Need Help with home audio setup - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By pase22
post #1 of 3 Old 05-21-2017, 01:32 PM - Thread Starter
Liked: 0
First off, I am a bit of a newbie so please spare me. I wanted to know it this was a viable audio setup.
1. Bluetooth audio transmitter into the input of a preamp via R/L cables.
2. Output of preamp into powered subwoofer via R/L cables.
3. High filter out of the subwoofer into amp via R/L cables
4. Out out the amp into main speakers via speaker wire
I realize that this is not ideal, however I am balling on a budget. I just want to know if this will work without sounding like crap. My amp is ancient and does not have a subwoofer or L/R out. Thank you.
brady l is offline
post #2 of 3 Old 05-21-2017, 04:05 PM
pase22's Avatar
Quoted: 3415 Post(s)
Liked: 2883
Why not just use speaker wire? In from speakers to sub, out from sub to amp then use the crossover on the sub.
I had it hooked up that way before upgrading my receiver. Worked well but, much better with a receiver that has bass management.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #3 of 3 Old 05-21-2017, 04:15 PM
pase22's Avatar
Liked: 2883
Not sure how restricted your budget is, but You can get a receiver with sub out and bass management for <$200 from A4L.
http://www.accessories4less.com/make...ceivers/1.html
pcfriedrich likes this.
pase22 is offline
Reply Speakers
preamp , setup , setup help , subwoofer
