Okay to leave subwoofer on all the time? - AVS Forum | Home Theater Discussions And Reviews
 10Likes
  • 2 Post By torii
  • 1 Post By danmar123
  • 1 Post By Bill Fitzmaurice
  • 1 Post By pase22
  • 1 Post By GLBright
  • 1 Post By Ben Tan
  • 1 Post By Lp85253
  • 1 Post By Doe Doe
post #1 of 25 Old 12-19-2016, 05:57 PM - Thread Starter
Quoted: 2581 Post(s)
Liked: 1200
Just wondering what most folks do here about subs that don't have auto on/off (or if it's faulty)?
Okay just to leave the sub on all the time? I was thinking of getting one of those surge protectors that can turn off connected devices based on a main device (which in this case would be the receiver), but that basically would be equivalent to yanking the plug out from the sub each time it turns off -- not sure if that's so great for the electronics.
I can't expect the sub to be drawing much power while off, besides a tiny bulb... but I typically don't like to leave devices on for no reason either.
Doe Doe is offline
post #2 of 25 Old 12-19-2016, 05:59 PM
torii's Avatar
Quoted: 3424 Post(s)
Liked: 1904
i leave all mine on auto. no issues yet and 2 of the subs 15+ years old
Doe Doe and Lp85253 like this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #3 of 25 Old 12-19-2016, 06:18 PM
Quoted: 24 Post(s)
I leave all my equipment on all the time, also @ very low volume.
It's not good to turn components on & off. Also keeps my cables burt in! Just my $.02
Doe Doe likes this.
Marantz 7702 mkii, Parasound 5250v2, Parasound 2003 MOD, Pioneer sx1280, Klipsh Heresy ii, Klipsch Forte II 2xs, Technics 1200 mk2 2x, Otari 5050 rr
B&W 804-F,803-R,805-FH,HTM1-C, MK 125ii 2x, Mapleshades platforms, Furman Elite 20
MIT HD23 RCA interconnects, OFC 12ga. custom speaker cable, BJ cables, Custom power cords, Dedicated sub panel, Oyaide outlets
Samsung PE6500, OPPO 203
danmar123 is offline
post #4 of 25 Old 12-19-2016, 06:56 PM
Bill Fitzmaurice's Avatar
Liked: 5770
Myth. But as to the OPs question, I leave my sub on all the time, for the same reason. It's been on for around ten years, maybe more, I've lost track.
Doe Doe likes this.
Bill Fitzmaurice is offline
post #5 of 25 Old 12-19-2016, 07:27 PM - Thread Starter
Liked: 1200
Thanks for the replies.
My concern wasn't turning the sub (or any devices) on/off, just doing it in a weird way by using an auto on/off surge protector ... which is the same as if I pulled the cord each time I wanted to turn it off. I read somewhere that for newer devices that may not even be so bad, just not sure if old subs would like it very much.
Guess it's not a big deal to just keep the sub on all the time, so I'll keep it as-is. Alternatively I may be able to hook it up to the back of my receiver (I need to check back there if it has a plug-in), but again that is still a 'pull the cord' type of deal as far as power goes.
Doe Doe is offline
post #6 of 25 Old 12-19-2016, 08:08 PM
Quoted: 24 Post(s)
If your handy, you can put an inline on/off switch in.
post #7 of 25 Old 12-19-2016, 08:17 PM
dswierenga's Avatar
Quoted: 133 Post(s)
Liked: 167
The only problem I can imagine is the possibility of a voltage surge during a lightning storm which might damage the subs' amp.
Panasonic TCP65VT60, Denon AVR-x6200w
Oppo UDP-203, Dish VIP722
NHT C4 front speakers, NHT C LCR center spkr
NHT Classic 3 surrounds
Velodyne Optimum 12 & DLS-5000R subs
dswierenga is offline
post #8 of 25 Old 12-19-2016, 08:56 PM - Thread Starter
Liked: 1200
Wouldn't a regular surge protector help with that?
Doe Doe is offline
post #9 of 25 Old 12-19-2016, 09:01 PM - Thread Starter
Liked: 1200
My sub has an on/off switch. Just not an auto one. It'd be a major pain to turn it on and off manually each time I wanted to use it, which is why I was wondering about an auto surge protector thingy. Apparently it's not needed, okay to just leave it on.
Doe Doe is offline
post #10 of 25 Old 12-19-2016, 11:46 PM
pase22's Avatar
Quoted: 3209 Post(s)
Liked: 2668
I accidentally put my sub to on istead of auto when I moved it into the bedroom. Stayed that way for months before I realized what I'd done. Never had any issues with the sub.
Doe Doe likes this.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #11 of 25 Old 12-20-2016, 03:29 AM
Quoted: 24 Post(s)
Now I got it. I have my subs connected to a Panamax MD2.It has a $100,000.00 equiptment policy.
post #12 of 25 Old 12-20-2016, 04:55 AM
Liked: 5770
You're more likely to be hit by lightning than for a surge to damage the amp.
post #13 of 25 Old 12-20-2016, 05:29 AM
GLBright's Avatar
Quoted: 101 Post(s)
Liked: 110
But it does happen. A storm took out my DefTech sub amp, a Denon integrated amp, and my garage door opener. Sad day. Still waiting on being struck myself though.
Lp85253 likes this.
GLBright is offline
post #14 of 25 Old 12-20-2016, 08:56 AM
Tay_lord's Avatar
Liked: 5
If the equipment has an auto function, I'll use that. Otherwise, I like to turn my equipment off when not in use.
LG OLED65C7P
Denon AVR-X4300H, NU3000DSP
KEF Q100
Marty Cube
PS4 Pro, HTPC
Tay_lord is offline
post #15 of 25 Old 12-20-2016, 12:07 PM - Thread Starter
Liked: 1200
I would think a regular surge protector should protect the equipment anyway... I mean, that is what surge protectors are for. If the device is on or off at the time... well, I suppose ideally it'd be off (or disconnected completely), but the odds of a surge breaking stuff would seem to be pretty rare to begin with, and even more so using a surge protector.
Doe Doe is offline
post #16 of 25 Old 12-20-2016, 12:39 PM
Liked: 5770
A surge protector is effective, but only against surges that generally wouldn't bother most audio gear anyway. At least they're cheap enough that there's no reason not to use them. They're ineffective against a major incident, like a lightning hit, where they'd get toasted along with everything else. The reason why you see big buck 'insurance' policies with these things is that their manufacturers know that the possibility of any gear attached to them being damaged is literally about the same as you getting hit by lightning. They're playing the odds, and the house always wins.
Lp85253 likes this.
post #17 of 25 Old 12-20-2016, 01:13 PM
jasonsong's Avatar
Quoted: 493 Post(s)
Liked: 185
Subwoofers that have auto function shut down the amp anyway. So technically it is shut down.
Now the ones that don't can be a bit problematic. I had this Jamo sub that would make a buzz as well as get hot. I shut that down. It does have a massive heatsink at the bottom but still. It's an old Jamo SW600.
jasonsong is offline
post #18 of 25 Old 12-20-2016, 11:32 PM - Thread Starter
Liked: 1200
I was referring to subs without an auto function, as otherwise that would be easy to figure out, just set it on auto and forget about it (assuming the auto function works, read a lot of times it can be flakey with some subs).
My sub is old and doesn't have an auto function, just on/off. I got it dirt cheap, so it's not a huge deal if the thing breaks -- and it's only so-so to begin with -- but I didn't want to accidentally hasten its demise by hooking up an auto on/off surge protector to it, if that could mess it up somehow. I believe the thing has been on for like a decade+ straight... so long as it's not gobbling up electricity, I'm fine with just letting it chug along as it has been.
Doe Doe is offline
post #19 of 25 Old 12-21-2016, 12:39 AM
Ben Tan's Avatar
Quoted: 527 Post(s)
Liked: 509
Let's look at it in simpler ways;
1) If you're going to be using it everyday, leave it on all the time.
2) If you're only going to use it once a week/month/year, then well... you know what to do.
Lp85253 likes this.
SVS Ultra Bookshelf + SVS Ultra Center
Prime Bookshelf Surround with Prime Elevation Heights
Dual Rythmik FV15HP
Yamaha RX-A3060 + Parasound Halo A31 + Emotiva A500
Ben Tan is offline
post #20 of 25 Old 01-26-2019, 08:00 AM
odeemae's Avatar
Quoted: 54 Post(s)
Thank you. Just purchased a new sub woofer and where I have it positioned it's a bit difficult to access the power switch. Now I can leave it on without worry
odeemae is offline
post #21 of 25 Old 01-26-2019, 10:51 AM
Quoted: 2026 Post(s)
Liked: 1697
if you have the auto on switch use it imo.. it saves on the amp being on all the time , which*may" help prolong amp life and save a little bit of electricity..
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #22 of 25 Old 01-26-2019, 11:01 AM
Liked: 1697
imo , it won't hurt anything to toggle it off at the end of use. i honestly believe *heat* is the enemy not current on/off.. it's all myth & magic.. everybody that chimes in will have anecdotal tales that will back up *their* thoughts...if you took actual studies ,1/2 the people on here would dispute it.. as a matter of fact i don't think it's worth worrying about with budget electronics...
Doe Doe likes this.
Lp85253 is offline
post #23 of 25 Old 01-26-2019, 11:12 AM - Thread Starter
Liked: 1200
Thanks, although this is a really old thread of mine, over 3 years old... took me a while to even remember what sub I was referencing.
On my main (old) sub, I'm not entirely sure why, but auto on/off kind of kicked in for it when I changed receivers. There isn't a switch for it, but it just sort of magically became active. Maybe my old receiver was giving it a low level signal for some odd reason and kept it in 'on' mode, not sure. A combination of audyssey/settings and minor position changes (nudged it away from the wall) also improved the sound with it too... can't say it's great (not like I even know what a 'great' sub sounds like) but I can say it beats mediocre subs (Bic, etc).
On my secondary setup, I just use an on/off power bar, as it's mostly for gaming/occasional streaming, and I just turn that sub and the avr off at the same... mostly out of habit.
Doe Doe is offline
post #24 of 25 Old 01-26-2019, 11:14 AM
Liked: 1697
lol , i didn't even check the dates since it was up hi on the 1st page... my bad...
Lp85253 is offline
post #25 of 25 Old 01-26-2019, 11:20 AM - Thread Starter
Liked: 1200
I've done that too. I remember writing up a long response to someone a while back, and right before I hit submit I thought the topic seemed oddly familiar. Then I check the date and it was like a 5 year old thread that someone revived... an odd thread that got brought back from the dead a couple of times.
Lp85253 likes this.
Doe Doe is offline
Reply Speakers
