Help with speaker placement, please. :) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-21-2015, 08:03 PM - Thread Starter
Liked: 0
Hey everyone! I just got (what I think is) a great deal on a set of in wall speakers and am trying to figure out the best placement for them. The speakers I got are Klipsch Front Left and Right Channels are R-2650-W II, Center Channel is an R-5502 -W II , Rear channels are R-2650-C II and CDT 2650-C. I also have an Onkyo NR-626 receiver. The problem is that my TV is mounted in the corner of the room above the fireplace and the room opens up to my kitchen/dining room (I am attaching a floor plan for reference). Additionally, the ceiling is vaulted. Is there any good way to mount the speakers? (I am willing to buy 2 more speakers if a 7.1/7.2 system is viable in this layout). Also, what subwoofer should I buy? I mainly play video games and watch movies but I would also like to be able to listen to music. Any help is appreciated. Thanks!
ID:	617593   Click image for larger version
BlueBubble2 is offline
post #2 of 2 Old 03-22-2015, 08:52 AM
drunkpenguin's Avatar
Quoted: 1898 Post(s)
Liked: 1820
Your right speaker is gonna be tough. You'll need to find out where the studs are. Above the window is going to be a large header so probably no room for an in wall there. I can't tell by the pic how much room there is to the left of the window, you might have space there. But honestly I think above the door is the only place you're going to find with enough open space between studs.
drunkpenguin is offline
Reply Speakers
in-wall , Klipsch , nr-626 , Onkyo , subwoofer
