AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Speakers (https://www.avsforum.com/forum/89-speakers/)
-   -   JBL 705i/708i (7 Series Master Reference Monitors) & 725G/728G (subwoofers): Jan 2015 (https://www.avsforum.com/forum/89-speakers/1724906-jbl-705i-708i-7-series-master-reference-monitors-725g-728g-subwoofers-jan-2015-a.html)
dabotsonline 10-17-2014 04:23 AM
JBL 705i/708i (7 Series Master Reference Monitors): Jan 2015
Originally Posted by Adam Savage
For the eight-inch two-way 708i and five-inch two-way 705i installed monitors, JBL developed a new miniature high-frequency transducer, the 2409H, featuring the manufacturer’s low-mass, annular diaphragm design, which was built to allow very high output with low distortion and high frequency response to 35kHz. JBL also engineered two new high-excursion five-inch and eight-inch woofers, the 725G and 728G, enabling the speakers to deliver robust low-frequency output into the 30Hz range...
To reduce enclosure size and installation cost, the speakers are centrally powered by Crown DCi 8|300N eight- and four-channel power amplifiers. The 705i and 708i can be driven by a single amp channel or bi-amplified. For greater accuracy and room-to-room consistency, BSS Soundweb London's signal processor provides speaker tuning, room EQ, and bass management. The processor accepts 16 or more analogue and AES/EBU inputs, and networks with the power amps via CAT5. The entire system can be externally controlled with HiQnet Audio Architect software, a hardware controller, or wireless tablet.
http://www.audioprointernational.com...monitors/07573
Data Sheet:
http://www.jblpro.com/ProductAttachm...eet_101514.pdf
5":
Frequency Response -1.5 dB @ 48 – 23kHz
Frequency Range 39Hz – 36 kHz
Max SPL (80 Hz - 20 kHz) >101 dB SPL / 1m
Maximum Peak SPL (80 Hz - 20 kHz) >107 dB SPL / 1m
http://www.jblpro.com/www/products/r.../lsr705i#Specs
8":
Frequency Response -1.5 dB @ 45 – 23kHz
Frequency Range 35Hz – 36 kHz
Max SPL (80 Hz - 20 kHz) >108 dB SPL / 1m
Maximum Peak SPL (80 Hz - 20 kHz) >114 dB SPL / 1m
kevon27 10-18-2014 01:34 PM
I was excited for a quick moment until I found out that the 7 series would be passive and not active monitors.. Come on JBL, create a LSR 708p (p for powered)
Gooddoc 10-18-2014 01:45 PM
Aha. I think I will have to wait for these. It appears they are the first models designed to be a timbre match for the M2's. I was wondering when they would get these out the door - and here they are. I wonder what the waveguide dispersion is?
I just ordered some SCS8's, but I think I might return them.
Zzzzz... 10-18-2014 04:13 PM
Zzzzz... 10-18-2014 04:19 PM
Note that the 725G/728G refer to the low frequency drivers in the 705i and 708i respectively. They are not subs are mentioned in the thread title.
Gooddoc 10-18-2014 05:19 PM
I'm curious what the list price will be compared to the 305 and 308.
SyntheticShrimp 10-18-2014 07:41 PM
Nice. Will be watching these.
dabotsonline 10-19-2014 12:33 AM
Ah, poor reading comprehension on my part! Thanks for pointing this out, @Zzzzz... . Could @markrubin or one of the other moderators edit my thread title, please? Cheers.
dabotsonline 10-20-2014 01:55 AM
For those interested, @imagic posted an article on said amplifiers here: https://www.avsforum.com/forum/286-la...mplifiers.html
EDIT: Formatted my message correctly, now!
Zzzzz... 12-26-2014 01:55 PM
Looks like these can now be purchased:
www.performanceaudio.com/shop/JBL/LSR-7-Series-826/
It's interesting that they can be purchased individually rather than as a system.
Perhaps the most interesting new info, hearsay at this stage, is that they measure even better than the M2's :eek::eek::eek::eek: Not sure how that is possible :D Probably the differences are minor but it looks like these could indeed be a very nice option if you don't need the SPL produced by the M2's.
www.audioheritage.org/vbulletin/showthread.php?36228-New-LSR-7-series-708&p=369867&viewfull=1#post369867
Frohlich 12-28-2014 05:56 PM
Very interesting. I thought these would only be available as part of a package with the crown amps. Looks like you can buy them individually?
Zzzzz... 02-06-2015 02:12 AM
A little titbit, Scott Wilkinson recently got to hear an Atmos setup consisting of 7 series speakers (see the 4th photo and accompanying info):
https://www.avsforum.com/forum/286-la...mmy-party.html
3 series monitors were also being used in another demo.
Skylinestar 02-06-2015 03:02 AM
In Studio D, the Dolby Atmos system used JBL's new 2-way 7-series speakers in a 7.1.4 configuration, with pairs of left and right side surrounds playing the same signal.
That statement sounds like 5.1.4 with array of surrounds instead of 7.1.4 :confused:
Zzzzz... 02-08-2015 05:47 PM
Yeah, it's not completely clear. For me its just nice to see that these are already out and that presumably Dolby had the good taste to choose these monitors for their demo :)
Hifisound 02-10-2015 11:34 AM
I assume these have "normal" passive crossovers and can be used with usual AV Receivers...
Zzzzz... 02-10-2015 12:38 PM
Yes.
"The 705i and 708i can be driven by a single amp channel or bi-amplified. For greater accuracy and room-to-room consistency, HARMAN’s BSS Soundweb London signal processor provides speaker tuning, room EQ, and bass management."
The above however suggests that to get the most out of them, the Harmon processor would be required to tweak their anechoic response (like with the M2s). I don't know if that is the case or not. It depends on what exactly they mean by "speaker tuning." So far the info provided by JBL has been pretty limited.
[email protected] 02-11-2015 01:53 AM
What, No built-in amp? Time to bring out the Lepai!
Hifisound 02-11-2015 10:55 AM
I guess no measurements out yet....
Zzzzz... 02-11-2015 12:44 PM
No official measurements are available as yet but the rumor is that they measure extremely well:
http://www.audioheritage.org/vbullet...l=1#post369867
Hifisound 02-12-2015 10:42 AM
Though no 3rd party measurements were seen for the earlier 63xx series....
Zzzzz... 02-14-2015 05:52 PM
Not really sure what you are getting at. Even if no third party measurements end up being published for these new monitors, there should be plenty of people giving their thoughts on them once they become available. If they sound anywhere as good as they apparently measure, then I would imagine they will be quite popular.
Hifisound 02-14-2015 08:27 PM
Just an observation . No offense intended :)
Zzzzz... 02-14-2015 10:39 PM
^^^ None taken :) Prior to the 7 series, the LSR6328Ps were one of the few speakers I'd seriously been interested in. Part of the lack of third party measurements could be down to the fact
1. they first came out quite a while ago - perhaps back then measuring gear was not as readily available / cheap as it is today
2. perhaps its not that unusual for a speaker not to have third party measurements made - to do a really worthwhile job of it you would need access to an anechoic chamber, which would be quite costly, and it would also be pretty time consuming
Swolephile 02-18-2015 02:30 AM
What will the price be for the 708i?
dan1210 02-18-2015 06:14 AM
Any more news on these chaps? Im in the uk and info is scarce to say the least, i reckon these could be perfect for home theatre (dedicated room)
Price and availability would be nice to know...
beastaudio 02-24-2015 12:12 PM
With the little 3 series priced at $250 and being powered, I am hoping these come in under 4 digits, but I have no clue at this point...
Zzzzz... 02-24-2015 12:41 PM
Prices were listed here but have since been removed:
705i $549 (reduced from $687.50)
708i $1249 (reduced from $1500)
beastaudio 02-24-2015 12:54 PM
Hmm, I guess that is about right. I'd be curious still how the 708i stacks up against the 6332
Zzzzz... 02-24-2015 06:09 PM
Yeah I'm also really keen to learn how these stack up to the older 6328 and 6332, as well the M2. It's sort of strange but the 6332s don't get mentioned here that often. I would of thought that they would be more popular.
beastaudio 02-25-2015 06:48 AM
After reading through the papers and spec sheets on it, I am pretty surprised myself as well....
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
