Confused buying soundbar Yamaha ATS-1050BL Vs Samsung HW-HM45C - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-06-2016, 08:48 AM - Thread Starter
Liked: 0
Question Confused buying soundbar Yamaha ATS-1050BL Vs Samsung HW-HM45C
Hi,
I am looking to buy sound bar under 200$. I don't need loud sound or need high volume. I just want to enjoy Rock music on decent volume.
I want my speakers to give good bass for music on decent volume. (not super loud)
I went to costco and found two fitting in my range : Yamaha ATS-1050BL Vs Samsung HW-HM45C
I listened to both and confused between buying. Both are pretty much same price
Yamaha has integrated subwoofer whereas samsung separate. Samsung has 300W and Yamaha has 120W and there might be other difference I might not be aware of
Can you please suggest buying between two or if there is another option you can suggest within my range and needs?
bhushansethi is offline
post #2 of 4 Old 07-06-2016, 09:33 AM
Zorba922's Avatar
Quoted: 7069 Post(s)
Liked: 5374
The soundbar with the separate subwoofer should sound better than the one without.
But if I were you, I'd just buy either a pair of powered speakers like the JBL LSR305, or a cheap amp with a pair of cheap speakers, such as the Dayton B652 at $50/pair with a $150 receiver:
http://www.accessories4less.com/make...rx-v377/1.html
The second option would allow you to have future expandibility, while the first option would be the easiest to set up.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #3 of 4 Old 07-06-2016, 11:40 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3015
First, there is a dedicated forum area on AVS for soundbars. Best place to research and ask questions: https://www.avsforum.com/forum/195-soundbars/.
But I agree with zorba. Unless placement is a problem for a pair of speakers, I would skip the soundbar.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #4 of 4 Old 07-06-2016, 05:11 PM
The Village Idiot
Knucklehead90's Avatar
Quoted: 781 Post(s)
Liked: 728
I don't own one of these but I see it in the catalog that Parts Express sends out every few months for $199 - shipped IIRC. There are 35 reviews by owners of that sound bar and they all seem to really like it.
Yamaha A-S1000 Int. Amp - Salk SongTowers - Oppo 103 - Marantz TT42 - Emo XDA-2 DAC - (WWG1WGA)
Multi-Channel: Yamaha RX-A2070 - Custom One-Off Selah Audio Center - Emo ERD-1 Surrounds
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
Reply Speakers
bass , sound bar , speakers , subwoofer , Yamaha
