Desktop/Bookshelf (stereo) speakers when I have to be close to a wall - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #1 of 32 Old 09-25-2016, 10:29 AM - Thread Starter
Liked: 0
I have a desktop setup that has been re-arranged after moving. I used to have the room for KEF Q300 bookshelf speakers on either side of my desk & front, but now they are left/right and slightly behind me, which is less than ideal.
I would like to get the speakers back in front of me, but I have limited space, and my desk is up against a wall. With the KEFs I know it said minimum of 9" off the backwall, and 37" off the sidewalls.
So my question is, are there any speakers out there that you all could recommend for putting close to a wall?
A second question would be, how terrible would it be if the speakers were mounted higher than my ears, but I angled them down towards me?
I appreciate any advice at all!
-Eric
.tex is offline
post #2 of 32 Old 09-25-2016, 10:45 AM
bgtighe23's Avatar
Quoted: 1853 Post(s)
Liked: 1239
-Eric
What is your budget?
You can also look at sealed designs, or front ported designs. Or even speakers that use passive radiators, which have characteristics like a ported design.
Examples of a front ported design would be something like the HTD Level 3 bookshelves: http://www.htd.com/Products/level-th...shelf-Speakers
Here's another front ported design: http://www.wavecrestaudio.com
Passive radiator: http://www.goldenear.com/products/aon-series
I believe NHT offers several bookshelves with sealed designs
If you are just looking for casual music listening then there shouldn't be any issue mounting them slightly above ear level. But there is where you will localize the sound. If you're looking for some seriously critical music listening, then mounting them above ear height isn't going to be ideal. But if you're just looking for some music to be playing while you're at your desk, mounting would be a nice way to keep your desk space clean, and also get some great sound.
I believe there is a port plug for all Ascend speakers. These are greatly reviewed and recommended speakers: http://www.ascendacoustics.com/pages.../spkrlist.html
With little desktop bookshelves, you won't be getting strong mid bass punch or a deep low end, so you could simply plug the port of any bookshelf speaker you want with a pair of socks and it isn't going to hurt the speaker. You will just have a little less bass.
You could also grab a little 6 ½" or 8" subwoofer from Parts Express and place in under your desk for the low end.
Receiver : Denon x5200
Front Stage : L/R - Statements by Jim Holtz
Surround Speakers : Klipsch RF-82II x 4 / RP-280F x 2
Subwooferage : 6 UM18/4 HT18 Subwoofer Log
bgtighe23 is offline
post #3 of 32 Old 09-25-2016, 11:50 AM
pase22's Avatar
Quoted: 3859 Post(s)
Liked: 3316
The port plugs that came with your Q300's are provided for that very reason. I use my port plugs because my speakers are closer to the wall than is recomended by Kef, no issues at all with sound quality and provides a smoother integration with the subs. I also don't see an issue with wall mounting the speakers toed in at the MLP.
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, Emotiva A-300, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #4 of 32 Old 09-25-2016, 12:45 PM - Thread Starter
Liked: 0
pase22 , great - thanks - maybe I will use the port plugs, I've saved them all this time, never thinking I'd use them...
Also- are you saying that you do not see an issue with them being mounted above the listener?
Note: The base of the speaker would be at about 6" above ear level, so on the KEF Q300, that puts the bottom port (+2.5") @ +8.5" and the top diaphragm center (+9.5") at +15.5".
If I had them @ 45=degrees left/right. They would be ~36" away and ~45" apart. (If any of that helps)
.tex is offline
post #5 of 32 Old 09-25-2016, 01:09 PM
pase22's Avatar
Liked: 3316
It's not ideal to have them 6 " above your ear. If could move them further apart it would be better, a picture of the room would give us a better idea of what your best options would be.
You have very good speakers and would like for you to be able to take full advantage of them.
post #6 of 32 Old 09-25-2016, 05:48 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3018
Even without the port plugs, you can still put the Q300s near the wall. Probably would get increased boundary gain on the bass, which is why they are probably recommending 9" or more out. But if you are happy with the sound, doesn't matter if they are close. So try it both ways
Shadowed likes this.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #7 of 32 Old 09-25-2016, 06:10 PM - Thread Starter
Liked: 0
Thanks guys -- I appreciate it -- That is good to know that close-ish to the wall is acceptable. The other thing is what to do about front-positioning. With my desk being L shaped and the desktop being consumed, I only have the option of mounting above ear-level, or off to the sides as I have now.
I attached the layout as it is right this moment, I measured everything out, should be pretty accurate. I hope this helps. And I REALLY appreciate it.
.tex is offline
post #8 of 32 Old 09-25-2016, 06:16 PM - Thread Starter
Liked: 0
I'm not sure why, but my files hadn't attached. -here they are again.
Name:	EDH 1525 Desk & Speakers Layout - expanded.png
File Type: pdf EDH 1525 Desk & Speakers Layout - expanded (1).pdf (34.5 KB, 18 views)
.tex is offline
post #9 of 32 Old 09-25-2016, 07:30 PM
cel4145's Avatar
Liked: 3018
I had trouble figuring out how everything is setup from the diagram. Sorry. Got a photo?
cel4145 is offline
post #10 of 32 Old 09-26-2016, 06:37 AM
pase22's Avatar
Liked: 3316
Can't make sense of where the desk is facing. Also have no idea where everything is in the room.
+1 for the photo. We'd like to help, to do that we need to know the layout.
post #11 of 32 Old 09-26-2016, 01:02 PM - Thread Starter
Liked: 0
Certainly - Sorry about that - I appreciate the help. Sorry about the mess. I have about 50 projects going on at once.
I hope this makes sense of it all.
ID:	1685889   Click image for larger version
.tex is offline
post #12 of 32 Old 09-26-2016, 01:31 PM
Quoted: 1281 Post(s)
Liked: 1120
Those things are the biggest pair of headphones I have ever seen!
Actually, have you given any thought to a great pair of headphones over a pair of questionably-placed bookshelf speakers?
sigpig is online now
post #13 of 32 Old 09-26-2016, 04:16 PM
cel4145's Avatar
Liked: 3018
I would move stuff off my desk to put the speakers on either side of the monitors. Then toe them in toward the listening position.
cel4145 is offline
post #14 of 32 Old 09-26-2016, 05:18 PM
Dargent0628's Avatar
Quoted: 286 Post(s)
Liked: 179
Hmm...would you consider moving the desk to the other wall and placing the stereo gear etc to the window side? Then you could mount the speakers on the wall above your desk. Also, look into the suggestion on NHT.
Dargent0628 is offline
post #15 of 32 Old 09-26-2016, 05:25 PM
cel4145's Avatar
Liked: 3018
Not before I tried putting them on my desk on either side of the monitors. If they aren't at ear height that way, throw some books under them to experiment. If it works out, then get some stands or some aurelex mopads to aim them up toward your ears.
I wouldn't get NHTs over your Q300s. Any speaker, sealed or front ported, will have some influence with boundary gains putting them up next to the wall. I don't think that the NHTs will offer you any benefits. See how your speakers sound first.
cel4145 is offline
post #16 of 32 Old 09-26-2016, 07:13 PM
pase22's Avatar
Liked: 3316
You can try a set of wall mount brackets such as these.
https://www.amazon.com/VideoSecu-Cla...speaker+mounts
Place one by the picture frame and one by the window, angle them towards you and use the port plugs.
post #17 of 32 Old 09-28-2016, 06:57 AM - Thread Starter
Liked: 0
@Dargent0628 - do you mean that I could mount above the monitors and angle downwards?
@sigpig - yes, I have some, but I was hoping to do both, day/time night time listening. Or music aloud when my wife is fine with it , and headphones othertimes
@pase22 & cel4145 - I've been trying to plan this out in my head. My question is, off the centerline, what is a decent maximum angle left/right for the speakers?
Thanks everyone -
Truly appreciative.
-Eric
.tex is offline
post #18 of 32 Old 09-28-2016, 07:13 AM
cel4145's Avatar
Liked: 3018
I would place them beside your monitors, and then toe them in such that the tweeter is pointed toward you. It's an experiment to see how it sounds. Place with the angle a little bit and see what is best
cel4145 is offline
post #19 of 32 Old 09-28-2016, 07:59 AM
pase22's Avatar
Liked: 3316
I don't think there's a right or wrong answer to the amount of angle to put them at. If it were my room, I'd put one where the record player is and the other right by the window. The Q100 and Q300 come equipped with a bracket for wall mounting. If wall mounting is not an option, place the stands as close as you can to the above mentioned locations.
Alternatively, you can move the desk to a better location as mentioned by Dargent or Move stuff off the desk as cel recomended which would be your easiest solution. Wall mounting would keep them out of your way and you wouldn't need to move anything.
post #20 of 32 Old 09-28-2016, 08:06 AM
Quoted: 286 Post(s)
Liked: 179
Thanks everyone -
Truly appreciative.
-Eric
Absolutely. However I personally would not enjoy such a near-field setup with those speakers.
Sent from my XT1635-01 using Tapatalk
post #21 of 32 Old 09-29-2016, 01:13 AM - Thread Starter
Liked: 0
Definitely going to have to do some rearranging.
By chance are there any panel speakers that are decent that could work?
That could be this close to the wall?
I really hate to give up my limited desk space. And the depth of the Q300s is going to eat it all!
.tex is offline
post #22 of 32 Old 09-29-2016, 06:33 AM
Liked: 1120
Actually, panel speakers (both electrostatic and planar magnetic) both require MORE room for them to work properly...
post #23 of 32 Old 09-29-2016, 06:54 AM - Thread Starter
Liked: 0
Yes - that is what I saw too - I was just hope I was miss some gem.
Any variant that meets that criteria then? or is it going to be an impossible search for El Dorado?
.tex is offline
post #24 of 32 Old 09-29-2016, 07:04 AM
Liked: 1120
I'm of the belief that proper positioning costs nothing, and you already have very good speakers.
cel4145 likes this.
post #25 of 32 Old 09-29-2016, 07:23 AM
cel4145's Avatar
Liked: 3018
+1
And experimenting with placing them on the desk is not permanent and takes 5 to 10 minutes to setup. You should try it and see. Could be you'll like the sound so much and be willing to sacrifice the desktop space. If not, then discuss this further. But right now, it makes more since to experiment some than to discuss it.
cel4145 is offline
post #26 of 32 Old 09-29-2016, 11:25 AM - Thread Starter
Liked: 0
+1
Ok - very good point --- And I don't really have the funds for new stuff anyways...
Just to be sure --> the Yellow position _may_ be acceptable, but the green _should_ be good?
I'll give it a go ASAP.
Thanks - really!
-Eric
Name:	Copy of EDH 1525 Desk & Speakers Layout - expanded - mod1.png
.tex is offline
post #27 of 32 Old 09-29-2016, 01:15 PM
Liked: 1120
Right now, green > yellow.
post #28 of 32 Old 10-01-2016, 06:48 PM - Thread Starter
Liked: 0
Thanks all - it took a bit more than 5-10 minutes but I moved everything around ( quite a few times) and have everything re-arranged in a far better manner now. (see attached).
One question I am hoping you can help with - Do you know of a good source for a 6" desktop speaker stand? As you can see the left speakers is on a floorstand (36") , but I have no place for one on the right, so it is on my 30" desk. Suggestions?
.tex is offline
post #29 of 32 Old 10-01-2016, 07:10 PM
pase22's Avatar
Liked: 3316
That looks a lot better than it was before so you're on the right track. Your best option would be to try fitting in your other stand so both speakers are at the same height and keep it out of your way. The ones I see available on amazon are somewhat expensive and impractical so DIY may be a better solution.
post #30 of 32 Old 10-01-2016, 10:01 PM
cel4145's Avatar
Liked: 3018
I make my own. Like this
cel4145 is offline
Reply Speakers
