JBL 705i/708i (7 Series Master Reference Monitors) & 725G/728G (subwoofers): Jan 2015 - Page 69 - AVS Forum | Home Theater Discussions And Reviews
 1085Likes
post #2041 of 2918 Old 01-25-2018, 08:09 AM
12B4A's Avatar
Quoted: 589 Post(s)
Liked: 511
Originally Posted by Zzzzz... View Post
I'm trying to understand this. How did you conclude that the heat was mainly from the display/processing board? Also, wouldn't the heat from the amps ultimately exit via the rear panel as well?
IR thermometer and fingers. There is some convection from the amp stage heatsink but it is significantly less than the heat generated by the processing/display board. Class D amps usually run pretty cool. For instance, the amp chip in the LSR305 doesn't even use a heatsink.
Zzzzz... likes this.
Life is Lambertian
12B4A is online now
post #2042 of 2918 Old 02-02-2018, 03:18 AM
Kain's Avatar
Quoted: 1925 Post(s)
Liked: 800
Is there any difference in SPL capabilities between using the 708i with the 300 watt Crown amps vs. the 708P?
Kain is offline
post #2043 of 2918 Old 02-02-2018, 06:59 AM
Quoted: 835 Post(s)
Liked: 982
Anyone using speaker stands for 705P's? Moving to a new house and might use them for surrounds.
I want good quality heavy duty stands. Haven't needed or used them for years, so looking for suggestions.
Rex Anderson is online now
post #2044 of 2918 Old 02-02-2018, 11:39 AM
Kain's Avatar
Liked: 800
One more question...
With the DCi 8|600N, can I power, say, five 708i speakers and use the rest of the available channels to power some SCS 8 speakers? Basically, when you load the tuning file(s) for the 708i onto the amp, does it apply it to all channels or only the ones you select?
Kain is offline
post #2045 of 2918 Old 02-02-2018, 12:30 PM
TimVG's Avatar
Quoted: 256 Post(s)
Liked: 387
My guess is no. Even though the 708p uses a 250W amp on the woofer and 250W on the CD, I assume the CD is a lot more sensitive than the woofer and will use up only a little amount of the available power resulting in the same approximate overall SPL capability.
TimVG is online now
post #2046 of 2918 Old 02-03-2018, 04:24 AM
Kain's Avatar
Liked: 800
Not to bring this topic back from the dead, but will it be possible for someone who owns (or has access to) to the 708i/708P to do some frequency compression sweeps like Gooddoc did? If someone can replicate the same results it will confirm what Gooddoc produced. Maybe @COACH2369 or @John Schuermann can give it a try? No worries if it is not possible but would be awesome if we can get some results other than Gooddoc's (not that I don't trust them).
Kain is offline
post #2047 of 2918 Old 02-03-2018, 09:41 AM
COACH2369's Avatar
Quoted: 1164 Post(s)
Liked: 984
I almost hate to admit this, but I don't know how to run what you are talking about. Are you referring to when I use the ARC in my Anthem? As much as I love this hobby, I am very uneducated in the technical end of things. I just hook everything up, have it calibrated and then it is tweaked until my ears enjoy what I hear.
COACH2369 is offline
post #2048 of 2918 Old 02-03-2018, 10:27 AM
Kain's Avatar
Liked: 800
No worries. I don't know how to do it either, I only know how to read the results.
However, I am pretty sure you cannot use your ARC mic for it. You need to get an external mic, attach it to your computer/laptop via USB, run REW on the computer/laptop, and then play some frequency sweeps through one of your 708P speakers at 75 dB. Then, increase the volume by 5 dB and do it again. Finally, plot the results in a graph. This will show when the speaker starts to compress and at what frequencies. @Gooddoc or @notnyt will be able to explain this much better than me. I know notnyt was interested in getting John to do this so we'd have a comparison to Gooddoc's results.
However, no worries if you can't do this.
Kain is offline
post #2049 of 2918 Old 02-03-2018, 10:50 AM
John Schuermann's Avatar
Quoted: 2001 Post(s)
Liked: 2493
I have a calibrated mic but have never done the sweeps. My 708s have been moved to side duties and I'm now using the JBL SCL2 as LCRs.
John Schuermann
The Screening Room Home Theater Sales and Design
JS Music and Sound Film Scoring and Sound Design
John Schuermann is offline
post #2050 of 2918 Old 02-03-2018, 11:10 AM
notnyt's Avatar
Quoted: 3714 Post(s)
Liked: 3679
to measure, just need to use REW or something with a calibrated mic. Start at like 75db sweeps of at least 5 seconds and keep increasing by 3db until you get to like 110 or so, or hit significant compression, whichever happens first.
Distance from the speaker needs to be measured as well. Measurements should be run with a frequency dependent window of 1/20 octave
notnyt is offline
post #2051 of 2918 Old 02-21-2018, 07:08 AM
LJG
LJG's Avatar
Quoted: 699 Post(s)
Liked: 407
It's too bad Jbl does not come out with a 708I for horizontal mounting as it makes the perfect ceiling pair with the M2. The length is just problematic for this function if mounting down vertically facing MLP.
LJG is online now
post #2052 of 2918 Old 02-22-2018, 04:09 AM
Quoted: 1181 Post(s)
Liked: 661
Why does the mike need to be calibrated, really? All you’re looking for is relative information. So as long as you keep levels low enough to avoid clipping on either side it should be fine.
IMO, an ARC mike or even an Audyssey towerlet is adequate to the task. The tricky part is having time to set up and run the measurements when environmental conditions allow one to do so.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #2053 of 2918 Old 02-22-2018, 08:59 AM
notnyt's Avatar
Liked: 3679
It needs to be calibrated so you know what levels it's actually compressing at.
notnyt is offline
post #2054 of 2918 Old 02-22-2018, 09:55 AM
Liked: 661
Often mike calibrations are done without absolute SPL. The Cross Spectrum ones for example. To get close enough to absolut-ish SPL for this purpose, you can use the NIOSH SPL meter app with your phone next to the mike and run your measurement software’s absolute SPL cal routine.
Serious Audio Blog
DS-21 is offline
post #2055 of 2918 Old 02-22-2018, 09:56 AM
notnyt's Avatar
Liked: 3679
Then you're assuming your phone is accurate
notnyt is offline
post #2056 of 2918 Old 02-22-2018, 10:13 AM
Quoted: 835 Post(s)
Liked: 982
MULTIPLE MOUNTING OPTIONS
JBL 7 Series monitors provide construction and mounting features that make installation simple. Constructed from rugged birch plywood, the cabinets are specially braced and reinforced to allow safe mounting. Top and bottom mounting points in a two-hole mounting pattern facilitate effortless wall and ceiling installations using readily available brackets. Both vertical and horizontal orientations are supported. Integrated handles aid in speaker positioning.
  • Compact enclosures minimize interference with sight lines to video monitors
  • Front-ported enclosures allow shelf and soft mounting without degradation in performance
  • Rear and bottom mounting points allow wall and ceiling mounting in either vertical or horizontal orientation using standard hardware
John Schuermann likes this.
post #2057 of 2918 Old 02-22-2018, 10:27 AM
LJG
LJG's Avatar
Quoted: 699 Post(s)
Liked: 407
I don't think 708's are made to turn horizontally due to their vertical pattern, they can be mounted that way but not designed for horizontal placement. It would be great if they could design a 708H - for horizontal placement.
LJG is online now
post #2058 of 2918 Old 02-22-2018, 10:40 AM
12B4A's Avatar
Quoted: 589 Post(s)
Liked: 511
It seems like a non-issue for ceiling mounting if you're aiming in the general direction of the MLP. I'm also not sure why the 705 would work just as well for ceiling speakers vs. 708 since the tweeters are the same on both speakers and trying to squeeze every last bit of sub ~80Hz loudness has little utility at that location.
Life is Lambertian
12B4A is online now
post #2059 of 2918 Old 02-22-2018, 11:01 AM
Quoted: 835 Post(s)
Liked: 982
JBL knows horizontal orientation is not ideal for studio monitors which is what they are designed to be. A horizontally oriented 708 type of speaker would have to be an entirely different cabinet design, just rotating the horn in the existing model would not be a good design.
I'm sure somewhere there are still recording engineers who are laying their 708's horizontally so they can be on the mixing console bridge or behind it on stands. But, most of those guys learned that doesn't work well because it screws up the dispersion pattern.
If size is your concern, the 705i/p has very similar specs and is much smaller. It could be hung vertically with the horn on top or bottom. Subs are going to handle the low end anyway, right?
post #2060 of 2918 Old 02-22-2018, 11:36 AM
LJG
LJG's Avatar
Quoted: 699 Post(s)
Liked: 407
Agreed on all points.
LJG is online now
post #2061 of 2918 Old 02-22-2018, 11:37 AM
Liked: 661
See https://blogs.cdc.gov/niosh-science-...01/17/slm-app/
Perhaps phone mike accuracy is more of an issue with generics than with iPhones. I don’t know.
Regardless, for this kind of measurement by a hobbyist, in the ballpark is good enough as far as absolute levels go.
If one really wants to be anal about it, one could measure absolutes using voltage out from the amp rather than SPL at the capsule.
Serious Audio Blog
DS-21 is offline
post #2062 of 2918 Old 02-24-2018, 02:26 PM
Kain's Avatar
Liked: 800
When we were discussing the SPL capabilities of the 708i, people stated you can only expect so much out of a 8" driver. However, Alcons Audio gets 130 dB out of a speaker with a 2" pro-ribbon tweeter and a 6.5" woofer and 134 dB out of a speaker with a 4" pro-ribbon tweeter and a 8" driver. And these are surround speakers.
Link to 2" pro-ribbon tweeter + 6.5" woofer: http://www.alconsaudio.com/product/crmsc-sr/
Link to 4" pro-ribbon tweeter + 8" woofer: http://www.alconsaudio.com/product/crms-sr/
Kain is offline
post #2063 of 2918 Old 02-24-2018, 04:53 PM
12B4A's Avatar
Quoted: 589 Post(s)
Liked: 511
Completely different price brackets. There's also a little bit of Hoffman's Iron Law involved when comparing the low frequency reach of the Alcons' vs. the 708.
Life is Lambertian
12B4A is online now
post #2064 of 2918 Old 02-24-2018, 05:16 PM
Jsin_N's Avatar
Quoted: 440 Post(s)
Liked: 192
Nominal SPL peak 129 dB (Sentinel3 200 Hz - 10 kHz)
134 dB (Sentinel10 200 Hz - 10 kHz)
Important to note where it can reach these levels
Jsin_N is offline
post #2065 of 2918 Old 02-24-2018, 06:59 PM
notnyt's Avatar
Liked: 3679
They're also claiming 103dbspl sensitivty out of an 8" woofer. I don't know about that claim :/
notnyt is offline
post #2066 of 2918 Old 02-24-2018, 07:21 PM
Brad/Viper-Fan's Avatar
Quoted: 66 Post(s)
Liked: 38
This info is from a JBL booth at a trade show:
JBL 708P
Distance from Speaker / Output:
3ft (1 meters) / 110dB
5ft (1.5 meters) / 107dB
7ft (2 meters) / 105dB
9ft (3 meters) / 104dB
17ft (5 meters) / 102dB
JBL 705P
3ft (1 meters) / 104dB
5ft (1.5 meters) / 101dB
7ft (2 meters) / 99dB
9ft (3 meters) / 98dB
17ft (5 meters) / 96dB
(Room Size: 75 cubic meters. Measured in half space.)
Brad
Brad/Viper-Fan is offline
post #2067 of 2918 Old 03-01-2018, 08:52 AM
lemonslush's Avatar
Quoted: 835 Post(s)
Liked: 424
You would want to use the in wall or incelings from the synthesis line from JBL to accompany the m2 or 7XX line. They are designed to be integrated with one another sharing lots of characteristics. They however are more expensive than 705's. IM looking into changing over to some 708s and 705 still awaiting to hear back if I need to use the JBL amps for them or if I can use my existing DSI crowns and mimic the settings.
"we need more power" - My Wife.
Theater Build Thread - Wartooth
lemonslush is offline
post #2068 of 2918 Old 03-01-2018, 10:59 AM
Liked: 2493
The amps that will allow you to load in the tunings for the M2 and LSR7 series:
Synthesis SDA
Crown DCi-n
Crown iTech
One can also add a BSS BLU box to the equation.
John Schuermann
post #2069 of 2918 Old 03-01-2018, 11:57 AM
Brandon B's Avatar
Quoted: 114 Post(s)
Liked: 90
If I'm driving 708's from the balanced outs of a Marantz 7702mkII, which has an output rating of 2.4V, I assume I should be using the +4dBu input sensitivity on the JBLs, yes?
Brandon B is online now
post #2070 of 2918 Old 03-01-2018, 12:20 PM
LJG
LJG's Avatar
Quoted: 699 Post(s)
Liked: 407
The in ceilings cannot be aimed directly at MLP, the 705's and 708's can be mounted vertically and aimed. That is one of the advantages over in ceiling. The in walls can be aimed to an extent at MLP.
LJG is online now
Reply Speakers
