AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Speakers (https://www.avsforum.com/forum/89-speakers/)
-   -   Need New Center channel to replace a Paradigm CC150 (https://www.avsforum.com/forum/89-speakers/1878521-need-new-center-channel-replace-paradigm-cc150.html)
hometheaterlove 02-03-2015 09:31 AM
So its time to find a center channel or fix my paradigm CC150 the foam has totally detached or rotted out. Not sure which.
Local home theater guys can refoam for $75. Online i can get a Athena AS-C1 for about a 100 which will match my other speakers AS-B1 all around.
I know the center needs to be the quality since it does so much. I do more movies then music but do listen to music here and there.
I saw a MTX TFE60C on sale and I want to keep the Center channel in the $100 range or less so the wife doesn't flip out. (we just got married so got be good)
AS-C1 would be a good match would it be worth it to get something like the MTX which has 6" woofers ??
Any recommendations of Centers would be great. Im looking used as i would rather have a older high end product then a new not so nice product on the lower end.
Thanks in advance!!
Transmaniacon 02-03-2015 09:39 AM
The best center choice is the one that matches your front speakers. If you can get that Athena center for $100, I'd jump on that.
hometheaterlove 02-03-2015 10:02 AM
So getting something a little bigger like the MTX is a bad idea? It's newer ans has warranty that's my only concern.
Since I barely got a year out of this paradigm.
Transmaniacon 02-03-2015 10:25 AM
You are going to have mis-matched speakers, and this leads to issue with sound panning across the front. Also your receiver will lower it's output to match the fronts, so a bigger speaker isn't going to work any better. Not to mention, I have never heard of MTX speakers.
I am assuming you got the Paradigm used, generally you can go a long time before a refoam, so perhaps the speaker wasn't stored properly before you.
Another option is to get the Paradigm refoamed, and keep an eye out for some matching Paradigm fronts.
hometheaterlove 02-03-2015 11:05 AM
Thanks I'm gonna try to grab the Athena since my wife has built custom stands for the other speakers.
Very much appreciated!!!
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
