Best in ceiling speakers for LCR under $800 a unit - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By RayGuy
  • 1 Post By Ellebob
post #1 of 13 Old 12-13-2017, 01:56 PM - Thread Starter
Rockokma's Avatar
Quoted: 46 Post(s)
Hello, can anyone recommend in ceiling speakers under $800 a unit for LCR? The speakers will be about 11' in front of ears and ceilings are 9' high. Master bedroom is directly above the speakers.
Thank you in advance.
Rockokma is offline
post #2 of 13 Old 12-13-2017, 08:07 PM
Zorba922's Avatar
Quoted: 7286 Post(s)
Liked: 5582
Are you absolutely sure you want to do in-ceilings for your FRONTS? They're passable for surrounds, but for fronts you are basically shooting yourself in the foot.
If it's a done deal, I'd look at the bigger MTM designs by JBL and NHT, google them.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #3 of 13 Old 12-14-2017, 10:41 AM
gajCA's Avatar
Quoted: 9253 Post(s)
Liked: 6359
At the very least get a real center channel as it does all the heavy lifting.
Not sure I'd spend more than this as these have received rave reviews from AVS members.
https://rslspeakers.com/c34e-ceiling-speaker/
Geoff A. J., California
gajCA is offline
post #4 of 13 Old 12-14-2017, 11:46 AM - Thread Starter
Rockokma's Avatar
Quoted: 46 Post(s)
Looking for something with an angle or amiable for the fronts. Also enclosed.
Rockokma is offline
post #5 of 13 Old 12-14-2017, 11:53 AM
gajCA's Avatar
Liked: 6359
The RSLs are angled; you could talk to them about back box solutions.
gajCA is offline
post #6 of 13 Old 12-14-2017, 12:27 PM
zieglj01's Avatar
Quoted: 3214 Post(s)
Liked: 3114
zieglj01 is offline
post #7 of 13 Old 12-14-2017, 01:45 PM - Thread Starter
Rockokma's Avatar
Quoted: 46 Post(s)
That is on the top of my list.
An installer just recommended the LCR.5S. Not sure if anyone can compare the LCR.5S to the Definitive Tech UIW RSS II's.
Rockokma is offline
post #8 of 13 Old 12-14-2017, 03:04 PM
RayGuy's Avatar
Quoted: 2919 Post(s)
Liked: 2696
Golden Ear has gotten a lot of good press on their in-ceiling 7000 series, some even claiming that the sound does not appear like it's coming from the ceiling(?!) ... but check with GE to see if the listening distance is sufficient for the speakers to perform properly with those 11' ceilings.
https://www.goldenear.com/products/invisa-series
Review: https://www.digitaltrends.com/home-t...nvisa-htr-mpx/
snpanago likes this.
RayGuy is offline
post #9 of 13 Old 12-14-2017, 03:27 PM
Quoted: 421 Post(s)
Liked: 307
Maybe you could check out the PSB C-LCR's. Here is the review from Hometheaterreview.com:
https://hometheaterreview.com/psb-c-...aker-reviewed/
I believe these are right in your price range.
Rgarc is offline
post #10 of 13 Old 12-14-2017, 10:37 PM
Quoted: 1889 Post(s)
Liked: 1089
You want speakers that angle at least 30 degrees. Here's a post I wrote a while ago, look at post #5 and #7 .
https://www.avsforum.com/forum/89-spe...l#post53625065
RayGuy likes this.
Ellebob is offline
post #11 of 13 Old 12-14-2017, 10:52 PM
Quoted: 423 Post(s)
Liked: 179
Revel c763l or dynaudio s4c80
love_that_sound is offline
post #12 of 13 Old 01-08-2018, 11:51 PM
Liked: 0
The best I've heard so far in your price range are the Goldenear HTR-7000 and the B&W CCM Cinema 7. Would like to know what you went with and why..
bubbabasco is offline
post #13 of 13 Old 01-09-2018, 03:48 PM
mmiles's Avatar
Quoted: 1027 Post(s)
Liked: 527
GE HTR700O was made for this application.
Mike Miles
[email protected]
mmiles is offline
Reply Speakers
