Alcons Audio - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By taskvig
post #1 of 13 Old 12-09-2017, 04:44 PM - Thread Starter
taskvig's Avatar
Alcons Audio
Coludn't find any thread for Alcons Audio, is there any?
And is there any Alcons users here?
taskvig is offline
post #2 of 13 Old 12-09-2017, 05:21 PM - Thread Starter
taskvig's Avatar
I am plannig to connect my newly bought Alcons CR2 during next week, replacing (at least for a test) my "DIY JBL M2 hybrids
taskvig is offline
post #3 of 13 Old 12-09-2017, 05:31 PM
kyzer soze's Avatar
Quoted: 518 Post(s)
Liked: 364
I know @thxman has alcons setup you could ask him.
Also the Alcons thread might be somewhere in here:
https://www.avsforum.com/forum/86-ult...t-gear-20-000/
Ascend Sierra 2's (LCR & side surrounds) + Pioneer atmos modules. 5.1.4 setup
Marantz AV7703
Rythmik FV15HP
JVC DLA-X590R (RS 440) projector
Stewart StudioTek 130 screen
kyzer soze is offline
post #4 of 13 Old 12-09-2017, 07:53 PM
Quoted: 1785 Post(s)
Liked: 1482
There's a thread about their recent CEDIA demo in the ultra-high-end subforum.
The consensus seems to be they can play absurdly loud without distortion and have enough HF energy to peel the paint off of the walls.
HT: Sony 940C, Oppo 203, Harman/Kardon DPR1001, Infinity Interlude IL40 x2, Infinity Interlude IL36C, Infinity MS-1 ii x2, Infinity MSW-1
Computer: Elac Uni-Fi UB5 x2, Elac Element EA101EQ integrated amp, SVS SB-12NSD
Dedicated 2-channel: Infinity Intermezzo 4.1t towers, Bluesound Node 2, Emotiva PT-100, Crown XLS 1502, Furman PL-8C
TuteTibiImperes is offline
post #5 of 13 Old 12-10-2017, 12:03 PM
thxman's Avatar
Quoted: 670 Post(s)
Liked: 718
thxman is offline
post #6 of 13 Old 12-10-2017, 12:04 PM
thxman's Avatar
Quoted: 670 Post(s)
Liked: 718
Congrats, looking forward to your impressions.
thxman is offline
post #7 of 13 Old 12-11-2017, 02:28 PM - Thread Starter
taskvig's Avatar
I've never listend to Alcons in hometheaters before, but the local cinema have a set of CR2 and it sounds real good!
It is also fun to watch Movies at this cinema, useing quite a bit of Alcons
My CR2 are similar to CRMS but uses a larger 6" ribbon and dual 8". Unfortuntely I don't have the sentiel amps but will be useing Crown instead.
taskvig is offline
post #8 of 13 Old 12-11-2017, 03:29 PM
mmiles's Avatar
Quoted: 1006 Post(s)
Liked: 516
Depending on model and series it may require the Alcons amps.
Where are you located?
Mike Miles
[email protected]
mmiles is offline
post #9 of 13 Old 12-12-2017, 02:39 AM - Thread Starter
taskvig's Avatar
My speakers need active crossover between mid/high and woofer, but otherwise it's fine running without the Alcons amp, an alternative is to make passive crossover at 270hz. The local cinema is also running their set With ordinary amps and Yamaha processor doing the crossover and EQ, I'll be useing Crown/BSS.
I'm located in Norway.
Anyone know what SIS really means/is? The SIS pre-wiring ensures complete (long!) cable/connector compensation between CR2 and ALC
taskvig is offline
post #10 of 13 Old 12-12-2017, 05:30 AM
mmiles's Avatar
Liked: 516
Since you are in Europe you can reach out to Alcons direct. I got Tom’s contact info somewhere.
Mike Miles
[email protected]
mmiles is offline
post #11 of 13 Old 12-19-2017, 03:18 PM - Thread Starter
taskvig's Avatar
Finally I got the chance to connect my Alcons peakers today
The design of the boxes is an real issue in my kinda small room so I might need to consider makeing DIY boxes for them
PS: Normally everything is hidden behind the screen and covers
thxman likes this.
taskvig is offline
post #12 of 13 Old 04-29-2018, 04:39 AM
clausdk's Avatar
Quoted: 254 Post(s)
Liked: 97
Bumping this thread. With all the mentions of Alcons Audio are there any new owners?
Just noticed their new VR5 which has a slanted cabinet might be useful as a wide channel although ment as a small studio monitor. Uses the new 90x60° horn and 2" pro-ribbon.
clausdk is offline
post #13 of 13 Old 05-03-2018, 12:41 PM
Kain's Avatar
Quoted: 2003 Post(s)
Liked: 900
Try asking in this forum on AVS: https://www.avsforum.com/forum/86-ult...t-gear-20-000/
There are a few Alcons Audio owners there.
Kain is offline
Reply Speakers
