Just purchased a pair of JBL 4722n speakers. - Page 175 - AVS Forum | Home Theater Discussions And Reviews
 3118Likes
post #5221 of 7396 Old 10-12-2016, 02:14 PM
Liked: 0
cws74 is offline
post #5222 of 7396 Old 10-15-2016, 12:07 PM
LTD02's Avatar
Quoted: 2915 Post(s)
Liked: 3611
@notnyt
not sure if you ever got your answer back on noise.
this page shows the specs for the opendrc-an as 108db dynamic range. i'm assuming that is referenced to 2v max output. if so, that puts the noise at about 8 uvrms (microvolts), which is pretty good.
source: https://www.minidsp.com/products/ope.../summary-table
with ~20x gain in the ncore, that is only ~160 uvrms noise (not counting whatever is coming in upstream from your source/avr) which gives about -85db noise at the speakers. should be fine.
Listen. It's All Good.
LTD02 is offline
post #5223 of 7396 Old 10-15-2016, 12:32 PM
LTD02's Avatar
Liked: 3611
also, here is a measurement of the opendrc-da8, not what you are looking at, but fwiw. look like the 1khz noise is getting down near the limits of his measuring gear, and appears to be somewhere in the ballpark of -127dbv, which of course would be about 1 uvrms.
https://www.minidsp.com/forum/hardwa...rc-noise#23945
second thought. maybe the specs in the comparo chart above are the worst case including the apparent noise spike at 60hz. if so, then the specs may be overly conservative at least as far as estimating noise from the horns goes.
all these numbers, specs, and measurements...and somehow it all still ends up having an order of magnitude variation in it (aka, its a crapshoot). lol.
LTD02 is offline
post #5224 of 7396 Old 10-15-2016, 12:59 PM
notnyt's Avatar
Quoted: 3728 Post(s)
Liked: 3697
lol yah, I'm probably gonna order them. I can also remove r141 from the ncore to drop the gain, and thus noise.
LTD02 likes this.
notnyt is offline
post #5225 of 7396 Old 10-16-2016, 05:07 PM
Quoted: 157 Post(s)
Liked: 69
First listen, blind buy because of you guys. Can't thank you enough! Dave Matthews live at radio city is like I'm in the front row! HUGE SOUNDSTAGE!!
podboy is offline
post #5226 of 7396 Old 10-16-2016, 05:09 PM
Claybe's Avatar
Quoted: 225 Post(s)
Liked: 86
You are going to LOVE them!!! Wait until you break them in and they open up!
jjackkrash likes this.
Claybe is offline
post #5227 of 7396 Old 10-16-2016, 05:14 PM
Quoted: 157 Post(s)
Liked: 69
I have yet to put my 150" falcon screen yep yet. Should I just buy the 2453H-SL CD's now? Money isn't a big deal just wanna know if it's worth it. The speakers only have 10 min on them so I might let them break in a bit
podboy is offline
post #5228 of 7396 Old 10-16-2016, 05:16 PM
Claybe's Avatar
Quoted: 225 Post(s)
Liked: 86
These speakers are incredible as is. If you have diamond ears and money is not a problem then get the upgraded CDs.
Claybe is offline
post #5229 of 7396 Old 10-16-2016, 06:05 PM
jjackkrash's Avatar
Quoted: 2223 Post(s)
Liked: 2328
How wide is that stage?
jjackkrash is offline
post #5230 of 7396 Old 10-16-2016, 06:53 PM
Quoted: 157 Post(s)
Liked: 69
14 feet wide
podboy is offline
post #5231 of 7396 Old 10-16-2016, 07:16 PM
notnyt's Avatar
Liked: 3697
awesome. if you listen to music, swap the cds
notnyt is offline
post #5232 of 7396 Old 10-18-2016, 12:24 AM
notnyt's Avatar
Liked: 3697
neutrik all the way...
just finished machining the back plates (not pictured). these should hopefully be live tomorrow. I have the harnesses made, just need to mount the neutrik connectors and connect everything up. more to come...
Scott Simonian and Gooddoc like this.
notnyt is offline
post #5233 of 7396 Old 10-18-2016, 05:44 AM
12B4A's Avatar
Quoted: 595 Post(s)
Liked: 514
I love amp building porn. Why did you decide to go with neutrik power connectors?
Life is Lambertian
12B4A is online now
post #5234 of 7396 Old 10-18-2016, 09:59 AM
notnyt's Avatar
Liked: 3697
because c13/c14 isn't locking and is more annoying to cut the hole for
notnyt is offline
post #5235 of 7396 Old 10-18-2016, 02:10 PM
Quoted: 801 Post(s)
Liked: 463
Will these speakers have to run as active speakers if I do the cd upgrade?
LumensLover is offline
post #5236 of 7396 Old 10-18-2016, 02:33 PM
notnyt's Avatar
Liked: 3697
no, the upgraded cds work better with the xover than stock.
notnyt is offline
post #5237 of 7396 Old 10-18-2016, 02:50 PM
Quoted: 801 Post(s)
Liked: 463
Oh wow. Where can I purchase them? Also, is there instructions in this thread on how to install them?
post #5238 of 7396 Old 10-18-2016, 03:09 PM
COACH2369's Avatar
Quoted: 1168 Post(s)
Liked: 986
I just returned your PM...
Most of us have purchased both the speakers and CD's from Full Compass.
@Frohlich can probably help you with installing them. He did his in a few minutes. It seems like an easy process for sure.
You will love these speakers!
Might I suggest the SCS8's for surround duty. They are simply marvelous!
COACH2369 is offline
post #5239 of 7396 Old 10-18-2016, 03:12 PM
notnyt's Avatar
Liked: 3697
https://www.avsforum.com/forum/89-spe...l#post42209001
notnyt is offline
post #5240 of 7396 Old 10-18-2016, 05:18 PM
Quoted: 157 Post(s)
Liked: 69
After one complete night of listening to the 4722's (without subs) crossed over to 70 hz my ears are a bit fatigued. I had my old speakers crossed to 70 hz and didn't bother to change the settings. I only have been listening to acoustic music however so there isn't much bass needed. I think I'm going to buy the 2453H-SL to see if I can mellow them out a bit. I listen to a lot of music 50/50 music/movies. It might be just that the speakers are not broken in yet but I am curious.
podboy is offline
post #5241 of 7396 Old 10-18-2016, 05:29 PM
notnyt's Avatar
Liked: 3697
nah, the 2432h is just fatiguing, the 2453h-sl is a lot better. It's also a bit bright using the 2432h without EQ. The upgrade clears that right up. If you do, looking forward to more feedback.
notnyt is offline
post #5242 of 7396 Old 10-18-2016, 05:45 PM
Quoted: 157 Post(s)
Liked: 69
"Hey Podboy you should blind buy these L/R/C for $3500....oh wait the holy grail will only cost $900 more with upgraded CD's!" They are much better than the htib KEF 3005se speakers. The brightness just got to me after a few hours. Hopefully the upgrading the cds will help me forget about speakers for a while.
podboy is offline
post #5243 of 7396 Old 10-18-2016, 08:59 PM
notnyt's Avatar
Liked: 3697
you can sell the original CDs for about $150 a piece fairly easily from what I've seen
notnyt is offline
post #5244 of 7396 Old 10-19-2016, 02:04 AM
Quoted: 157 Post(s)
Liked: 69
I do admit the stock 4722s are unlike anything I've ever heard. My brother and dad don't think it can get much better. I'm just curious
podboy is offline
post #5245 of 7396 Old 10-19-2016, 02:28 AM
Quoted: 157 Post(s)
Liked: 69
Looking for one 2453h-sl if anyone sees one floating around please lemme know. Thanks!
podboy is offline
post #5246 of 7396 Old 10-19-2016, 04:48 AM
Frohlich's Avatar
Quoted: 1972 Post(s)
Liked: 2151
I answered the several PMs I got last night. Knew there must be a new bevy of posting on the 4722 thread
A few thoughts:
1)The upgrade is very reasonable in cost and totally worth it from a performance stanpoint...especially if you sell the old CD on ebay it becomes a dirt cheap upgrade.
2)The waveguide influences the sound and takes out the room more than most traditional speaker designs
3)Experiment with room correction and what sounds best to your ears. I like the sounds of the 4722s so much I actually prefer to run Audyssey in L/R bypass and use it mostly for bass frequency correction.
Frohlich is online now
post #5247 of 7396 Old 10-19-2016, 05:37 AM
NWCgrad's Avatar
Quoted: 1283 Post(s)
Liked: 1332
There is a reason why JBL uses a different CD on the High Power Screen Arrays (5 series models), the 2452H-SL is far superior to the stock CD'S on the 4722. These speakers are designed to a price point, and they succeeded exceptionally well I think.
The 2453H-SL is pretty similar in performance to the higher priced 2452H-SL.
______________________________________
Home Theater:
https://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #5248 of 7396 Old 10-19-2016, 06:30 AM
Gooddoc's Avatar
Quoted: 3687 Post(s)
Liked: 3279
I've thought that about every speaker I've owned.
Seriously. That's not a snarky comment, just a truth. That's not to say you won't feel the same way in 6 months or a year, but you may hear things then that you don't now. It takes me that long to discover issues. I'm not a golden ear
So if you're curious, keep the stock CD's and decide for yourself in a half a year what you think needs improvement. If nothing, then you just saved yourself a bunch of money.
Gooddoc is offline
post #5249 of 7396 Old 10-19-2016, 09:24 AM
beastaudio's Avatar
Quoted: 5503 Post(s)
Liked: 5317
Nah man, don't listen to that cool headed fool. Buy the CD's, upgrade all the things!
Gooddoc and ChopShop1 like this.
beastaudio is offline
post #5250 of 7396 Old 10-19-2016, 09:34 AM
Quoted: 157 Post(s)
Liked: 69
I know the 2452H-SL are in jbls high power screen arrays and the 2453H-SL performs similarly, but what speaker does the 2453H-SL go in? Is it a higher end speaker?
podboy is offline
Reply Speakers
