Help me place my surround and rear speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-11-2014, 11:41 AM - Thread Starter
ohioratrodder's Avatar
Quoted: 23 Post(s)
Liked: 0
I could put the surrounds on stands but it will be close to the two ends chairs(wont be used much as only the 4 middle seats get used regularly) and the right stand will also be in the middle of the floor. Was also thinking of sticking one above the air hockey table and other on the wall above the arcade machine but would think that is to far back. Only place i could see to put rears would be on the beam that runs above the arcade machines but dont know if that would be to close to the surrounds if i put them on the walls instead of stands.
ID:	306162   Click image for larger version
ID:	306170   Click image for larger version
ID:	306178   Click image for larger version
ohioratrodder is offline
post #2 of 6 Old 10-15-2014, 05:48 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 0
are in ceiling speakers terrible for surround speakers? are any recommendations on smaller speakers to hang from the ceiling that will sound good for surround speakers?
post #3 of 6 Old 10-15-2014, 06:15 PM
ack_bk's Avatar
Quoted: 1343 Post(s)
Liked: 1503
No they are not at all. In fact depending on your room layout they may be the better and only choice. What is your budget?
ack_bk is offline
post #4 of 6 Old 10-15-2014, 06:45 PM - Thread Starter
Quoted: 23 Post(s)
Liked: 0
budget guess around a grand. not an audiophile(have decent hearing lose) but would like it sound decent to anyone else who listens. reviews gave the andrew jones good reviews and i got them for a great price. but read that speakers should be 3 ft above ear level and my ceiling is already finished. running wire wont be a huge problem but adding bracing to hold 10lbs speakers maybe.
post #5 of 6 Old 10-15-2014, 09:10 PM
ack_bk's Avatar
Liked: 1503
So are you saying you don't want to put in in-ceiling speakers and are planning on-ceiling with mounting brackets?
I would not spend $1K for the surrounds if you have hearing loss. Honestly, something like this would be fine:
http://www.crutchfield.com/p_760CW60...0R.html?tp=193
That is a great price on those speakers and Crutchfield support is top notch. You don't need bracing for these the drywall and dog legs will hold them fine.
ack_bk is offline
post #6 of 6 Old 10-16-2014, 09:24 AM - Thread Starter
Quoted: 23 Post(s)
Liked: 0
I am not against in ceiling speakers but read they are not near as good as mounted speakers. I just want the best surround for my family as guest as i can in my limiting room.
From what i read i thought surrounds should be 3 ft above ear level. I don't think i can hang the andrew jones bookshelf speakers comfortably, not against stands either but figured having them almost right next to the end listens heads wouldnt be idea for them.
Reply Speakers
