G-Wiz Products Speaker Stands Review - AVS Forum | Home Theater Discussions And Reviews
 10Likes
  • 2 Post By prof55
  • 1 Post By prof55
  • 1 Post By gajCA
  • 1 Post By aerodynamics
  • 2 Post By gwizpro
  • 1 Post By prof55
  • 2 Post By SunByrne
  • 1 Post By SunByrne
post #1 of 25 Old 08-22-2017, 03:03 PM - Thread Starter
Moderator
Moderator
prof55's Avatar
Quoted: 23 Post(s)
UPDATE:After some issues with dimensions (see Post #11 for specific details), I have received replacement center posts from the maker.
The final result is a very usable product, but still with a minor variance in dimensions (~1/16" slant L/R & fr/bk). This issue would probably not be noticeable in most applications, but with my particular speaker arrangement (see pic below) it did require shimming to perfectly align the tops of the L/center/R speakers.
In short, these stands work, but didn't completely meet my rather exacting standards. Very much to his credit, Tom from GWiz has posted in this thread (see Post #21) and described both the issues and the steps he has taken to correct them. I suspect my experience has been singular (the unfortunate meeting of my tight standards and Tom's temporary saw issues), and I expect we'll see better reviews in the future.
Garry
Ordered from G-Wiz Products
Packing is minimal, but they did arrive safely:
Hole alignment is not what you'd call precision...
...and neither are the "right angles":
I chose "Gently Eased" for "Base Edge Style", other available choices are "Round Over" and "Bevel". Long edges are good, but corners are very sharp, with chipped finish:
Comments:
Shipping: I ordered on July 25 2017, received August 22 2017. Their website states "Your order will be built and shipped within 3 weeks from date that we receive payment.", so they did come fairly close.
Quality: Not what I would call "finish carpentry", but adequate for the price ($180.00 shipped). Holes are misaligned (off by 1/8"+), and you'll need to lay the stands sideways on a flat surface while tightening screws to end up square. Two of the boards were not square (off by 1/6"+), not an issue with my application but could be critical to some. Wood quality is good, finish is average.
Advertising: The day I ordered their site said "Huge Sale, 20% off, Ends Tuesday July 25". This date was changed daily to the current date for at least the next two weeks. I'd have to question the ethics involved in a "sale" that ends daily and starts again instantly... I see their site now just says "Huge Sale, 10% Off".
Overall: If you have very specific requirements for dimensions/finish (LOTS of choices available!) and don't want to spend a lot of $$$, these stands fill the bill. If you're looking for furniture quality (or even IKEA quality) these may not be for you. I'm not thrilled, but I am happy with how these fit and look.
Garry
Zorba922 and madhuski like this.
prof55 is offline
post #2 of 25 Old 08-22-2017, 03:23 PM
gajCA's Avatar
Quoted: 8585 Post(s)
Liked: 5784
Garry[/SIZE][/B]
Thanks for the review; very thorough.
I must say, they do look nice in your last photo which is the way most people would view them.
Really match well with the other wood, (organ? and fireplace surround).
Nice looking setup; what are the speakers if you don't mind my asking?
Geoff A. J., California
gajCA is offline
post #3 of 25 Old 08-22-2017, 05:12 PM - Thread Starter
Moderator
Moderator
prof55's Avatar
Quoted: 23 Post(s)
L/R front speakers are Electro-Voice Sentry V (10" woofer, compression horn), center is the same but modified to fit. They were built in the early 70s, I'm a big fan of old two-ways lol.
gajCA likes this.
prof55 is offline
post #4 of 25 Old 08-23-2017, 09:43 AM
gajCA's Avatar
Liked: 5784
Nice!
gajCA is offline
post #5 of 25 Old 08-27-2017, 12:38 PM - Thread Starter
Moderator
Moderator
prof55's Avatar
Quoted: 23 Post(s)
Update: I've been trying to do the final alignment on this setup, and was unable to get things level between the L/R and center speakers. At first I thought it was the carpet, then I measured the stands... Both of them lean left-to-right by nearly 1/8"! I'll update as I receive word, but I'd avoid this dealer at present.
prof55 is offline
post #6 of 25 Old 08-27-2017, 12:40 PM
gajCA's Avatar
Liked: 5784
I'd just add adjustable speaker spikes to the stands.
https://www.parts-express.com/dayton...m_campaign=pla
leecreek likes this.
gajCA is offline
post #7 of 25 Old 08-27-2017, 01:33 PM - Thread Starter
Moderator
Moderator
prof55's Avatar
Quoted: 23 Post(s)
Unfortunately that wouldn't work, I can't add to the height. These stands were supposed to put L/R in vertical alignment with the center channel, top of all speakers only clears the bottom of the screen by about ¼" (last pic, 1st post).
prof55 is offline
post #8 of 25 Old 08-27-2017, 02:10 PM
SunByrne's Avatar
Quoted: 159 Post(s)
Liked: 262
I recently ordered from them as well. We'll see how it turns out, as mine haven't shipped yet.
_____
Study: Schiit Bifrost Multibit > Yamaha A-S500 > Ascend Acoustics Sierra-2/Emotiva S8
Living Room HT: Oppo BDP-83 > Denon X3400H > PSB Image 4T/8C/S50/Rythmik L22
Office: Schiit Modi 3 > NAD C740 > Ascend Acoustics Sierra-1 NrT
Bedroom: Onkyo TX-8050 > PSB Image 1B/SubSonic5
SunByrne is offline
post #9 of 25 Old 08-27-2017, 03:16 PM
Quoted: 197 Post(s)
Liked: 1836
Take them apart and square up the H beam portion.
leecreek is online now
post #10 of 25 Old 08-27-2017, 06:06 PM - Thread Starter
Moderator
Moderator
prof55's Avatar
Quoted: 23 Post(s)
Then they would be too short. I could cut them off square and add spikes, but I don't think "custom made" stands should require this amount of work.
prof55 is offline
post #11 of 25 Old 08-27-2017, 10:16 PM - Thread Starter
Moderator
Moderator
prof55's Avatar
Quoted: 23 Post(s)
I've contacted the company, they say to pack them up and they'll send a UPS label for return. They've also promised to send a new set the same day they receive the return. I'm going to do it, but considering that I waited over a month for these I'm also going to post pics of the problems.
Measurements (all supposed to be 11"):
Front/side (on verified level tile floor):
Side view:
prof55 is offline
post #12 of 25 Old 08-28-2017, 07:41 AM
SunByrne's Avatar
Quoted: 159 Post(s)
Liked: 262
Thanks for the measurements, @prof55 . Does not make me optimistic about my pending order.
_____
SunByrne is offline
post #13 of 25 Old 08-28-2017, 10:07 AM
gajCA's Avatar
Liked: 5784
Let us know your impressions.
Glad to see GWiz is at least giving the OP a second set.
They'd better have their best guy put those together as the first set were not exactly a perfect match which is exactly what the OP requires.
I must admit I've never double checked any stands I've used but then again I didn't have the exacting requirements the OP needs.
gajCA is offline
post #14 of 25 Old 08-28-2017, 11:20 AM
Quoted: 197 Post(s)
Liked: 1836
Me either, but I tend to spread my speakers out some. I wouldn't have them like that. YMMV
post #15 of 25 Old 08-28-2017, 01:13 PM - Thread Starter
Moderator
Moderator
prof55's Avatar
Quoted: 23 Post(s)
I'll admit my application may be a little out of the ordinary, but I expect tolerances better than ± 1/8" on ANY item like this, be it a stand, speaker cabinet, shelf, or whatever. I don't think that's unreasonable, and I hope this is not beyond current woodworking practices.
Call me old, but if these stands were graded when I took high school wood shop (1970) they would have received a "D".
prof55 is offline
post #16 of 25 Old 08-28-2017, 01:21 PM
gajCA's Avatar
Liked: 5784
Can't argue with you there; the ruler does not lie.
gajCA is offline
post #17 of 25 Old 08-28-2017, 05:12 PM
Quoted: 197 Post(s)
Liked: 1836
And that might be where they originated from....lol
post #18 of 25 Old 09-07-2017, 01:34 PM - Thread Starter
Moderator
Moderator
prof55's Avatar
Quoted: 23 Post(s)
Finally received repaired stands, Post #1 updated.
prof55 is offline
post #19 of 25 Old 09-07-2017, 05:35 PM
SunByrne's Avatar
Quoted: 159 Post(s)
Liked: 262
Thanks for the update. Mine are supposed to arrive Monday so we'll see how things compare.
_____
SunByrne is offline
post #20 of 25 Old 09-07-2017, 10:39 PM
aerodynamics's Avatar
Quoted: 279 Post(s)
Liked: 129
Geez, if you're going to start a business making furniture, the least you can do is check your table saw for square and invest in a doweling jig.
prof55 likes this.
aerodynamics is offline
post #21 of 25 Old 09-11-2017, 04:52 PM
Liked: 2
Tom from GWiz Products
HI guys, this is very first review that has been negative in over 10 years.
We absolutely did have issues with a new table saw (Saw Stop)and cutoff saw we purchased.
The units have been re calibrated and all is well now.
We pride ourselves in a Quality product.
We have reviewed this review and have taken steps to alleviate any future problems.
Thank You for your review as it makes us just that much better.
Tom Gillespy
Owner
GWiz Products
724 864-0200
gajCA and leecreek like this.
gwizpro is offline
post #22 of 25 Old 09-11-2017, 07:40 PM - Thread Starter
Moderator
Moderator
prof55's Avatar
Quoted: 23 Post(s)
Tom Gillespy
Owner
GWiz Products
724 864-0200
Post #1 updated once again, and many thanks to Tom of GWiz for appearing here to explain.
gajCA likes this.
prof55 is offline
post #23 of 25 Old 09-12-2017, 10:39 AM
SunByrne's Avatar
Quoted: 159 Post(s)
Liked: 262
Mine are supposed to arrive tonight, after Harvey-related shipping delay. I have a pretty busy week this week so I'm not sure how much detail I'll be able to provide, but at least it'll be another data point.
gajCA and prof55 like this.
_____
SunByrne is offline
post #24 of 25 Old 09-12-2017, 10:56 AM
Quoted: 197 Post(s)
Liked: 1836
Have a pair of old EV's here ...12TRXB's. small world
post #25 of 25 Old 09-15-2017, 09:04 AM
SunByrne's Avatar
Quoted: 159 Post(s)
Liked: 262
OK, they arrived, they're assembled, and the review is up. Happy to report did not have the issues @prof55 did.
https://www.avsforum.com/forum/89-spe...l#post54803248
gajCA likes this.
_____
SunByrne is offline
Reply Speakers
