Just purchased a pair of JBL 4722n speakers. - Page 150 - AVS Forum | Home Theater Discussions And Reviews
 3118Likes
post #4471 of 7396 Old 05-01-2016, 01:33 PM
Frohlich's Avatar
Quoted: 1972 Post(s)
Liked: 2151
Originally Posted by Molon_Labe View Post
Yes, I am going to order two more on Monday
Frohlich is offline
post #4472 of 7396 Old 05-01-2016, 02:10 PM
Claybe's Avatar
Quoted: 225 Post(s)
Liked: 86
Don't you need 4 more?!?
Claybe is offline
post #4473 of 7396 Old 05-01-2016, 02:24 PM
jasonr93's Avatar
Quoted: 47 Post(s)
I think so. Listening to Dire Straits Money for Noting I could detect Sting's voice sounding smoother at the beginning when when he sings, "I want my....I want my MTVvvv".
So that would mean dialogue in movies as well? Just concerned about the dips in the graphs posted in the upper frequencies, as the stock cd doesn't dip where the 2435h-sl does. Just thinking to myself that a flatter response would be more of an accurate reproduction in sound than one that dips. Just my thoughts and opinions on it, not trying to state facts.
jasonr93 is offline
post #4474 of 7396 Old 05-01-2016, 05:54 PM
Claybe's Avatar
Quoted: 225 Post(s)
Liked: 86
No, I am dropping down to two surrounds instead of four. I like the presentation better in my room.
I am assuming you are getting rid of the sides? You are going 5.2 then? Are you keeping the SC8s? Are you going to try the attentuators first?
Claybe is offline
post #4475 of 7396 Old 05-01-2016, 07:21 PM
notnyt's Avatar
Quoted: 3731 Post(s)
Liked: 3705
they measure and sound better than the 2432h all around
notnyt is offline
post #4476 of 7396 Old 05-01-2016, 09:58 PM
jasonr93's Avatar
Quoted: 47 Post(s)
Even without EQ? As I myself wouldn't be messing with that.
jasonr93 is offline
post #4477 of 7396 Old 05-01-2016, 10:00 PM
notnyt's Avatar
Liked: 3705
especially without eq, you should read my post on them with all the details
notnyt is offline
post #4478 of 7396 Old 05-01-2016, 10:18 PM
jasonr93's Avatar
Quoted: 47 Post(s)
Yeah, I'm trying to go back to find and re read all the comments of everyone's opinion on them. Just to get a general idea, which so far everyone is in an agreement with the upgrade being much more preferred. Did you also say that the 2453h-sl requires different size screws to swap out the stock cd?
jasonr93 is offline
post #4479 of 7396 Old 05-02-2016, 04:05 AM
Frohlich's Avatar
Liked: 2151
Notnyt was kind enough to post the required screws. The stock 2432H screws are too long. I ended leveraging his info and just ordered them from Amazon and it worked like a charm.
http://www.amazon.com/Socket-Screws-...ilpage_o04_s00
Frohlich is offline
post #4480 of 7396 Old 05-02-2016, 09:16 AM
beastaudio's Avatar
Quoted: 5506 Post(s)
Liked: 5324
EDIT: Your listing is OO stock. and, Beast made a bad suggestion to use the 1 1/4" screws. Do not use.
beastaudio is offline
post #4481 of 7396 Old 05-02-2016, 09:47 AM
jasonr93's Avatar
Quoted: 47 Post(s)
Does anyone know if it is 1" or 1 and 1/4"? I would like to know so I don't purchase the wrong item in the future.
jasonr93 is offline
post #4482 of 7396 Old 05-02-2016, 09:51 AM
notnyt's Avatar
Liked: 3705
Pretty sure I covered this...
2453H-SL INFORMATION
LTD02 likes this.
notnyt is offline
post #4483 of 7396 Old 05-02-2016, 10:02 AM
jasonr93's Avatar
Quoted: 47 Post(s)
Thank you for the link. With so many pages in the thread it's hard to remember which page you had posted all the info on. So 1" or 7/8" works. Thanks again.
jasonr93 is offline
post #4484 of 7396 Old 05-02-2016, 10:03 AM
notnyt's Avatar
Liked: 3705
yep, thread is active and it gets buried. search works tho
LTD02 likes this.
notnyt is offline
post #4485 of 7396 Old 05-02-2016, 10:13 AM
beastaudio's Avatar
Liked: 5324
I edited my post due to misinformation.
post #4486 of 7396 Old 05-02-2016, 10:18 AM
notnyt's Avatar
Liked: 3705
What I was surmising however was, the 1" brand is out of stock via amazon. You took your 1.5" stock ones and ground them down by 1/4", therefore, 1 1/4" should also work fine, which are in fact in stock. If you feel differently, I will go back and edit my post to save anyone from misinformation.
1 1/4" is a little close, makes it annoying to get on and if any of the 2453h-sl aren't machined 100% correctly, may cause an issue. 1" or 7/8" is much better.
notnyt is offline
post #4487 of 7396 Old 05-02-2016, 10:46 AM
Frohlich's Avatar
Liked: 2151
I ordered the 1" from my Amazon link above and confirm they work perfectly (sorry they are out of stock now..didn't realize that when I posted the link).
LTD02 likes this.
Frohlich is offline
post #4488 of 7396 Old 05-02-2016, 11:39 AM
COACH2369's Avatar
Quoted: 1168 Post(s)
Liked: 986
Sounds like making the change to the CD will only help the overall performance of the speaker.
I will definitely keep the upgrade in mind when the timing is right....or when I know I will have some time to take the screen wall apart.
If I was ordering some 4722's, I would grab some of the CD's and change them out right away...seems like a no brainer.
COACH2369 is offline
post #4489 of 7396 Old 05-02-2016, 03:03 PM
Molon_Labe's Avatar
Quoted: 3206 Post(s)
Liked: 3850
Alright boys, I am all in and keeping the side surrounds. Four 2453H-SL ordered today.
Scott Simonian, LTD02 and Gooddoc like this.
AVP - Trinnov Alt16
Speakers - JBL M2 (3), JBL 708p (4), JBL 705i (4)
Subs - (2) Deep Sea Sound 24" & (2) Dual Stereo Integrity 18"
Video - Sony 55es
Screen - Seymour 127" A/T 16:9
Molon_Labe is online now
post #4490 of 7396 Old 05-02-2016, 03:10 PM
jasonr93's Avatar
Quoted: 47 Post(s)
So if I don't mind the highs on the stock cd and listen to music a little bit, would you say that upgrading to the 2453h-sl I would hear a difference or benefit personally?
jasonr93 is offline
post #4491 of 7396 Old 05-02-2016, 03:11 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5985 Post(s)
Liked: 5114
Yay!
Scott Simonian is offline
post #4492 of 7396 Old 05-02-2016, 03:14 PM
Molon_Labe's Avatar
Liked: 3850
Yay!
If we ever meet, you owe me large quantities of wine or beer because keeping you approved has cost me
Scott Simonian likes this.
AVP - Trinnov Alt16
Video - Sony 55es
post #4493 of 7396 Old 05-02-2016, 04:05 PM
Bass Enabler
Liked: 5114
Deal.
post #4494 of 7396 Old 05-02-2016, 04:07 PM
jasonr93's Avatar
Quoted: 47 Post(s)
Haha. Just have the what ifs.. and if the benefits are something that already don't mind over the stock cd. The highs and listening to music here and there. Could always try them, though I doubt they accept returns.
jasonr93 is offline
post #4495 of 7396 Old 05-02-2016, 04:52 PM
notnyt's Avatar
Liked: 3705
Pretty sure they'd sell almost instantly on ebay/avs
notnyt is offline
post #4496 of 7396 Old 05-02-2016, 04:54 PM
Molon_Labe's Avatar
Liked: 3850
Buy them and if you don't like them offer @COACH2369 a deal on them
AVP - Trinnov Alt16
Video - Sony 55es
post #4497 of 7396 Old 05-02-2016, 05:12 PM
jasonr93's Avatar
Quoted: 47 Post(s)
Yeah, both of those options are good. Just might consider it. Is speaker exchange the main place everyone is ordering these?
jasonr93 is offline
post #4498 of 7396 Old 05-02-2016, 07:54 PM
Claybe's Avatar
Quoted: 225 Post(s)
Liked: 86
HA! I told you so . I knew you had it in you!!!
Molon_Labe likes this.
Claybe is offline
post #4499 of 7396 Old 05-02-2016, 08:33 PM
Quoted: 157 Post(s)
Liked: 69
If you don't see a big improvement in your surrounds I'll buy 3 off of you for reassurance
podboy is offline
post #4500 of 7396 Old 05-03-2016, 03:27 AM
COACH2369's Avatar
Liked: 986
I approve this comment.
Reply Speakers
