Help me find the best ht solution - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #61 of 61 Old 04-22-2015, 01:40 PM
RayGuy's Avatar
Quoted: 3338 Post(s)
Liked: 3133
Originally Posted by aludum View Post
Can you please compare the sound quality of these speakers? Do you have any other good speaker in your mind?
Depends on which brands are available to you in India. Do some research of your options.
As to comparing speakers, all of the ones you listed are of good quality and would be a bit less "in your face" than the Polks. Polks have a forward sound, the others will be a bit more laid back, by varying degrees. Being more specific than that is just a waste of time ... you need to hear them for yourself.
aludum likes this.
RayGuy is online now
Reply Speakers
av receiver , home audio , home cinema , speaker , speaker advice
