Speaker setup for my dad - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-20-2015, 11:52 PM - Thread Starter
Liked: 0
Hi, I want to buy a speaker setup for my dad's new pc, but don't want to go the conventional route of buying standard PC speakers. I was thinking about buying the Klipsch promedia 2.1 speakers, but I believe that it's possible to make a better setup by buying these parts seperate. I was thinking about a pair of passive speakers, an amp, and a decent 100-watt sub. Could anyone here give me a good setup for around ~125-150 that would be better sounding than the Klipsch speakers?
dyslecix is offline
post #2 of 4 Old 12-21-2015, 02:34 AM
jyaku's Avatar
Was debating the same myself and went with a Lepai 2020+ and Pioneer BS22's. Couldn't be happier.. more than enough bass (after a month).
Very warm sound which is what I like compared to brightness of certain other speakers.
jyaku is offline
post #3 of 4 Old 12-21-2015, 03:28 AM
Shpongle DMT's Avatar
Quoted: 28 Post(s)
Liked: 33
Definitive Technology Incline: incredible sound in a sleek and compact package. You can add a sub later but they already put out a lot of bass. Just a little more pricey that your listed budget.
http://www.amazon.com/Definitive-Tec.../dp/B00G5CKH6O
Shpongle DMT is offline
post #4 of 4 Old 12-21-2015, 02:47 PM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2155 Post(s)
Liked: 3234
What you're looking to purchase doesn't align with the budget I'm afraid; you'll either end up with low quality pieces or you won't be able to get everything you want. For ease of installation you might want to still consider a 2.1 system, like the ProMedia (which for the price is a fine system). If you still want to pursue separates ideally you should consider increasing your budget.
If you take yourself too seriously expect me to do the exact opposite...
JimWilson is offline
Reply Speakers
