I have a Dolby Atmos 5.1.2 setup right now, and for the main Left and Right channels I have Pioneers SPFS52 Andrew Jones Speakers.
I have on Layaway with my local audio dealer, a pair of Monitor Audio Bronze B6's. My main question would be....before I make this investment... is it worth it? I sure have heard both and theres a difference. But wanted to know the opinion of some of the enthusiasts here in the forums.
My opinion may not be worth much as I'm not an expert nor am I familiar with your Andrew Jones speakers however I have owned a set of Monitor Audio Silver series speakers for about 10 years now and they are superb, even after all this time. Clear, full and great base, I'm very happy with their product.
They will be a noticeable upgrade, however going with Monitor bronze 2's and upgrading the sub would have a much greater impact on your listening enjoyment, especially for HT. A set of speakers crossed over to a good sub at 80hz eliminates the need for towers.
Thanks for the recommendations. Ill take this under considerations and see.
I previously had a Polk Audio Sub, and after 5 or 6 years it died. And replaced it with a MA Bronze BX Sub. Combined with MA Radius HD all around.
Then came the interest in building something for ATMOS. At the time I bought this Pioneers towers for a good price. But wanted something at the long run from MA quality.
Why I bought towers?, was more from a safety point. Since my kids accidentally have bumped speaker stands and got me worried. Decided then to buy towers instead which are more solid on the floor.
Huge upgrade, whether you go bookshelf or tower. There is no question. Silver series even more so. Just to point out...a tower speaker and bookshelf speaker with sub won't sound the same. The tower will have a fuller sound due to the bass/mid bass coming from the tower above 80hz. Not saying one is better than the other, it's all personal preference. I just often read people saying there's no need for towers if you use a sub with bookshelves. It's not exactly the same sound. Both options have pros and cons.
I think speaker upgrades are the best bang for your buck, up to about 10k per pair, assuming you have enough power for your listening level. Then the difference becomes more marginal.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
