Are Front Height Speakers OK use as Atmos speakers? - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 102Likes
post #421 of 434 Old 04-19-2020, 10:46 AM
MagnumX's Avatar
Quoted: 1572 Post(s)
Liked: 1043
Originally Posted by ckoons1 View Post
since i have the bic america venturi line of speakers. would it be best to get the bic america Dv-62SIB bookshelf speakers for my front height speakers so they match ?
Probably. It's usually preferable to keep drivers as similar as possible for timbre matching. It may not be as important for surround speakers as a center channel, but still an improvement when sounds don't change just by panning around the room (important in a movie like Gravity where dialog moves all over the room).
It might be harder to tell timbre differences with things like explosions than dialog, for example. Some say Audyssey and other room correction systems sometimes help in that regard, but that's not what they were designed for.
ckoons1 likes this.
Click THEATER (Updated: Nov-12-2019) for pics: Epson 3100 3D Projector, DaLite 92" screen, 11.1.6 (Marantz SR7012 + Yamaha HTR-5960 + Onkyo ESPro) - Dialog Lift - PSB T45/B15/S50/X1T/CS500 Speakers & Def Tech PF-1500 15" sub; 2nd Room (Updated Apr-22-2019): 48" Plasma TV, Carver AL-III, Carver C-5 Pre-Amp, Technics SH-AC500D, Dual Carver TFM-35x Amps (Active Bi-Amp), Klipsch Surrounds ; Sources: PS4, LG UP875 UHD, Nvidia Shield (KODI), ATV4K, Zidoo X9S, LD, GameCube : Props (Updated 4-11-20)
MagnumX is online now
post #422 of 434 Old 04-19-2020, 11:38 AM
Quoted: 17 Post(s)
Liked: 2
thank you
ckoons1 is offline
post #423 of 434 Old 04-20-2020, 03:46 AM
Quoted: 17 Post(s)
Liked: 2
any suggestions on how and what to use to point my front height bookshelf speakers downward so I can point them to the listener ?
thank you
ckoons1 is offline
post #424 of 434 Old 04-20-2020, 03:50 AM
Quoted: 17 Post(s)
Liked: 2
ah just read something online. how about rubber door stoppers ?
ckoons1 is offline
post #425 of 434 Old 04-20-2020, 04:14 AM
MagnumX's Avatar
Liked: 1043
I bought some studio foam wedges that angle the speakers downward a bit, but it's not a whole lot.
ckoons1 likes this.
post #426 of 434 Old 04-20-2020, 05:16 AM
MRAYB's Avatar
Quoted: 508 Post(s)
Liked: 1930
thank you
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 ... good if sitting on a shelf where not a lot of angle is need
https://www.amazon.com/gp/product/B0...UTF8&psc=1...I use a few of these under my center speaker. Can be "carved" for a custom size. Hacksaw blade or coping saw worked fine.
https://www.amazon.com/gp/product/B0...F8&psc=1..good for if higher up on the wall. Can modify for more of a downward angle.
ckoons1 likes this.
MRAYB is online now
post #427 of 434 Old 04-20-2020, 05:58 AM
Quoted: 17 Post(s)
Liked: 2
awesome. thank you.
interested in number two
will it not tilt the speakers too far forward to where they could tip ?
ckoons1 is offline
post #428 of 434 Old 04-20-2020, 06:56 AM
Quoted: 17 Post(s)
Liked: 2
ckoons1 is offline
post #429 of 434 Old 04-20-2020, 07:07 AM
MRAYB's Avatar
Quoted: 508 Post(s)
Liked: 1930
awesome. thank you.
You can shape these any way you like. Made of a dense foam type material.
Maybe? They have a front lip to help. You could always use some of this on the bottom of the speaker. Easily removable and holds great. https://www.amazon.com/Bostik-Mastic...s%2C319&sr=8-3
ckoons1 likes this.
MRAYB is online now
post #430 of 434 Old 04-20-2020, 07:49 AM
Quoted: 17 Post(s)
Liked: 2
very cool
thank you
MRAYB likes this.
ckoons1 is offline
post #431 of 434 Old 04-21-2020, 06:44 AM
Quoted: 17 Post(s)
Liked: 2
decided to go with this
https://www.amazon.com/Audioengine-D...ct_top?ie=UTF8
going to put some blutak on the speakers attached to the stand and on the stand attached to the top entertainment shelf
does that sound about right ?
MRAYB likes this.
ckoons1 is offline
post #432 of 434 Old 04-21-2020, 10:34 AM
MagnumX's Avatar
Liked: 1043
That's more or less what I'm using for my front height speakers. I don't use any blutak, though. I also changed the PSB tweeters on my Image series speakers here to a fabric tweeter that seems to have much better off-axis response for the front height and side heights that are less aimable. No timbre anomalies I can detect and the response sounds pretty even with the Helicopter flying around now (rear CS500s are fully aimable and were perhaps just a tad brighter so they now match quite well, IMO).
post #433 of 434 Old 04-21-2020, 10:54 AM
Quoted: 17 Post(s)
Liked: 2
maybe i will try without blutack first
ckoons1 is offline
post #434 of 434 Old 04-28-2020, 09:42 AM
langers_2004's Avatar
Hi all. Been reading this thread for a while now.
I had front and rear heights. I've since moved the front heights to the top front position, but on the side wall aimed at mlp from near the roof/wall join.
Has anyone else done this. What setting are you using in the avr. I'm currently using a marantz sr6013 and set to top front and read height.
fgsouza likes this.
langers_2004 is offline
Reply Speakers
atmos
