Monoprice Crossover points - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-12-2017, 02:24 PM - Thread Starter
Liked: 0
Is there anywhere I can find the crossover ranges for the monoprice in-wall speakers? More specifically the Amber series? Curious to see what the ranges are for the different drivers of the 3-way and 2-way.
Eric Hansen is offline
post #2 of 4 Old 01-12-2017, 02:45 PM
Elihawk's Avatar
Quoted: 1918 Post(s)
Liked: 2060
I don't see that, but this is as much spec as you are going to get from most companies...
https://www.monoprice.com/product?c_...seq=1&format=2
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #3 of 4 Old 01-12-2017, 02:57 PM - Thread Starter
Liked: 0
Ya I've seen that but most of the time you can get the crossover points, for example you can find the crossover points on all the klipsch speakers http://assets.klipsch.com/product-sp...Spec-Sheet.pdf - those are set at 1,500hz
post #4 of 4 Old 08-02-2017, 04:35 PM
MonopriceAudio's Avatar
Liked: 1
I really like these speakers. The Mid/High crossover is 4kHz and the Low/Mid crossover is 650Hz. Be on the look out for matching mains and satellites.
MonopriceAudio is offline
Reply Speakers
crossover , Monoprice
