Just purchased a pair of JBL 4722n speakers. - Page 246 - AVS Forum | Home Theater Discussions And Reviews
 3118Likes
post #7351 of 7396 Old 06-18-2019, 01:52 PM
beastaudio's Avatar
Quoted: 5507 Post(s)
Liked: 5324
Originally Posted by jlpowell84 View Post
Who all here has the 8350 surround? There is a quad set 3hrs south of me and I need to go to Sac anyway to drop a couple drivers and possibly theater seating. I had planned on Volts...I do like that I can make Volts whichever dimension I so choose.
Just don't on the 8350's. Cross em off.
Isn't the control 328 the same thing as an SCS 8 just without a box? Thought I remember reading this. Specs are similar but not exact on JBL pro website. 328 says it's a 1" CD, SCS8 says it's a 1" high temperature diaphragm with fluid cooling.
Yes they are the same. If you don't want to build, go with either, if you do want to build the volts or concentric 8's will suffice. As to which are better, that'll be up to you.
beastaudio is offline
post #7352 of 7396 Old 06-18-2019, 01:55 PM
notnyt's Avatar
Quoted: 3731 Post(s)
Liked: 3705
The 8350s are awesome, what are you on about?
notnyt is offline
post #7353 of 7396 Old 06-18-2019, 10:51 PM
jlpowell84's Avatar
Quoted: 2019 Post(s)
Liked: 987
Originally Posted by carp View Post
Awesome, thanks for the references!
jlpowell84 is offline
post #7354 of 7396 Old 06-18-2019, 11:00 PM
jlpowell84's Avatar
Liked: 987
I want to be able to build my own so I liked the 328, I can prob get good pricing on them. So even though JBL Pro website has different wording and slightly diff specs you say its same HF and LF drivers?
post #7355 of 7396 Old 06-19-2019, 07:37 AM
beastaudio's Avatar
Liked: 5324
I read 8330 in my rushed state and posted without paying enough attention. I like the 8350's, but FWIW I feel the scs8's for a full surround system will still be better.
post #7356 of 7396 Old 06-19-2019, 08:40 AM
DekPM19's Avatar
Quoted: 189 Post(s)
Liked: 56
Do you mean scs8 for the surround speakers and the atmos or just surrounds?
Allen
DekPM19 is offline
post #7357 of 7396 Old 06-19-2019, 10:11 AM
beastaudio's Avatar
Liked: 5324
Allen
Yes, or just as well do 328c's for the ceiling if you are going for some WAF factor.
post #7358 of 7396 Old 06-19-2019, 07:15 PM
DekPM19's Avatar
Quoted: 189 Post(s)
Liked: 56
I have looked at the 328c and back can. They want you to tie off the can. I live in the south and we don’t ha ve basements, but we have bonus rooms which is what I have. The crawl space is to small to get in there and do some work, but I catn fish cables through which what I did I put my projector up. The scs 8 I could mount on the ceiling and get the speaker wire to them. I could mount the 328c too I think but not tie the can off. I was thinking about making some wooden rings to mount around the hole cut then screw the cans in to them. I guess the one thing about the scs8 is you can aim them.
Allen
DekPM19 is offline
post #7359 of 7396 Old 06-19-2019, 08:28 PM
jlpowell84's Avatar
Liked: 987
have read the 8320, which have same form factor as 8350, are not as hot a performer.
post #7360 of 7396 Old 06-19-2019, 09:34 PM
notnyt's Avatar
Liked: 3705
They're not the same form factor. The 8320s are a good deal smaller.
8320: 16 in x 13.5 in x 8.8 in
8" woofer + dome tweeter with 3khz xover 93dbspl sens 1/2 space
8350: 18 in x 18 in x 10.25 in
10" woofer + compression driver with 1.4khz xover 99dbspl sens 1/2 space
8320
8350
notnyt is offline
post #7361 of 7396 Old 06-20-2019, 05:58 AM
12B4A's Avatar
Quoted: 596 Post(s)
Liked: 514
Are those divots for diffraction?
Life is Lambertian
12B4A is offline
post #7362 of 7396 Old 06-20-2019, 06:49 AM
Wrager's Avatar
Quoted: 298 Post(s)
Liked: 178
Huh? Maybe your part of GA, but around me, about half the homes have basements. I have two basements because of the slope I'm on.
Wrager is offline
post #7363 of 7396 Old 06-20-2019, 08:40 AM
beastaudio's Avatar
Liked: 5324
Haha, I was gonna say, every house on my street...every single one including mine has a basement. That's neither here nor there tho pertaining to the discussion, if he can get the 328c's to work, they are great, if not the scs8's will do. Gotta run wire one way or another.
post #7364 of 7396 Old 06-20-2019, 11:36 AM
DekPM19's Avatar
Quoted: 189 Post(s)
Liked: 56
Down here in Savannah you want find many basements, I should have been clearer.
Allen
DekPM19 is offline
post #7365 of 7396 Old 06-20-2019, 11:40 AM
Quoted: 940 Post(s)
Liked: 273
I have scs8 for surrounds and also for ceiling. They produce great surround and atmos sound. My issue is that they take a lot of space specially when it comes to surround area. My room is 12' wide and after having 3 seats next to each other, I'm left with enough space on each side just to walk by. After placing scs8 as surround, I have to walk side ways to get by . Really annoying. Any suggestion on what I can use instead of scs8 to match with my 4722N as L/C/R? A wall mount speaker that's a good fit for 4722N would be great.
As for atmos, I have them all pointing at MLP. After mounting, they take extra 8" off from ceiling because of their height + mount. Ceiling in my room is 8' high but i have a 6" riser which reduces the height even more. Plus side of scs8 is that it can be aimed. With 328, we'll get extra 8" back since its mounted on ceiling but it can't be aimed at MLP afaik.
harrisu is offline
post #7366 of 7396 Old 06-20-2019, 11:57 AM
DekPM19's Avatar
Quoted: 189 Post(s)
Liked: 56
I can mount the 328c I was just wandering by being able to aim the scs8 would it give you the better atmos experience since a lot of people talk about being able to aim their speakers they install in the ceiling.
Allen
DekPM19 is offline
post #7367 of 7396 Old 06-20-2019, 12:14 PM
beastaudio's Avatar
Liked: 5324
Take a gander at my build thread in my signature. Our rooms are very similar. 12' wide, three seat rows, and I actually have just 7.5ft drop ceiling. You can see how I took sine depth off my side surrounds by insetting them into the wall which gave me with sheetrock another 4" of literal "Wiggle room" when walking beside the seats. as far as other in-wall options out there, your options for something that will keep up the 4722's are pretty limited unless you DIY like I did. If you can inset the scs8 into the sheetrock and gain 4" back then that might be the route I'd take honestly.
Allen
yes by aiming the scs8's you will get a better experience for sure. If you can do it and are ok with how they will be installed/WAF factor then I'd say go for it.
post #7368 of 7396 Old 06-20-2019, 12:46 PM
DekPM19's Avatar
Quoted: 189 Post(s)
Liked: 56
That what I wanted to know thanks. In that room I don’t have a WAF factor, the rest of the house, yes.
Allen
jlpowell84 likes this.
DekPM19 is offline
post #7369 of 7396 Old 06-20-2019, 01:36 PM
jlpowell84's Avatar
Liked: 987
Allen
Yes and I have thought about this quite a bit. If you look at JBL demo rooms they have done they seem to always have speakers aiming. Do I like the idea of flush and clean? Yea I really actually do and may still do it as my seating will always be small. Ive had a single row of seating for last couple years, never would have more than two. So with a 7.2.4 system I think flush mount with 120 dispersion would be fine. But research would ultimately tell.
post #7370 of 7396 Old 06-20-2019, 01:37 PM
jlpowell84's Avatar
Liked: 987
8320
8350
Exactly, I just meant same physical shape and look. But not as hot as performer as not even close to same speaker by the specs you list.
notnyt likes this.
post #7371 of 7396 Old 06-20-2019, 01:42 PM
jlpowell84's Avatar
Liked: 987
My exact reason for bringing this up. I had two ideas. What about rebuilding the SCS 8 box to slimmer and mounting closer to ceiling? Essentially treating it like a DIYSG Volt speaker that I think you can get to I think 6-7" slim?
Can the 328c be built into a box so one can aim it or has JBL meant it to be as it mounted into a ceiling or wall?
post #7372 of 7396 Old 06-20-2019, 01:47 PM
jlpowell84's Avatar
Liked: 987
Ah just read this after respondings, yea that wouldn't look too bad if one made a good finish look to it, and can still aim. Was my only beef with SCS 8 was the depth of speaker plus mounting bracket added depth. But if it matches JBL sound better than a Volt thats enough for me...
post #7373 of 7396 Old 06-20-2019, 02:41 PM
Quoted: 940 Post(s)
Liked: 273
Good idea. Issue is that the HT is in the basement and I have a concrete wall behind right side of sheetrock. measuring it came out to 2 1/2" from outer side of sheetrock. Still better than sticking it out all the way though but if could be pushed like 6" in, would have been much better.
Hmmm DIY. I have done some subs DIY. If the DIY is not too hard, I might be able to do it.
My ceiling has a lot more space. I can push them in to the point where only the grill area is visible but it won't be that easy since we'd have to make it point to MLP. In this case, the cut out has to be the length of the speaker so that it sticks out of ceiling. Hmmm that'd be a big cut out.
harrisu is offline
post #7374 of 7396 Old 06-21-2019, 07:06 AM
beastaudio's Avatar
Liked: 5324
The 328c comes with it's own backer box IIRC. Not sure how modify-able it would be but with and/or the scs8, provided you keep the volume the same, making your own box would be feasible I guess. Having a different shape baffle on the scs8 would create a slight issue with baffle step correction but for surround duty that problem would be extremely small.
No biggie, sheetrock is replaceable
post #7375 of 7396 Old 06-21-2019, 02:02 PM
DekPM19's Avatar
Quoted: 189 Post(s)
Liked: 56
I have an idea with the backing can for the 328c. I think I saw some volts done kinda like this. Make you a mount to go on the backside of the sheet rock. Cut it in half and slide threw the hole to the backside of the sheet rock. Then glue and clamp into place. Then you slide the can up into the hole and on the other ring drill pilots holes through the ring to mount it in place. Then you would mount the speaker to the can as you normally do.
Allen
DekPM19 is offline
post #7376 of 7396 Old 06-24-2019, 09:23 AM
Wrager's Avatar
Quoted: 298 Post(s)
Liked: 178
Would these offer any better fitment options? https://www.jblpro.com/ProductAttachments/JBL_AC18_26-082016.pdf
I use the 28/26 as side surrounds.
Wrager is offline
post #7377 of 7396 Old 06-24-2019, 12:18 PM
DekPM19's Avatar
Quoted: 189 Post(s)
Liked: 56
The 28/26 looks like it could be used as a main speaker, have you ever tried that?
Allen
DekPM19 is offline
post #7378 of 7396 Old 06-24-2019, 12:36 PM
Wrager's Avatar
Quoted: 298 Post(s)
Liked: 178
Allen
I did sort of, but not in the theater. I used three of 18/95's for my family room before I got the 708i's. They really are excellent, neutral speakers and can take a ton of power.
Wrager is offline
post #7379 of 7396 Old 06-24-2019, 12:44 PM
DekPM19's Avatar
Quoted: 189 Post(s)
Liked: 56
To keep you from maybe repeating yourself do you have any information for your thoughts on the 708i as theater speakers. I like what everybody says about the 4722 but don’t know if I want that big of a speaker in my room. I have come close to buying a 4722 to put in as a center channel to just try one out.
Allen
DekPM19 is offline
post #7380 of 7396 Old 06-24-2019, 01:27 PM
jlpowell84's Avatar
Liked: 987
Looks nice but needing 8 cost climbs quickly
Allen
Is DIY out of the picture?
Reply Speakers
