AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Speakers (https://www.avsforum.com/forum/89-speakers/)
-   -   How would i connect these to my pc? (https://www.avsforum.com/forum/89-speakers/1954785-how-would-i-connect-these-my-pc.html)
Matt255 03-31-2015 09:46 PM
i am planning to get the energy take classic 5.1 speakers i am wondering how will i connect them to my pc and still be able to get 5.1 sound. Will i need an av receiver to connect them?
Knucklehead90 03-31-2015 10:20 PM
Yes you will need an AVR. And to get full value from them you'll need the on-board sound chip or an add-on sound card that is surround sound capable.
Julio Castrejon 03-31-2015 10:41 PM
Yes it looks like you will need one after all. You can use your PC HDMI out or Optical out for the 5.1 sound.
jmh547 04-01-2015 05:58 AM
What computer/motherboard do you have. You may not need a sound card as some on board sound has digital outputs and descrete line level outputs for each channel. If you use a digital output you will need an avr for the decoding, if yours has line level you could just get an amp and let the computer decode. Right now I am using an onboard optical output to my avr
Matt255 04-01-2015 03:53 PM
my motherboard is an asus hero vii and can you recommend a av receiver for me
Knucklehead90 04-01-2015 05:32 PM
Your motherboard has optical out and supports 7.1 audio so any modern AVR will have the necessary inputs.
Budget?
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
