Center channel recommendation: light <$150 available ASAP w/ Paradigm Monitors - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Zorba922
  • 1 Post By pase22
post #1 of 9 Old 11-27-2017, 11:43 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
Looking for center channel speaker recommendation. As a stopgap, I bought a Definitive Technology ProCenter 1000 Compact Center Speaker at BestBuy on Black Friday for $164. Looking to upgrade or get similar quality for lower price.
I live in Kenya and am in the US for one more week, so I have limited time to find something. Selection in Kenya is super limited and expensive, as you might imagine. I moved a portion of my US inventory with me and am trying to do a feasible upgrade.
Basic specs looking for:
- reasonably cheap: approx under $150 - 175: I'll probably sell it there when I move back and don't think there's a deep resale market
- pretty lightweight: 15 lbs max; preferrably under 10 lbs; will take it in my suitcase and have limited excess pounds
- lower height dimensions: no specifics specs; just looking for something not too tall
- paired with Paradigm mini-monitors v7 bookshelves: I'm not looking for to match them as it's not feasible. I already have a matching 28 lb monitor center channel I'm storing here. Maybe an older version paradigm center channel on ebay might be better than other brands?
- need to get it by next Wed Dec 6th. That means my ability to bid on ebay is limited.
- time is limited; won't have too much time to do extensive research or even test product (parents, where I am staying, don't have a receiver)
- My receiver is a decent entry / mid-level Onkyo 7.1 with enough power for what I need (don't remember model # or specs)
Any suggestions? I realize the weight constraint will limit potential quality.
Since I'm not matching the exact bookshelves, is there a certain best bang-per-buck, more compact center channel that is recognized? Maybe more mass-market brand vs. Paradigm? Should I look for an older, smaller, cheaper Paradigm center on ebay? I saw something from the cinema line, which I know nothing about.
navimag is offline
post #2 of 9 Old 11-28-2017, 08:16 AM
Quoted: 2026 Post(s)
Liked: 1697
bic fh6 lcr...
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #3 of 9 Old 11-28-2017, 08:17 AM
Zorba922's Avatar
Quoted: 7061 Post(s)
Liked: 5364
Best option under $200:
https://www.amazon.com/BIC-America-F.../dp/B0015A8Y3E
Even though it's got 6.5" woofers, the sealed design makes for a compact cabinet. About 18lbs though.
Lp85253 likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #4 of 9 Old 11-28-2017, 09:23 AM
zieglj01's Avatar
Quoted: 3005 Post(s)
Liked: 2910
If you can handle the weight -- the JBL Arena center would be my choice, and a good option to work with your Paradigm
https://www.amazon.com/JBL-Arena-125...l+arena+center
Who AM I
zieglj01 is online now
post #5 of 9 Old 11-28-2017, 09:41 AM
pase22's Avatar
Quoted: 3209 Post(s)
Liked: 2668
NHT Super one 2.1. Turn it sideways as a center. Well within budget and weighs 9lbs or 10 lbs boxed weight.
https://www.amazon.com/NHT-SuperOne-...ds=nht+speaker
obordin likes this.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #6 of 9 Old 11-28-2017, 11:43 AM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
Great, thanks for the ideas.
Need to do some weight calcs to see if I can stretch for an 18 lb option. If not, NHT definitely helps in that category.
Just to confirm - I assume these would be better than the speaker I purchased as a standby (see link below)? And also better than an older Paradigm center, say cinema series?
For reference, this is the Def Tech speaker I purchased as a standby: https://www.amazon.com/Definitive-Te...Center+Speaker
navimag is offline
post #7 of 9 Old 11-28-2017, 03:01 PM
Zorba922's Avatar
Liked: 5364
Yes, the SuperOne would be better...other options for buying a single TM bookshelf for center use:
  • Ascend CBM-170SE
  • Hsu HB-1
  • Wavecrest HVL-1
The advantage of buying those 3 instead of the NHT is that you can call up the company and ask them to pre-rotate the tweeter for horizontal placement (unless you're going to use it vertically).
Zorba922 is offline
post #8 of 9 Old 11-28-2017, 11:09 PM - Thread Starter
Quoted: 14 Post(s)
Liked: 0
  • Ascend CBM-170SE
  • Hsu HB-1
  • Wavecrest HVL-1
Super helpful. Thanks again.
Will there be much difference between the NHT SuperOne and the Hsu / Ascend / Wavecrest options?
The NHT is a little lighter and therefore preferable all else equal, but I really liked the Hsu sub I previously owned and wonder if it'd be worth the extra weight to buy the Hsu option (or Ascend or Wavecrest if those are better)?
navimag is offline
post #9 of 9 Old 11-29-2017, 07:12 AM
Zorba922's Avatar
Liked: 5364
Will there be much difference between the NHT SuperOne and the Hsu / Ascend / Wavecrest options? The NHT is a little lighter and therefore preferable all else equal, but I really liked the Hsu sub I previously owned and wonder if it'd be worth the extra weight to buy the Hsu option (or Ascend or Wavecrest if those are better)?
Depends on how picky you are, really. If you want maximum accuracy and detail, I'd pick the Ascend. Both the Hsu and Wavecrest are known to have a slight treble roll off which makes them preferable to those who are sensitive to high frequencies and want a bit of "warmth," esp. during music...such ears might find the NHT to be slightly "bright." The Ascend would probably be the safest choice because it's consistently described as "neutral" which its measurements confirm.
Zorba922 is offline
Reply Speakers
budget , center channel , small
