AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Speakers (https://www.avsforum.com/forum/89-speakers/)
-   -   Would you be able to hear any difference in sound? (https://www.avsforum.com/forum/89-speakers/2733713-would-you-able-hear-any-difference-sound.html)
jomartz 01-30-2017 07:02 AM
If the only thing you change in any given sound system are the cables, Would you be able to hear any difference in sound?
pase22 01-30-2017 07:05 AM
No!
JonfromCB 01-30-2017 09:11 AM
Only if you have been convinced that you will and believe that you do.
eljaycanuck 01-30-2017 09:14 AM
Depends. For example:
- If the old cables are defective and the new cables work properly, I would hear a difference.
- If the old and new cables work properly and are of comparable quality, I would probably not hear a difference.
Gooddoc 01-30-2017 09:17 AM
These threads are painful to see, but I can't help rubbernecking :).
Bill Fitzmaurice 01-30-2017 09:28 AM
You could, because there are three factors that will alter response: resistance, capacitance and inductance. The more important question is if spending more than $1 per foot for cable will give better resistance, capacitance and inductance than spending less. The answer to that question is no. For that matter many seriously expensive cables, as in over $100 per foot, even $1,000 per foot, have worse specs than very inexpensive cables.
mtrot 01-30-2017 03:41 PM
Oh boy, you had to do it. Putting on protective equipment now. Yes, the difference between some cables is easily detected.
A9X-308 01-30-2017 07:44 PM
When you know what you're listening to, yes. Otherwise, no.
1201 01-30-2017 08:39 PM
I would spend the money on a better AVR. those sony dh ones are suck ;)
nbp_civic 01-30-2017 09:45 PM
A cheap cable would work the same as an expensive cable. Expensive cables are for esthetics and most of the time durability. I usually buy cheap to normal quality cables. I would consider monoprice products to be normal quality.
littlefoott 01-30-2017 11:24 PM
24 gauge wire vs 14 gauge wire at 140 watts = maybe.
bluewizard 01-31-2017 06:58 AM
I would say the answer is - Likely NO.
Because I am not an absolutist, I concede that there might be some circumstance on some system where you could hear a difference in Speaker Cable. Note I am not saying you will, only that it could happen. But that would be with a very expensive, and very revealing and transparent system. Likely far above the cost available to use mere mortals.
I would say that for most people most of the time, quality but generally common wire of the right size, is all you really need.
Here is a link to Percent of Signal Loss for various wires and various speaker impedance, which will help in determining the right size and the right length.
https://www.avsforum.com/forum/89-spe...tml?highlight=
For the above, see Post#2 for all the charts.
Here is another thread that analyzes the Power Capabilities of common Speaker Wire -
https://www.avsforum.com/forum/89-spe...ch-enough.html
Though the above link is more FYI than practical information.
For a vast majority of people in a vast majority of circumstances, common Oxygen Free Copper (OFC) Wire of 14ga is fine, and it is reasonably cheap.
Now if you want nicer looking wire, you can spend a bit more, but on the issue of what you spend, if you look near the end of this threads where the summary charts are posted -
https://www.avsforum.com/forum/89-spe...d-you-pay.html
POST # 193 Charts -
https://www.avsforum.com/forum/89-spe...l#post42741506
You will see that a majority of people surveyed paid well under 5% of their total system cost on ALL wire and cable. Many in the 2% to 4% range.
Again, for a vast majority of people common OFC 14ga Copper is all you need to get the job done.
Steve/bluewizard
locqho 01-31-2017 07:20 AM
Good system: yes. Bad one: no.
Bill Fitzmaurice 01-31-2017 07:45 AM
The system doesn't matter. That's an audiophool myth, one concocted by the sellers of over-priced systems and over-priced wire.
18Hurts 01-31-2017 09:06 AM
That depends
I've seen people use telephone cable to make 100 foot runs and yes, changing to 12 gauge really improved the sound. The difference between 16 AWG and 12 AWG at shorter runs is not detectable. The pro sound guys have charts to help you select the right gauge cable for lengths of runs and what impedance and power used. Back in my PA days, I used 12 and 14 guage Rapco cable, it could be run over by trucks, stepped on by drunks, rained on etc. and no problems. For short 25 foot cables, I went 14 guage but had 12 AWG 50 footers for outside use.
If you are using something like SpeakerPower 12 KW amps at low impedance or Powersoft K20 stadium amplifiers, use the cable they specify in the manual.
For speaker wire, I purchase 100 foot spools of the stuff and use it for subwoofer wiring in the house and out in the garage. Use it for AVR wiring and wiring the PA amp to some large speakers for summer BBQs. Since I can be running 10 to 100 feet or higher wattage for outdoor use, I tend to buy spools of 12 AWG. A good catch all guage just in case I need to push the subs outside at 100 feet, if you don't do that--14 AWG is good for in home use when purchasing spools of the stuff. Oddly enough, it is more important to go higher guage for the much longer runs to rear surrounds in a basement than the three mains that are close to the amplifiers.
If it looks weird to run different guages to different speaker lengths, just use the guage that is required for the longest run.
As far as brand, I strongly recommend the copper kind with insulation. If it is good enough to wire the internals of the amplifier and internal wiring of your speaker--it will work fine. If you want mystical properties, it is no fun to change out all the wiring in your amp and rewire the speaker and crossover to match.
Enjoy! :)
mitchco 01-31-2017 09:17 AM
bluewizard 01-31-2017 10:40 AM
We have to attach some "IFs" to our comments. If he is using reasonable sized wire, and if he is using something in the range of common Consumer Audio Systems, then likely he won't hear a difference.
However, If he has a massively expensive, and truly transparent and revealing system, then he MIGHT here a difference.
But for the moment I'm going to assume his system is somewhere in the spectrum of common consumer systems.
The thing you want to avoid is excess spending on the speaker wire. In a recent discussion, someone posted a question about his system. He detailed the system and indicated he has a 40w/ch NAD C320BEE which is their smallest model. But he also indicated he had this very expensive cable -
https://www.audiovisualonline.co.uk/...speaker-cable/
£7.50/meter, when constructed into a common length cable (3m/10ft), and terminated with QED Banana Plugs, the cable comes to £52.50 for EACH Cable, so £105/pair, which is $132/pair at current exchange rates. I'm OK if he wants to spend that kind of money on speaker wire, but likely that wire did no better job that $0.36/foot wire like this -
https://www.parts-express.com/audtek...50-ft--100-020
In another thread, someone was complaining because they couldn't afford a relatively modest £500 Stereo Amp because it was going to cost him another £500 for wire and cable. Our suggestion to him was - DON'T SPEND £500 ON WIRE AND CABLE.
While others will deny it, there is a reasonable sense of proportion. You do not put $500 speaker wire on a $500 Amp. Better to spend $900 on the amp and $100 on the wire. Though realistically, you could spend $975 on the Amp and $25 on the speaker wire.
Generally, most people spend well under 5% of the total system cost on ALL wire and cable. So, keep thing reasonable. If you happen to have a $5000 system, then you can probably afford to also spend $500 on wire and cable, you can afford it, but you really only need to spend around $100 to $200 depending on your specific configurations.
I use a percent of system cost, though others disagree, but the goal is to keep thing from getting grossly out of proportion.
Generally, sanity and bounds of reason must rule the day.
Steve/bluewizard
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
