Just purchased a pair of JBL 4722n speakers. - Page 243 - AVS Forum | Home Theater Discussions And Reviews
 3118Likes
post #7261 of 7396 Old 10-31-2018, 08:19 AM
Gooddoc's Avatar
Quoted: 3683 Post(s)
Liked: 3279
Ah, the itch. It's only a matter of time now till the scratch starts again.....
Frohlich likes this.
Gooddoc is offline
post #7262 of 7396 Old 10-31-2018, 08:32 AM
beastaudio's Avatar
Quoted: 5503 Post(s)
Liked: 5317
I think honestly Jeff has chronic poison ivy.
Frohlich, dgage and Gooddoc like this.
beastaudio is offline
post #7263 of 7396 Old 11-01-2018, 02:59 AM
COACH2369's Avatar
Quoted: 1168 Post(s)
Liked: 986
Perhaps...
COACH2369 is offline
post #7264 of 7396 Old 11-24-2018, 04:36 AM
jasonr93's Avatar
Quoted: 47 Post(s)
Is Anyone able to make me a couple of spacers for new cd's?
jasonr93 is offline
post #7265 of 7396 Old 11-24-2018, 12:05 PM
notnyt's Avatar
Quoted: 3728 Post(s)
Liked: 3697
If you can't find anyone to, send me a pm.
notnyt is offline
post #7266 of 7396 Old 11-24-2018, 12:22 PM
jasonr93's Avatar
Quoted: 47 Post(s)
Okay, thanks. I figured giving something for someone's time making it would be cheaper than buying the bits and wood.
jasonr93 is offline
post #7267 of 7396 Old 11-24-2018, 01:20 PM
notnyt's Avatar
Liked: 3697
Wood shouldn't cost more than like $10, and a bit is like $5-10, not too bad.
I 3d-printed a set of these recently and they came out good.
carp and Frohlich like this.
notnyt is offline
post #7268 of 7396 Old 11-24-2018, 01:47 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1781 Post(s)
Liked: 1702
Those look good and if you want to smooth out the throat, you should be able to use a very small amount of Acetone on a rag depending on what material (ABS) was used to print the part.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is offline
post #7269 of 7396 Old 11-24-2018, 01:53 PM
Frohlich's Avatar
Quoted: 1972 Post(s)
Liked: 2153
Thats awesome. Great job. Give me a refresher, what are the spacers for. Is it to correct a dip around 12khz...little rusty on this old conversation. I didn't user a spacer and upgrade to the 2453H SL.
Frohlich is online now
post #7270 of 7396 Old 11-24-2018, 01:54 PM
notnyt's Avatar
Liked: 3697
no need really
notnyt is offline
post #7271 of 7396 Old 11-24-2018, 01:56 PM
notnyt's Avatar
Liked: 3697
yes
notnyt is offline
post #7272 of 7396 Old 11-24-2018, 02:50 PM
Deep Sea Sound
dgage's Avatar
Liked: 1702
no need really
Looks good. What printer do you have?
David Gage
Deep Sea Sound
dgage is offline
post #7273 of 7396 Old 11-24-2018, 04:03 PM
notnyt's Avatar
Liked: 3697
400x400x450mm cartesian with dual extruders (e3d titans with volcano hot ends and 0.6 + 0.4mm olsson ruby nozzles). Using buildtak magnetic bed, 0.9 deg 2a motors driven by a duet2 wifi. I designed the majority of the parts on it at this point, but it started life as as gmax clone.
I'm considering a railcore build, but this works well enough and I'm saving funds currently.
dgage and jjackkrash like this.
notnyt is offline
post #7274 of 7396 Old 11-24-2018, 11:39 PM
jasonr93's Avatar
Quoted: 47 Post(s)
That's awesome. How much time/money does it take for you to print the spacers and also this ^ ^ (the image above)?
jasonr93 is offline
post #7275 of 7396 Old 11-25-2018, 09:42 AM
Deep Sea Sound
dgage's Avatar
Liked: 1702
You’re such a geek and I wish I didn’t understand anything you just wrote but I understood all of it.
I have a Sindoh 3DWox but designed a CoreXY-based printer with 16”^3 printer envelope. Haven’t had a chance to put it together yet but have all the parts. It would run off of a Duet2 as well with the e3d Kraken quad-print head. Will use 4 Bondtech QR extruders remotely to keep weight down on the print head.
notnyt likes this.
David Gage
Deep Sea Sound
dgage is offline
post #7276 of 7396 Old 11-25-2018, 09:57 AM
Molon_Labe's Avatar
Quoted: 3175 Post(s)
Liked: 3820
What just happened? Am I still on Earth? As someone who makes a living in IT, I feel very less now.
dgage, notnyt and jjackkrash like this.
Don't waste your money on a new set of speakers.....you get more mileage from a cheap pair of sneakers - Billy Joel
Molon_Labe is offline
post #7277 of 7396 Old 11-25-2018, 11:23 AM
Deep Sea Sound
dgage's Avatar
Liked: 1702
Would QoS over TCP and UDP make you feel better Mr. Networking Guru?
And we’ll say the 3D printer talk is related to the 4722 by way of the spacer for the updated CD. If Notnyt shares his file, I could also print spacers since my 3D printer sits idle too much as it is. Cost would be shipping and materials.
David Gage
Deep Sea Sound
dgage is offline
post #7278 of 7396 Old 11-25-2018, 11:26 AM
notnyt's Avatar
Liked: 3697
That D20 print was a test at higher quality - which failed. The slicer had some bugs which caused the infill to get printed twice in some areas and show through the walls. It took about 3-4 days to print, but I could print it much faster with some different settings.
The spacers take about 45 to 60 minutes to print. Probably about $5-10 in filament depending on what I use.
notnyt is offline
post #7279 of 7396 Old 11-25-2018, 11:33 AM
notnyt's Avatar
Liked: 3697
The spacers are trivial to model, but here it is anyway. You want to print with high wall thickness. 2-2.4mm should be good. Make sure the top/bottom layers are nice and smooth. Might even want to under extrude the top skin a little.
I was also gonna offer to mail it out for costs if unable to get elsewhere.
Molon_Labe likes this.
notnyt is offline
post #7280 of 7396 Old 11-25-2018, 11:42 AM
jjackkrash's Avatar
Quoted: 2223 Post(s)
Liked: 2328
I don't have any idea what any of that gibberish means, but now I really want one of those Federation issued food replicators.
jjackkrash is offline
post #7281 of 7396 Old 11-25-2018, 05:26 PM
Frohlich's Avatar
Liked: 2153
MMMMMM...sign me up David
BTW, Jeff might need some for his 708s
post #7282 of 7396 Old 11-26-2018, 12:19 AM
jasonr93's Avatar
Quoted: 47 Post(s)
I tried making mine out of spare plywood, but when i drilled some layers chipped away causing surface to be far from smooth. Should have used mdf. Thinking about ordering 2 from you instead if you'd be willing.
jasonr93 is offline
post #7283 of 7396 Old 11-26-2018, 03:40 AM
COACH2369's Avatar
Liked: 986
BOOM! The hard part will be dissecting the cabinet and properly installing it...
post #7284 of 7396 Old 01-03-2019, 09:53 AM
byron69's Avatar
Quoted: 14 Post(s)
Hi everyone!
I’m planning to update my HT speaker and I’m looking for JBL Pro references.
In Europe, 3678 is not available anymore. Do you think that an LCR setup with 3x4722N will be great in just 40 m2 equivalent to 430ft2?
Thanks for your experience and advice, as it seems that C221/C222 are not really done for our HT.
Best Regards
Envoyé de mon iPhone en utilisant Tapatalk
byron69 is online now
post #7285 of 7396 Old 01-04-2019, 03:22 AM
byron69's Avatar
Quoted: 14 Post(s)
Up
post #7286 of 7396 Old 01-04-2019, 09:48 AM
byron69's Avatar
Quoted: 14 Post(s)
13 ft to 16 ft from the speaker (4m to 5m)
post #7287 of 7396 Old 01-04-2019, 10:29 AM
byron69's Avatar
Quoted: 14 Post(s)
Thanks a lot!
post #7288 of 7396 Old 01-04-2019, 11:50 AM
ricren's Avatar
Quoted: 16 Post(s)
No issues at all. I would suggest you upgrade the compression driver. Plenty of info on that in this thread. Enjoy them, I sure did.
Hi,could you just recommend me a brand/model of compression driver for doing the uograde? This thread is 245 pages long and that makes very difficult to find that information. Thanks!
ricren is offline
post #7289 of 7396 Old 01-04-2019, 11:59 AM
ricren's Avatar
Quoted: 16 Post(s)
Sure - JBL 2453H-SL
Much appreciated. tks!
ricren is offline
post #7290 of 7396 Old 01-04-2019, 12:39 PM
carp's Avatar
Quoted: 3513 Post(s)
Liked: 3195
I'm 10 feet from the center channel, a bit further obviously to the L/R and there are zero issues with being that far away so you are easily good to go. I did the upgraded compression drivers and the result is that I'm 2+ years of having these speakers and still have no desire to upgrade/switch which for me is an eternity.
You can sell the original CD's on ebay for 100 each/300 total. They sound good, but it's a significant difference IMO.
carp is offline
Reply Speakers
