AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Speakers (https://www.avsforum.com/forum/89-speakers/)
-   -   How do you clean your Hi Gloss/Piano black speakers? (https://www.avsforum.com/forum/89-speakers/2031713-how-do-you-clean-your-hi-gloss-piano-black-speakers.html)
xcrossover 06-13-2015 05:56 AM
Hi All,
I use Mr Sheen wood/leather/plastic cleaner which also protects the wood not sure how it would go with piano black finish.
anyone got recommendation?
thanks
witchdoctor 06-13-2015 06:03 AM
Originally Posted by xcrossover (Post 34990361)
Hi All,
thanks
Windex, test it our first on a small spot to see if you like it before doing the whole speaker
xcrossover 06-13-2015 06:06 AM
Well apparently you aren't suppose to use window cleaners on wood finish. :-)
fatbottom 06-13-2015 06:35 AM
I buy a new pair of speakers everyday. Saves on dusting.
FMW 06-13-2015 06:40 AM
I hose them down. ;)
fatbottom 06-13-2015 06:40 AM
I live in a vacuum.
blastermaster 06-13-2015 06:45 AM
I use stuff called "Invisible Glass" on our actual piano and clean it off with a microfibre cloth. Works great. If it were my expensive speakers, though, I'd probably get one of those air cans for computers and blow off any excess dust first.
jaykay0222 06-13-2015 07:05 AM
Power washer works best for me
tubby497 06-13-2015 07:12 AM
I use an automotive cleaner/detailer:
http://www.meguiars.com/en/automotiv...quik-detailer/
ALtlOff 06-13-2015 07:18 AM
Small hand held dusting mop & Endust.
But any decent furniture or automotive quick spray will work, remember your cleaning clear lacquer, not wood directly.
pablolie 06-13-2015 07:18 AM
Microfiber cloth indeed.
CHASLS2 06-13-2015 11:16 AM
I use Zaino Z6 detail cleaner like i would on the C6 Vette i had for my CM 10 s2's.
kwkshift 06-13-2015 11:24 AM
Swiffer duster to remove all the dust. If you have any fingerprints left behind, use a microfiber towel and auto detailer like Mothers/ Meguiers, etc.
RayDunzl 06-13-2015 12:40 PM
xcrossover 06-13-2015 04:14 PM
so im guessing the use of wood conditioners are out since no one uses them. i use on my floor standing as it has wood vinyl on it.
Kensmith48 06-13-2015 04:19 PM
I got the cleaner/polish that they use on pianos from the local music store. Works great.
lovinthehd 06-13-2015 04:29 PM
Lemon pledge here. Also works great on my titanium bike frames. Why would it matter if it is wood under the piano black lacquer finish? Mine's bamboo....
scanido 06-15-2015 11:14 AM
+1
I do this every other year and mainly to protect the finish from UV. Otherwise, just a simple dusting with a high quality microfiber.
torii 06-15-2015 12:16 PM
wife uses windex and nothing I can do to stop her except buy new gear :)
dragan35 06-15-2015 12:33 PM
+1
ousooner2 06-15-2015 12:43 PM
3 Attachment(s)
530gsm or higher microfiber + Ultima Waterless Wash Plus (from my auto detailing collection :))
bhaaf 06-15-2015 12:57 PM
Hi All,
thanks
Endust. No polishes and such. Also works good on the surfaces of all your gear. Recommended to me by a reputable manufacture.
Craig Peer 06-15-2015 02:49 PM
I just use a Swiffer Duster, as nobody ever touches mine.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
