I was going to get the 110s for my surrounds, but noticed the 110sr.
Is there an advantage/disadvantage to getting either the 110 or the 110sr as the surrounds?
ahblaza and Hopinater like this.
Equipment: Yamaha 3050, Oppo 103d, DIYSG HT12s (L,C,R), PSA mt 110s (SR,SL), 2 VBSS, Submaximus, 4 driver BOSS build, umik-1, Epson 3700
BryceDH is offline
post #7873 of 8725 Old 04-22-2018, 09:20 PM
serith's Avatar
Quoted: 776 Post(s)
Liked: 805
the 110sr's are angled surrounds, and the 110's are bookshelf speakers. really just depends more on where & how you want to mount and position them. when i upgrade my surrounds, i'll be grabbing (4) 110sr's for my side & rear.
CallingMrBenzo and Hopinater like this.
serith is offline
post #7874 of 8725 Old 04-23-2018, 09:29 AM
Quoted: 1012 Post(s)
Liked: 1261
The angled surrounds that can be mounted higher on the wall and fire down to the seats make more sense if you arent running Atmos height speakers IMO. If you do have height speakers, then generally you would want the bed speakers to be at ear height I think?
Pradeep2 is offline
post #7875 of 8725 Old 04-23-2018, 09:36 AM
imureh's Avatar
Quoted: 2680 Post(s)
Liked: 3225
They are essentially the same speaker. The 110s have a little more midbass due to larger cabinet which is really not needed for surround duty.
Hopinater likes this.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #7876 of 8725 Old 04-23-2018, 01:22 PM
Hopinater's Avatar
Quoted: 3337 Post(s)
Liked: 10024
I've got a 210T with a 210C front stage and am running the 110SR's as surrounds. But I used to have a 110 front stage before I upgraded to the 210's so I have had experience with both the 110's and the 110SR's and there is very little difference. To be honest I think you would have to have the 110's and 110SR's playing next to each other to notice the difference. So I would go with whichever speaker works best for your set up.
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is offline
post #7877 of 8725 Old 04-23-2018, 01:40 PM
BryceDH's Avatar
Quoted: 174 Post(s)
Liked: 158
Thanks for all the input! Sounds like I'll go with the 110s like originally planned. These go in my main living room and im not sure i want to mount these to the wall.
BryceDH is offline
post #7878 of 8725 Old 04-23-2018, 04:24 PM
imureh's Avatar
Liked: 3225
There is a guy selling 3 110s for $400 each which is a great price
PSA MT-110 Speakers (3)
https://r.tapatalk.com/shareLink?sha...8&share_type=t
post #7879 of 8725 Old 04-23-2018, 04:54 PM
BryceDH's Avatar
Quoted: 174 Post(s)
Liked: 158
You are awesome, thanks for posting. Ive been browsing the forumn on and off, but hadnt seen this yet.
imureh likes this.
BryceDH is offline
post #7880 of 8725 Old 04-23-2018, 05:16 PM
imureh's Avatar
Liked: 3225
My pleasure. Good luck and let us know if and when you get them and what you them.
post #7881 of 8725 Old 04-23-2018, 05:24 PM
ahblaza's Avatar
Quoted: 2449 Post(s)
Liked: 3387
I think that's a wise move my friend, I had MTM 210s LCR with MT 110s surrounds and the combination was seamless and enveloping. I never heard the 110SR as I preferred a stand mount surround(s) and couldn't believe the difference it made to have matching drivers all around, I also had the opportunity to have all LCR and Surrs the exact same, all MT 110s, you can't go wrong with any combination. I'm from the camp that surrounds are very important and you don't know what you're missing till you have it............good luck and enjoy.
Pradeep2 likes this.
ahblaza is offline
post #7882 of 8725 Old 04-23-2018, 05:30 PM
imureh's Avatar
Liked: 3225
Some more PSA gear @BryceDH
Moving Sale: PSA 110x3, 15V sub, denon x2300, oppo 203 (SE michigan)
post #7883 of 8725 Old 04-23-2018, 08:34 PM
serith's Avatar
Quoted: 776 Post(s)
Liked: 805
you're selling all your gear? did you already sell/are you selling your 110 surrounds?
oh never-mind, it's someone else selling.
serith is offline
post #7884 of 8725 Old 04-24-2018, 05:18 AM
BryceDH's Avatar
Quoted: 174 Post(s)
Liked: 158
Is it difficult to switch a 110 to a 110c if needed? It sounds like the tweeter just needs rotated 90 degrees. If i get the 3 110s (fingers crossed), i would want to make one of them a center.
BryceDH is offline
post #7885 of 8725 Old 04-24-2018, 05:31 AM
Hopinater's Avatar
Liked: 10024
It's really easy. Just as you said, remove four screws rotate the tweeter 90 degrees and put the screws back in.
ahblaza likes this.
post #7886 of 8725 Old 04-24-2018, 06:22 AM
imureh's Avatar
Liked: 3225
Yep. It actually looks better that way rather than horizontal. PSA can help guide if needed but real simple.
post #7887 of 8725 Old 04-24-2018, 07:11 AM
BryceDH's Avatar
Quoted: 174 Post(s)
Liked: 158
Last question, for now. Is anybody using a 110c with 210T's? I know i want to get the towers, so my gut is telling me i need the 210c for my center, and not a 110c.
BryceDH is offline
post #7888 of 8725 Old 04-24-2018, 07:35 AM
Hopinater's Avatar
Liked: 10024
I'm not currently doing it but when I first started transitioning from a setup consisting of 110's for my L/C/R channels I went with 210T's for my L/R channels and kept my 110 for the center channel. It worked fine but there were a couple of things that made me decide to go the Full Monty and move up the the 210C.
1. The first is that the efficiency of the 110s is a bit lower than the 210's and while I can't say that I noticed it adversely affecting the sound quality I felt like something was a little mismatched.
2. I'm a big believer in getting your front stage matching as close to identical as possible so the 210c was a no brainer.
3. As big as the 110 is it looked small sitting in between the 210T's so it was aesthetically more pleasing to my eye to go with the 210c.
Having said that, the 110c sounded great and worked great but the 210c took it to the next level. But you won't be unhappy either way.
post #7889 of 8725 Old 04-25-2018, 01:49 AM
Sekosche's Avatar
Quoted: 1378 Post(s)
Liked: 3397
Always buy the best center channel you can afford; roughly 85% of TV/movie content comes through the center channel. I would recommend people downsize other speakers if needed first, but never skimp on the center channel. That said, I’d bet 95% households don’t have a center channel as capable as a 110C let alone the 210C.
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is online now
post #7890 of 8725 Old 04-25-2018, 07:21 AM
serith's Avatar
Quoted: 776 Post(s)
Liked: 805
i'm still floored by how much better my system sounds using a 3rd tower directly behind the middle of the screen for a center channel. the l/r did a really good job giving you a phantom center but nothing like this.
rustolemite likes this.
7.0.6 / 1700 ft³ / PSA MTM-210T³ / Epson HC 2150 / 147" AT 2.39:1 Spandex Screen / Seatcraft Rialto³ / Velvet Everywhere / Chasing LFE
serith is offline
Reply Speakers
