Match Speakers with Hegel H80 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-19-2016, 01:09 PM - Thread Starter
Liked: 0
I am upgrading my system, maybe to what some would consider an entry level audiophile level. I just purchased a Hegel H80 integrated amp. I have had my eyes on the Monitor Audio Silver 8s in the white lacquer finish, but have not pulled the trigger yet. I love the MAs and will likely go that direction, but figured I'd see what other recommendations are out there. I listen to a wide variety of music: rock, jazz, classical, electronic, world, acoustic, live, etc. and almost exclusively lossless digital file (although I may get a turntable sometime down the road) My budget is around $2k. I will also say aesthetics are important as these are for the living room. I particularly like the clean look of the white lacquer. Thanks in advance.
Nosara is offline
post #2 of 2 Old 01-19-2016, 04:20 PM
commsysman's Avatar
Quoted: 1119 Post(s)
Liked: 584
Those are excellent speakers, and your amplifier is one of the best.
You will no doubt enjoy that system; it should sound great!
commsysman is offline
Reply Speakers
hegel , Monitor Audio
