Any way to NOT need an A/V receiver? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By dscottj
  • 1 Post By PeterDoubt
post #1 of 20 Old 06-25-2016, 08:19 PM - Thread Starter
drew4392's Avatar
Never thought I'd posting this question.
I justtttt got a Def Tech 5.1 system installed and really like it. I went from a much larger setup with towers, huge center, big home entertainment cabinet, to a smaller, on-wall speaker system with a smaller rack for my components. Reason being, we were expecting a baby and needed a play area.
Fast forward... and almost out of nowhere... I sold the house and bought a new one. The new house has a unique layout, and unfortunately, doesn't afford much space for a component rack.
Which brings me to my odd question......
Can I run 5.1 without a receiver? Time Warner can hide a small cable box behind the TV on the wall, but I have this awesome Yamaha receiver that I actually have to consider eliminating due to space.
If a solution is so obvious, I apologize. I've always run receivers.
I was also thinking about replacing my 5.1 def tech for a GoldenEar soundbar. Maybe.
Any advice is greatly appreciated!
drew4392 is offline
post #2 of 20 Old 06-25-2016, 10:13 PM
afrogt's Avatar
Quoted: 2332 Post(s)
Liked: 1524
you can get fake 5.1 with certain soundbars but if you want true 5.1 you'll need a receiver.
Afro GT
afrogt is offline
post #3 of 20 Old 06-25-2016, 10:41 PM
Quoted: 153 Post(s)
Liked: 69
If you don't want speakers hung on walls you'll need a soundbar. There's no way around it, to get a clean look need to get rid of bulky components. That's what I did for my living room, got a cheap $150 soundbar. I don' watch much movies so all my expensive equipment are in my bedroom doing 2channel music.
nbp_civic is offline
post #4 of 20 Old 06-25-2016, 11:00 PM
astrallite's Avatar
Quoted: 70 Post(s)
Liked: 39
The only 5.1 I can think of without a "receiver" would be a Dolby Digital Decoder with 6 channel outs to powered speakers.
In general you are looking at PC/Multi-Media Speakers, or getting a stand-alone decoder like this:
https://www.amazon.com/Tekimbe-Digit...igital+decoder
And running it to powered monitors/speakers/towers. You would of course, need to get some really long RCA cables in that case since those are now substituting for speaker wire.
The only downside to this I see is you are now manually level-matching your speakers with a microphone or by ear and tuning the volume knob on each powered speaker you've got. Also if you aren't going to run a separate amp, you are stuck with using commercial powered speakers which are generally designed for a desk form-factor, not ones designed necessarily for flat wall-mounted decor/form-factor.
astrallite is offline
post #5 of 20 Old 06-26-2016, 05:31 AM
dscottj's Avatar
Quoted: 264 Post(s)
Liked: 164
That must be one strange space you got there. With ubiquitous networking and modern remote control technologies, the receiver doesn't even have to be on the same floor as the speakers, let alone the same room. Stick it in a closet in the basement, problem solved.
shivaji and cmdrdredd like this.
I'm also an author! Gemini Gambit - He's trying to save the world. She's trying to hide from it. When they meet, death is the least of their worries. http://www.amazon.com/Gemini-Gambit-...dp/0986396214/
Its sequel, Dragon's Ark, is also available. Behind the Great Firewall of China, there are secrets people will kill to keep. https://www.amazon.com/Dragons-Ark-G...dp/B01LD5BYV4/
dscottj is offline
post #6 of 20 Old 06-26-2016, 05:51 AM
gregoryperkins's Avatar
Quoted: 747 Post(s)
Liked: 274
I have a difficult location for my TV between 2 doors in the living room. There is no place for LR to go properly. I have a Polk Surround bar that puts a bunch of unpowered speakers in a bar for 5.0. It sounds decent for tv, but this is not the main theater. I have a 12" svs sitting under the bar so it has plenty of bass. I also have 2 remote satellites to open it up a bit, so it is really 7.1 but you almost never hear anything from them. It does not do well with music.
It looks like this,not sure if it is the exact model.
https://www.audioholics.com/soundbar...iew_fullscreen
For music, I use the receiver's zone 2 to run another set of speakers in the same room. It's a bitch to get the sub to play with both zones, but I sort of have it in control.
I'm not sure if anyone is making them anymore. I have another down in the basement for the exercise room tv.
So the upside is you can use the receiver, the downside is you need a receiver.
I'm not sure if this picture will work.
https://*******/photos/55iCRXWfBMi6ysbb9
gregoryperkins is offline
post #7 of 20 Old 06-26-2016, 10:00 AM
Zorba922's Avatar
Quoted: 8328 Post(s)
Liked: 6375
You'd be better off with a pair of self-powered speakers than any soundbar, IMO. I'd rather take the superior separation of two speakers over the fake "simulated" surround of a soundbar any day.
JBL LSR305 or 308, Emotiva (https://emotiva.com/products/emotiva...red-monitors-0) are what I'd look at.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #8 of 20 Old 06-26-2016, 01:53 PM
RayGuy's Avatar
Quoted: 3350 Post(s)
Liked: 3143
The Golden Ear soundbar is passive, and will need a receiver. Get yourself an infrared to RF remote control mechanism and be done with it. Alternatively, you can go the soundbar route, but you will need a powered version that has inputs for your other equipment. Vizio is best on the cheap, Yamaha is better, and there are high quality soundbars out now, but they can be expensive.
You might find this helpful: http://hometheaterhifi.com/reviews/speaker/soundbars/
You decide how best to approach it.
RayGuy is offline
post #9 of 20 Old 06-26-2016, 09:18 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3017
In case it helps, Marantz makes low profile receivers. Similar width and depth profile as standard AVR, but smaller in height.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #10 of 20 Old 06-27-2016, 07:50 AM
desmofan's Avatar
How about a powered speaker system
Something like a Sonos 5.1 system. It's fed from your cable box/TV/etc. with an optical digital connection, and is actual 5.1. I've heard it, and when setup correctly, it sounds very good.
desmofan is offline
post #11 of 20 Old 06-27-2016, 08:05 AM
unclfuzzy's Avatar
Snobbish audiophiles please avert your eyes
I have a Vizio soundbar with a wireless subwoofer to which the rear channels are wired. All my sources connect to the TV via HDMI and out from TV to soundbar via optical. Works and sounds great.
https://smile.amazon.com/VIZIO-SB385.../dp/B00SMBGGV6
unclfuzzy is offline
post #12 of 20 Old 06-27-2016, 08:08 AM
lar
lar's Avatar
If your only issue is space I'd also investigate computer audio setups. I use to use a Sound Blaster Extigy whenever I needed an impromptu receiver (no computer attached). It's smaller than a cable box, accepts optical and coax and has 1/8" jacks for all speaker channels. You'll obviously need powered speakers to do this.
lar is offline
post #13 of 20 Old 06-27-2016, 08:11 AM
PeterDoubt's Avatar
Quoted: 16 Post(s)
I use the older version of this in one setup. If it sounds as good as mine, it would work.
https://www.amazon.com/Logitech-Z906...surround+sound
morbidcorpse likes this.
PeterDoubt is offline
post #14 of 20 Old 06-27-2016, 10:01 AM
lifespeed's Avatar
Quoted: 282 Post(s)
Liked: 39
not thinking out side the (receiver) box?
Wow, I guess nobody here has ever considered that a high-end PC soundcard outputs 5.1 (or 7.1 for that matter) analog channels. ASUS has some good ones, I personally use their old Xonar D2X. It has excellent audio performance.
Now you'll still need amplification, but that certainly does not require a receiver. I suggest you research Class D 5.1 amplifiers. They are newer technology, you may need to be a little careful to find a good implementation that meets your audiophile (or not) requirements. These are typically much smaller and power efficient than the big ADCOM power amps that I use.
Lifespeed
91XG Yagi for San Francisco, DB4e bowtie for Fremont
SiliconDust HDHR4-2US network tuners, one per antenna
Media server PC running Emby
Rabbit Ears reception report
lifespeed is online now
post #15 of 20 Old 06-27-2016, 11:32 AM
Quoted: 971 Post(s)
Liked: 821
Yamaha Sound Projectors are AVRs and a "speaker bar" all-in-one. I have one in my living room and use it all the time.
sigpig is online now
post #16 of 20 Old 06-27-2016, 02:08 PM
morbidcorpse's Avatar
Quoted: 304 Post(s)
Liked: 283
I used to use the Logitech Z5500 5.1 for years in my living room. The mostly PSA system I have now is vastly superior, but for not taking up much space, the z5500 had very good sound for very little money. I got mine for $180 and free shipping. Plus, I made money on it when I flipped it on ebay a few years back.
morbidcorpse is offline
post #17 of 20 Old 06-28-2016, 05:07 AM
JustMovies's Avatar
I had a situation where I remodeled a room for my wife, mounted a TV on the wall and wanted good 5.1 surround without using a receiver. I purchased a Vizio 5.1 surround sound setup and it was the best investment I made. I auditioned many top rated sound bars side by side in my house that had fake surround, and they all sounded terrible to me. The Vizio has a 3 speaker sound bar for the front 3 channels, then broadcasts wirelessly to a subwoofer at the back of the room that also runs two separate (wired) rear channel speakers from the subwoofer. The setup is similar to using a receiver, where the volume of the rear speakers is set separately from the front. I have the sub under a side table, and the surround speakers on both sides of the sofa. The sound cannot compare to a $1000 setup, but it is really very good. The surround aspect for movies is excellent, and the subwoofer pounds out good bass. I'm very happy with the setup, and it didn't break the bank.
-edit-
(duh!) I just saw that post #11 by unclfuzzy already talks about the same setup as mine....(I need my coffee this morning!) so we both are using the same great setup...
JustMovies is offline
post #18 of 20 Old 06-28-2016, 08:56 AM
Zorba922's Avatar
Liked: 6375
It always puzzles me when I see people trying to sell USED stuff on eBay at the same or higher prices as new stuff on Amazon...but I guess SOMEBODY must be buying them after all! Good for you, in any case.
Zorba922 is offline
post #19 of 20 Old 06-29-2016, 04:17 PM
BassThatHz's Avatar
Quoted: 3970 Post(s)
Liked: 4489
Your best bet is to get an Oppo 103 and a HDMI input matrix box.
https://www.oppodigital.com/blu-ray-...-Features.aspx
http://www.monoprice.com/category?c_...&cs_id=1011002
Just make sure you get a matrix box that has the features you need.
I believe Crestron makes some 1 rackunit amps. Others might too, you'll have to look around.
Or as what was already suggested, just throw it in another room and run speaker cables.
http://www.parts-express.com/jsc-wir...00-ft--100-782
Secondary Alternatives:
The miniDSP HDA is the smallest unit I know of, but it only supports LPCM; and it only has 2 inputs, both HDMI.
https://www.minidsp.com/products/ht-series/nanoavr-hda
For just $70 there is a 7.1 DAC, but it only has 1 input.
https://www.amazon.com/Digital-Conve...dp/B019RF7ZVA/
With the Crestron HDDA2 you can only do stereo decode:
https://www.crestron.com/products/model/HD-DA-2
Crestron also has a compact AVR, but I bet it is at least $2000. LOL
https://www.crestron.com/products/model/HD-XSPA
BassThatHz is online now
post #20 of 20 Old 06-29-2016, 04:37 PM
BassThatHz's Avatar
Liked: 4489
Crown makes a CT series of amps.
8 channels in just 1.75inches tall.
Probably costs a fortune though...
http://www.crownaudio.com/en/products/ct-8150
Reply Speakers
