JBL 705i/708i (7 Series Master Reference Monitors) & 725G/728G (subwoofers): Jan 2015 - Page 53 - AVS Forum | Home Theater Discussions And Reviews
 1085Likes
post #1561 of 2918 Old 02-22-2017, 08:24 PM
12B4A's Avatar
Quoted: 589 Post(s)
Liked: 511
Originally Posted by McLuvin View Post
Yes, they are really good considering their price point. But I knew it could get better. So nice to see these made the day of light.
305s replaced Maggie 1.7i for me. I'll be waiting in line for the 705p. I'd expect there to be some differences attributed to CD vs. dome tweeter, front firing port vs. rear firing port, and overall better resonance free build quality. However, I think a night and day difference expectation might be unreasonable considering the basic physics involved.
Life is Lambertian
12B4A is offline
post #1562 of 2918 Old 02-22-2017, 09:13 PM
Quoted: 1181 Post(s)
Liked: 661
Does anyone know if the baffle/waveguide of the 708i is just screwed on? I recall seeing internal shots that had what looked like baffle screws, but can't find them now.
I have an idea...
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #1563 of 2918 Old 02-23-2017, 05:04 AM
12B4A's Avatar
Quoted: 589 Post(s)
Liked: 511
Here's the 705 internal from Sean Olive. It seems like it would just be the same for the 708, just scaled up. I wouldn't be surprised if they still used the same amount (6-8) of baffle screws:
Were you thinking about adding mass to the baffle? Noaudiophile tried it with the 308's. I don't think it had the intended effect.
Life is Lambertian
12B4A is offline
post #1564 of 2918 Old 02-23-2017, 03:20 PM
McLuvin's Avatar
Quoted: 343 Post(s)
Liked: 144
It's the sound of a compression driver I was missing in the 308's. That and a little more output and they would have been perfect. Well, now we have the 708p's....
Interesting though is the max spl on the 708i and p. I ran them through the SPL calculator and it says the sensitivity on these are around 87db with the amp wattage rating for the 708p. I know that can't be right because the 308's come in around 92db sensitivity and the two are only 2db apart in total output. I know it's not all about output but those numbers just seem off. Anybody know what's going on here?
McLuvin is offline
post #1565 of 2918 Old 02-23-2017, 05:14 PM
Liked: 661
No, I assume structurally they're fine. I'm thinking of wrapping them in a prettier cabinet. The M2 waveguide is available but just too big.
Serious Audio Blog
DS-21 is offline
post #1566 of 2918 Old 02-24-2017, 06:59 PM
Skylinestar's Avatar
Quoted: 1308 Post(s)
Liked: 267
Originally Posted by Gooddoc View Post
This is mounted
Hi. What's the length of that "rod"?
Is there any mounting holes on the back of the 708?
Do that holes on the Peavey VM70 mount align with those on the 708?
Skylinestar is offline
post #1567 of 2918 Old 02-24-2017, 10:45 PM
Gooddoc's Avatar
Quoted: 3635 Post(s)
Liked: 3224
Ah, I can't count how many times I've been asked that very question .
When I find my tape measurer I'll let you know.
There are top, bottom, and back mounting points on the 708 and the Peavey pattern fits if I recall correctly. If not, I drilled them .
Jsin_N likes this.
Gooddoc is offline
post #1568 of 2918 Old 02-25-2017, 10:42 AM
John Schuermann's Avatar
Quoted: 2001 Post(s)
Liked: 2493
Not to TOTALLY derail this conversation, but I got my usual e-mail notification of a post in this thread, with this the only text in the body of the email:
"This is mounted."
"What's the length of that "rod"?
A did a little double take there
John Schuermann
The Screening Room Home Theater Sales and Design
JS Music and Sound Film Scoring and Sound Design
John Schuermann is offline
post #1569 of 2918 Old 02-25-2017, 10:46 AM
Ted C's Avatar
Quoted: 153 Post(s)
Liked: 187
Talking
I don't know, had my wife take a look and she said it was 6" from the base to the mounting point. But personally I think its a lot longer! Time to get out the ruler...
Ted C is offline
post #1570 of 2918 Old 02-25-2017, 10:48 AM
Gooddoc's Avatar
Liked: 3224
It always looks longer to the guys
Gooddoc is offline
post #1571 of 2918 Old 02-25-2017, 10:50 AM
Gooddoc's Avatar
Liked: 3224
Originally Posted by skylinestar View Post
hi. What's the length of that "rod"?
6 1/2"
Gooddoc is offline
post #1572 of 2918 Old 02-25-2017, 10:51 AM
Ted C's Avatar
Quoted: 153 Post(s)
Liked: 187
Yes indeed! But I guess what is most important is that you can hear the results of your mounting job when all is said and done
Ted C is offline
post #1573 of 2918 Old 02-25-2017, 01:50 PM
Gooddoc's Avatar
Liked: 3224
How's progress moving along on your room Ted??
Gooddoc is offline
post #1574 of 2918 Old 02-25-2017, 05:44 PM
Blackdevil77's Avatar
Quoted: 477 Post(s)
Liked: 226
Quick question. Usually with clip/limiter lights, if the light occasionally flickers, you're at the limit and you shouldn't increase the level at all, if anything back off a little. I'm guessing the same applies with the DCi 4/300 with the 708i's. I went to check the DCi amp out of curiosity while watching a concert blu ray tonight and noticed the red clip lights flickering occasionally during peaks. The 708i's are being used as surround channels currently and crossed at 80Hz.
Blackdevil77 is offline
post #1575 of 2918 Old 02-25-2017, 07:09 PM
notnyt's Avatar
Quoted: 3714 Post(s)
Liked: 3679
lol, could have sworn I mentioned something about that...
notnyt is offline
post #1576 of 2918 Old 02-25-2017, 07:23 PM
12B4A's Avatar
Quoted: 589 Post(s)
Liked: 511
Alternatively, it could be clipping at the input since the clipping indicator does come on in either output or input clipping. My $1 is on input clipping.
Life is Lambertian
12B4A is offline
post #1577 of 2918 Old 02-25-2017, 07:47 PM
notnyt's Avatar
Liked: 3679
You think he's clipping the input of the amp? That seems unlikely
notnyt is offline
post #1578 of 2918 Old 02-25-2017, 07:59 PM
Quoted: 477 Post(s)
Liked: 226
I don't think it's the input on the amp. I was at -7 on the front of the AVM60. Wasn't even close to clipping on the Cats. I know the DCi 4/300 amp has limiter set in the DSP settings for the 708i's as @notnyt pointed out before. I'm assuming the lights flickering is just the limiters doing their job and protecting the speakers based on what the DSP settings set the limiters to for the 708i's. I was just posting here to make sure. It was loud, but it didn't seem THAT loud surrounds to be hitting their limits.
post #1579 of 2918 Old 02-25-2017, 08:01 PM
notnyt's Avatar
Liked: 3679
It'll compress the lower frequencies to prevent damage to the speakers. If it's just coming on briefly, I wouldn't worry.
notnyt is offline
post #1580 of 2918 Old 02-26-2017, 12:00 AM
adidino's Avatar
Quoted: 499 Post(s)
Liked: 340
Try adjusting the input gain on the amp from 32db to 29db. Setting is 's under "Input Configuration" in Audio Architect. You will need to adjust gain settings in the processor relative to the main speakers after your do.
adidino is offline
post #1581 of 2918 Old 02-26-2017, 12:14 AM
notnyt's Avatar
Liked: 3679
This seems pointless as it would cause the input signal to the amp to be higher, and the output signal after adjusting the processor would remain unchanged. What benefit were you trying to go for here?
notnyt is offline
post #1582 of 2918 Old 02-26-2017, 12:17 AM
adidino's Avatar
Quoted: 499 Post(s)
Liked: 340
I assumed there may be some type of input gain mismatch between the 708 and the amp. Perhaps not if you think that will not have an affect (or make it worse).
adidino is offline
post #1583 of 2918 Old 02-26-2017, 12:38 AM
notnyt's Avatar
Liked: 3679
If he was clipping the input on the amp you'd want to raise the amp's gain so the input signal to it could be lowered.
As these amps are rated at +20dBu before compression, and +26 before clipping, it's not likely he's clipping the inputs.
Maximum Input Level before Compression +20 dBu
Maximum Input Level before Clipping +26 dBu
notnyt is offline
post #1584 of 2918 Old 02-26-2017, 01:04 AM
Gooddoc's Avatar
Liked: 3224
The clip light can also flash if the TLC protection circuit is engaging. As I said, the only way to know for sure what is going on is to monitor the input/output signals in Audio Architect. Otherwise you're just guessing.
Gooddoc is offline
post #1585 of 2918 Old 02-26-2017, 06:46 AM
Quoted: 477 Post(s)
Liked: 226
I wasn't clipping the input. After some thinking, I think I know what it is. I'm a little embarrassed to say what I did.... or didn't do for that matter that may solve the problem.
post #1586 of 2918 Old 02-26-2017, 02:08 PM
Quoted: 477 Post(s)
Liked: 226
Originally Posted by Molon_Labe View Post
You realized you bought a speaker too small for the output?
I kid...I kid.
Glad you got it sorted out.
Lol these speakers don't have the same output the Sparks have, but they do have more than what I experienced last night. Used the wrong ARC profile and had the surrounds running 5db and 6db hot.
post #1587 of 2918 Old 02-26-2017, 09:12 PM
Gooddoc's Avatar
Liked: 3224
The Spark is a single 8" design, no? I doubt that it has greater output, particularly if the 708 is run active like the spark.
Gooddoc is offline
post #1588 of 2918 Old 02-26-2017, 10:35 PM
notnyt's Avatar
Liked: 3679
708 is low sensitivity and setup to play to lower frequencies. it gives up output for extension. jbl limits the power on the low end to 250 watts, hence why owners are seeing clipping below reference levels. it's not hard to best them in output capabilities. The Sparks are designed to be run with a sub, not as a monitor, so they can get away with a higher sensitivity driver.
notnyt is offline
post #1589 of 2918 Old 02-27-2017, 01:45 AM
Gooddoc's Avatar
Liked: 3224
Owners? Aside from the "owner" that reported it, and then realized why, who else?
In pretty much any residential surround application, the 7's run active and crossed over at anything over 70 Hz are not going to clip.
John Schuermann likes this.
Gooddoc is offline
post #1590 of 2918 Old 02-27-2017, 01:50 AM
notnyt's Avatar
Liked: 3679
likely anyone else who tries to play them at reference with jbl factory settings and and is further than 3 feet from them?
5db hot but -7 mv is 2db under reference, and it was still hitting the clip indicator.
notnyt is offline
Reply Speakers
