Just purchased a pair of JBL 4722n speakers. - Page 177 - AVS Forum | Home Theater Discussions And Reviews
 3098Likes
post #5281 of 7379 Old 10-30-2016, 02:46 AM
notnyt's Avatar
Quoted: 3725 Post(s)
Liked: 3691
Messing around with the 2453H-SL. A 1/2in spacer cleared up the dropout at 12khz on the STX825 wave guide. Got the opendrc-an's running and some filters plugged in. I was testing different auto-adjustment levels in different frequency ranges, hence why it's not as smooth on the left.
notnyt is offline
post #5282 of 7379 Old 10-30-2016, 06:07 AM
chrapladm's Avatar
Quoted: 1099 Post(s)
Liked: 443
So do you have the mid/high on a passive Xo and using the opendrc's two channels for EQ?
chrapladm is offline
post #5283 of 7379 Old 10-30-2016, 01:34 PM
notnyt's Avatar
Liked: 3691
100uf cap and an autoformer for 12db of padding. Using the opendrc for the filtering, one opendrc per speaker.
notnyt is offline
post #5284 of 7379 Old 10-30-2016, 02:03 PM
MKtheater's Avatar
Quoted: 2326 Post(s)
Liked: 2272
Is that at the LP or 1 meter? I never liked a ruler flat response at the LP in my room. Ruler flat at the speaker and letting my room do its thing has always sound best to me in my room.
MKtheater is online now
post #5285 of 7379 Old 10-30-2016, 04:17 PM
notnyt's Avatar
Liked: 3691
its 1 foot. not the final curve, just messing around.
notnyt is offline
post #5286 of 7379 Old 10-30-2016, 05:02 PM
MKtheater's Avatar
Liked: 2272
Have you listened to it yet? How does your room effect the response?
post #5287 of 7379 Old 10-30-2016, 05:19 PM
notnyt's Avatar
Liked: 3691
I don't have the rest of the parts yet
notnyt is offline
post #5288 of 7379 Old 10-30-2016, 05:36 PM
MKtheater's Avatar
Liked: 2272
Oh, well technically you can't get a better start.
post #5289 of 7379 Old 10-30-2016, 05:38 PM
notnyt's Avatar
Liked: 3691
waiting for the woofer, then will build enclosure
notnyt is offline
post #5290 of 7379 Old 11-01-2016, 03:53 PM
notnyt's Avatar
Liked: 3691
*sigh* opendrc-an units gonna have to go back. Not happy with the noise level. I can hook my NC400 DIRECTLY up to a CD and its almost completely silent with my ear up to it. Adding a 12db autoformer inline knocks it down to almost completely undetectable. With the opendrc hooked up even with the autoformer, I can still here it 6 feet away. I guess I'm going to build a PC based solution.
Also, the opendrc's produce a disturbing amount of voltage on startup over a long duration. I'll grab a capture of it at some point.
notnyt is offline
post #5291 of 7379 Old 11-01-2016, 04:49 PM
dwaleke's Avatar
Quoted: 1412 Post(s)
Liked: 719
I'm not surprised to hear this.
Every minidsp unit I've tried adds audible noise when you run them in passthrough mode.
You really need volume control post dsp device which isn't feasible with multiple devices and an active setup.
dwaleke is offline
post #5292 of 7379 Old 11-01-2016, 05:21 PM
notnyt's Avatar
Liked: 3691
suggestions for interfaces I can run with brutefir?
notnyt is offline
post #5293 of 7379 Old 11-01-2016, 07:25 PM
dwaleke's Avatar
Liked: 719
I've never used brutfir.
Jriver with audiolense xo is by far the best setup I've had. Ran mains 3-way active but even passive was great.
Very limited input sources though.
You can run jriver for audio in/out only but I could never get latency low enough with the motu 16a. I think it was jriver's issue.
1201 is running a Linux pc based solution iirc.
dwaleke is offline
post #5294 of 7379 Old 11-01-2016, 08:13 PM
notnyt's Avatar
Liked: 3691
yep, helped him with some stuff on it a bit. Likely the path I'm going to go since I can get a linux box to boot very quickly. just trying to find a good interface with a low noise floor. Might try a bunch of emu 0404s. will see.
notnyt is offline
post #5295 of 7379 Old 11-01-2016, 09:16 PM
mitchco's Avatar
Quoted: 73 Post(s)
Liked: 132
I have tried several audio DSP softwares over the past 5 years, with Audiolense and Acourate being the top two in my opinion. Audiolense, easier to use and setup, Acourate more flexibility and power as it is more of a digital audio toolkit.
I use JRiver's convolution engine and 64 bit digital volume to control my active 3 way horn system. If playing videos from within JRiver, the latency of the linear phase FIR filter is taken into consideration and there are no lip sync issues. With Acourate, one can linearize and time align the drivers, in addition to frequency and excess phase room correction. I am happy with the result.
I don't use https://www.ludd.ltu.se/~torger/brutefir.html but I know several that do and are happy with the results. Attached is an older doc on how to set up BruteFIR convolution on a USB stick. There is considerable BruteFIR info on the Acourate forum at: https://groups.yahoo.com/neo/groups/acourate/info
mitchco is offline
post #5296 of 7379 Old 11-01-2016, 09:56 PM
notnyt's Avatar
Liked: 3691
rofl the pdf doesn't actually talk about how to setup brutefir, just some basic linux stuff. I do that for a living and a hobby so it's cake for me to get it rolling. I was using FIR designer to get some filters generated for the opendrcs, should be able to use the same for brutefir and specify a delay for that. I think I'm going to order a 16a tonight so I can get started on that. I wonder how much processing power it'll take to handle this.
chrapladm likes this.
notnyt is offline
post #5297 of 7379 Old 11-01-2016, 10:07 PM
notnyt's Avatar
Liked: 3691
I looked at brutefir config, looks very straight forward. Looks like modern hardware will easily handle it at very low latency levels. Might grab a NUC or something for this project.
notnyt is offline
post #5298 of 7379 Old 11-01-2016, 10:11 PM
mitchco's Avatar
Quoted: 73 Post(s)
Liked: 132
Ha, like I say I don't BruteFIR. Can the FIR designer gen filters like: http://files.computeraudiophile.com/...WhitePaper.pdf
mitchco is offline
post #5299 of 7379 Old 11-01-2016, 10:14 PM
notnyt's Avatar
Liked: 3691
yeah, its pretty slick. You can check it out without paying for it, just can't export anything.
https://eclipseaudio.com.au/fir-designer/
notnyt is offline
post #5300 of 7379 Old 11-01-2016, 10:27 PM
mitchco's Avatar
Quoted: 73 Post(s)
Liked: 132
Slick it is. Acourate similar. Are you planning minimum or linear phase xo's?
mitchco is offline
post #5301 of 7379 Old 11-01-2016, 10:27 PM
notnyt's Avatar
Liked: 3691
gonna move this discussion to my thread to stop filling the 4722 thread with this
https://www.avsforum.com/forum/155-di...e-journey.html
notnyt is offline
post #5302 of 7379 Old 11-02-2016, 08:58 AM
Quoted: 801 Post(s)
Liked: 462
I can't fit another 4722n into my room due to low ceilings. Can't use AT screen due to need for alr screen plus my room is only 18ft deep. Any suggestions for center speaker to go with JBL 4722n pair with upgraded cds?
LumensLover is offline
post #5303 of 7379 Old 11-02-2016, 09:46 AM
notnyt's Avatar
Liked: 3691
I'm diying 2453H-SL over a 265h-2 on the STX825 waveguide to match the 4722. Still waiting on the driver to ship. Currently running a 3677 under the screen which works fine after EQ.
notnyt is offline
post #5304 of 7379 Old 11-02-2016, 11:42 AM
notnyt's Avatar
Liked: 3691
opendrc voltage across + and - on startup and shutdown.
notnyt is offline
post #5305 of 7379 Old 11-03-2016, 02:11 AM
Kwikas's Avatar
Quoted: 54 Post(s)
Can anyone who is looking to sell their 2432's and is willing to post them to Australia please PM me? Thanks
Kwikas is offline
post #5306 of 7379 Old 11-03-2016, 03:30 PM
Molon_Labe's Avatar
Quoted: 3072 Post(s)
Liked: 3701
I don't mind sending them to Australia. They currently are in @beastaudio possession while he does testing. When he is done, they can be shipped directly to you. Not sure how big of a hurry your in.
Chris
NWCgrad likes this.
Molon_Labe is online now
post #5307 of 7379 Old 11-03-2016, 07:55 PM
Kwikas's Avatar
Quoted: 54 Post(s)
Chris
Not in a hurry. PM me the price. Thanks Chris.
Kwikas is offline
post #5308 of 7379 Old 11-03-2016, 08:11 PM
Skylinestar's Avatar
Quoted: 1308 Post(s)
Liked: 268
what's up with minidsp and its noise problems that seem to be going on forever?
Skylinestar is offline
post #5309 of 7379 Old 11-03-2016, 08:12 PM
notnyt's Avatar
Liked: 3691
no idea... not a prob with my 2x8 on the subs ... since subs... but way too noisy for compression drivers, even padded 12db.
dwaleke likes this.
notnyt is offline
post #5310 of 7379 Old 11-04-2016, 11:49 AM
Quoted: 157 Post(s)
Liked: 69
I have 3 available with less than 5 hours on them. PM me if you want them.
podboy is offline
Reply Speakers
