Just purchased a pair of JBL 4722n speakers. - Page 234 - AVS Forum | Home Theater Discussions And Reviews
 3097Likes
post #6991 of 7373 Old 11-02-2017, 05:21 PM
COACH2369's Avatar
Quoted: 1165 Post(s)
Liked: 984
Originally Posted by notnyt View Post
If one of you guys with upraded CDs are ever on long island, would be curious to get your take on how I have things setup with the Be phragms.
Your room is amazing and I would love the opportunity to hear how it sounds.
I think a lot of us made the jump due to your work and research, which was much appreciated.
@Frohlich , Road trip? You bring the tacos!
carp, Frohlich and femi like this.
COACH2369 is offline
post #6992 of 7373 Old 11-03-2017, 04:27 AM
Frohlich's Avatar
Quoted: 1960 Post(s)
Liked: 2129
Have you seen how big notnyt's subs are...we better bring a lot of taco's for the old port hole fit test!!!!!!
notnyt likes this.
Frohlich is online now
post #6993 of 7373 Old 11-24-2017, 02:53 PM
Quoted: 925 Post(s)
Liked: 268
Hey guys, can the JBL Sythesis SCL-4 be paired with 4722n? I am currently using Sc-8 for surrounds and surround back and also 4 on ceiling with 4722n as LCR. I don't have much space for surrounds. These JBL Sythesis SCL-4 flash with wall and won't get in the way. Wanted to know if they would be fine with 4722n? Also, does anyone know how much they const?
harrisu is offline
post #6994 of 7373 Old 12-06-2017, 07:46 AM
mitchco's Avatar
Quoted: 73 Post(s)
Liked: 132
Audiolense Digital Loudspeaker and Room Correction Software Walkthrough
I hope folks don't mind me posting a link to another site wrt JBL 4722's. I used Audiolense to optimise my 4722's:
- develop a linear phase digital XO for biamping.
- time align the drivers.
- smooth the frequency response using a linear phase target.
- use "room correction" to reduce non-minimum phase low frequency room reflections (i.e. reduce group delay).
- use "partial correction" for constant directivity waveguide equalization, but partial time domain correction.
Really happy with the 4722's - they pound the rock n roll that soothes my soul
carp, dgage and notnyt like this.
mitchco is online now
post #6995 of 7373 Old 12-25-2017, 04:56 AM
vitaminbass's Avatar
Quoted: 24 Post(s)
Harrisu, have you tried crossing at something like 50 Hz? In my opinion, with the huge headroom all the way down to 50 Hz...it would be worth a try. Crossing them over much higher is to some degree defeating the purpose of having such capable mains. I believe 4722s start rolling off not much below 50, this is mostly about protecting them from those occasional scenes with lots of low content...you have lots of cone area but not a ton of XMax.
vitaminbass is offline
post #6996 of 7373 Old 12-25-2017, 05:02 AM
Quoted: 24 Post(s)
Merry Christmas folks,
I have read about 25% of this thread but I'm sure I missed alot too...
Is there a standout choice with the same characteristics as the 4722s but in a smaller package, maybe one 15? I'm pushing it for having room for these as my width is only 12.5' and I am only back around 8'-12' from the screen. I definitely want the midbass slam but don't need that much headroom or physical size.
post #6997 of 7373 Old 12-25-2017, 05:22 AM
Frohlich's Avatar
Liked: 2129
post #6998 of 7373 Old 01-04-2018, 10:49 AM
realtight's Avatar
Quoted: 47 Post(s)
Liked: 98
Was anyone able to figure out the 4722 active settings setup for something we can mimic in a minidsp? I know this post here started playing around with replicating the crown dsi variable q shelf filters but didn't see anything further.
Also what are the active jbl 4722's using for the CD protection?
I have custom 4722n's with the upgraded cd's and 2225h's for the woofers. I currently have a minidsp with mic and two adcom gfa-555ii that I would love to experiment with...
realtight is offline
post #6999 of 7373 Old 01-04-2018, 12:17 PM
Wrager's Avatar
Quoted: 293 Post(s)
Liked: 175
http://cn.jblpro.com/www/products/in...5#.Wk6LDN-nGUk
It uses the same CD and very similar 15" woofer, but the cost is very high. I have the older 6215/95 and it has a really pleasant sound.
Gearpro likes this.
Wrager is offline
post #7000 of 7373 Old 01-04-2018, 06:55 PM
donivan's Avatar
Quoted: 38 Post(s)
Liked: 43
My room is 12'9" wide and I'm at 10' from the screen with a trio of 4722s behind an AT screen and it works beautifully. I think part of the 4722s magic is it's large waveguide which allows for a lower crossover. It seems like the PA options with similar parts use a much higher crossover point. If your are open to assembling a speaker there is the DIYSG 3 way Titan which is highly regarded. I believe QSC makes a cinema single 15.
donivan is online now
post #7001 of 7373 Old 01-05-2018, 04:23 AM
COACH2369's Avatar
Liked: 984
Originally Posted by Frohlich View Post
+2
post #7002 of 7373 Old 01-19-2018, 04:45 PM
adrummingdude's Avatar
Quoted: 1103 Post(s)
Liked: 768
Originally Posted by sandipb View Post
Why pay that price for used ones when you could get brand new ones for only about $140 more per speaker from Southern California Cinetech, check the site
https://socalcinetech.com/?
I've come across them before while perusing online. Their prices seem too cheap to be legit. Has anyone had any experience with them?
HT: KEF Reference 1 - Anthem AVM60 & MCA525 - Martin Logan Focus - DefTech XTR-20BP - Dual SVS SB16 Ultra
Office 2CH: KEF LS50 - Crown - Bluesound
Stage: Allen & Heath Dlive s5000 - Westone AMPRO 30 - AKG mics - Crown Amps
WAF is currently at DEFCON ORANGE
adrummingdude is offline
post #7003 of 7373 Old 01-19-2018, 04:54 PM
chrapladm's Avatar
Quoted: 1099 Post(s)
Liked: 443
Not sure what price your looking for but there seem to be two places that most of us on this thread have used for purchasing JBL products. I used Socal and they were great. I will be ordering some more stuff in the future and may just try the other company when the time gets closer. But you cant go wrong with either places that have been mentioned here in this thread.
adrummingdude and sandipb like this.
chrapladm is online now
post #7004 of 7373 Old 01-19-2018, 04:56 PM
mitchco's Avatar
Quoted: 73 Post(s)
Liked: 132
Yup, Michael at Socalcinetech sold me the 4722's at that price and also sold me the 2453h-SL CD upgrades too. All good.
post #7005 of 7373 Old 01-19-2018, 09:37 PM
carp's Avatar
Quoted: 3500 Post(s)
Liked: 3159
I bought 3 4722n's from them for 1150 shipped each and the upgraded CD's (can't remember exact price but at the time was the cheapest I could find) and 10 SCS8's at 315 shipped each. Legit and great customer service.
carp is offline
post #7006 of 7373 Old 01-20-2018, 10:59 AM
donivan's Avatar
Quoted: 38 Post(s)
Liked: 43
Another satisfied customer here! Recently bought some SL diaphragms at a great price. They did take a couple of months but that's because they were out of stock at JBL.
Frohlich and adrummingdude like this.
post #7007 of 7373 Old 01-21-2018, 07:35 AM
boothman's Avatar
Quoted: 94 Post(s)
Liked: 41
Also bought 5 CD's from SoCal. no problem. Plan on ordering more stuff from them.
boothman is offline
post #7008 of 7373 Old 01-21-2018, 08:50 AM
Frohlich's Avatar
Liked: 2129
The 4722 thread lives!!!! I have an AVS member coming over today for a demo (think he already bought them and waiting for delivery). Best deal going in HT IMHO...especially with the upgraded CD.
COACH2369 likes this.
post #7009 of 7373 Old 01-25-2018, 03:29 AM
jlpowell84's Avatar
Quoted: 2013 Post(s)
Liked: 979
How is everyone? Anyone make any changes away from the 4722's? I still miss mine and may get a pair again!
Frohlich likes this.
jlpowell84 is offline
post #7010 of 7373 Old 01-25-2018, 06:29 AM
Quoted: 801 Post(s)
Liked: 462
If I get a dedicated home theater in my next home, I will definitely be purchasing another set of JBL Pro Cinema speakers.
LumensLover is offline
post #7011 of 7373 Old 01-25-2018, 09:44 AM
parapet's Avatar
Quoted: 64 Post(s)
What's "wrong" with your 215RTs?
parapet is offline
post #7012 of 7373 Old 01-25-2018, 02:20 PM
Molon_Labe's Avatar
Quoted: 3069 Post(s)
Liked: 3689
Nothing is wrong with them. 10:1 the only thing wrong is his incessant speaker addiction
Molon_Labe is offline
post #7013 of 7373 Old 01-26-2018, 05:51 AM
Frohlich's Avatar
Liked: 2129
Now its a party. We have JlPowell84, Lumenslover, Carp and Molon Labe on the thread...just like the good old days
carp, COACH2369 and Molon_Labe like this.
post #7014 of 7373 Old 01-26-2018, 07:08 AM
coolgeek's Avatar
Quoted: 1613 Post(s)
Liked: 890
Keep the thread alive guys.. one day i might have to try these JBLs out...
coolgeek is offline
post #7015 of 7373 Old 01-26-2018, 10:00 AM
beastaudio's Avatar
Quoted: 5487 Post(s)
Liked: 5288
I moved on. But not very far....I think you guys knew that already tho.
beastaudio is offline
post #7016 of 7373 Old 01-26-2018, 10:35 AM
Frohlich's Avatar
Liked: 2129
Hopefully in April I will get a first hand demo of those killer 4367's
post #7017 of 7373 Old 01-26-2018, 11:11 AM
beastaudio's Avatar
Liked: 5288
Hopefully? Better be a definitely.
post #7018 of 7373 Old 01-26-2018, 11:38 PM
coolgeek's Avatar
Liked: 890
My prediction: Beast will go right back to the 4722... (cause of mid bass bang)
coolgeek is offline
post #7019 of 7373 Old 01-27-2018, 04:45 AM
hv9200's Avatar
Quoted: 111 Post(s)
Liked: 71
Long time lurker here....Anyone in the New England area have a set of 4722’s that I can come demo? I have been on the fence for a while now and am just not convinced yet.
"although he walks among us, he is not one of us"
hv9200 is offline
post #7020 of 7373 Old 01-27-2018, 06:16 AM
COACH2369's Avatar
Liked: 984
I still stuck with JBL....but some will say I lack to the size to compete with what you guys have, BUT they make me happy.
It is on...I am already counting the days down until I get back from that weekend and figure out how to put 4367's in my room and explain to my wife why it is happening.
Reply Speakers
