LS50 vs Q150 audition - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 51Likes
post #31 of 87 Old 06-29-2018, 06:47 PM
KenM10759's Avatar
Quoted: 3289 Post(s)
Liked: 1798
My LS50 desktop speakers are pointed almost straight ahead, and that's after much experimenting with different toe-in angles. It such a slight angle it's undetectable to most anyone but an engineer.
KEF R500, R200C, R100, R50, SVS SB2000 sub, NAD T758v3 AVR, Pro-Ject RPM1 TT w/ Ortofon 2M Red, Bluesound Vault2, LG UP875 4K BlueRay, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer. Desktop: NAD M10, KEF LS50, KEF Kube 10b. Guest room: Hafler 200 L-R, KEF reference Model 100 center, KEF iQ10 surrounds, M&K V-90 sub.
KenM10759 is offline
post #32 of 87 Old 07-04-2018, 05:00 PM - Thread Starter
aarons915's Avatar
Quoted: 630 Post(s)
Liked: 560
Alrighty I changed the thread title since the Q100 are now in the mix, no real surprises with them, like many have said they are a bit on the bright side and I agree, the measurements also show the same. The easiest way to describe the differences would be that the Q100 emphasize the highs and are definitely the brightest of the 3. The Q150 and LS50 sound very similar with the LS50 having more detail from about 2-5K but the Q150 have a very similar midrange sound compared to the LS50. The Q100 also have the least bass response in my room, probably because of the front port. The Q150 and LS50 driver also look identical, I'm just speculating but I would bet that they are pretty much the same driver, the crossover is probably the main difference.
So in conclusion, I'd say the Q100 are good speakers, I'd mainly use them for surrounds since vocals sound a little unnatural due to the brightness. The Q150 sound more neutral and are very smooth through the midrange, they also have the best bass response of all 3 speakers. The LS50 are definitely the best of the bunch, slightly smoother than the Q150 through the midrange, just the right amount of detail over the Q150 and a much better cabinet and build quality over the other 2.
Just some notes on the measurements, these are all taken with a 100Hz 2nd order high pass so the bass is a bit rolled off but the relative differences won't change. I measured each speaker (left and right separately) in 3 different positions around my main listening position so each graph is the average of 6 measurements.
ID:	2424504   Click image for larger version
ID:	2424506   Click image for larger version
gajCA and noobtv like this.
aarons915 is online now
post #33 of 87 Old 07-04-2018, 05:12 PM
Quoted: 75 Post(s)
Liked: 7
Why don't you get R300 ? It will be replaced and it's on sale, I think you can get around $1000 USD if you negotiate with the sales person.
They told me R300 uses the same tweeter/mid as blade speakers, LS50 tweeter/mids are lower grade, but LS50s have the better cabinets according to salesperson.
So I guess in the end because LS50s have the better cabinets it closes the gap, you really have to listen and pick what you like.
KEF R900 (coming), Martin Logan Motion 40, 50XT, 15s, LX16. Dual SVS SB13. Dual PSA 3611s (coming)
Marantz SR5009, Yamaha A-S2100, MX-A5000, OPPO HA-1, Burson HD-160
Headphone : HD800 / Fostex TH900 mk1 / TH610 / Beyerdynamic T5p.2 / HE6 / LCD 2.2 / Denon AH-D7100/AH-D600
canadian411 is offline
post #34 of 87 Old 07-04-2018, 05:25 PM - Thread Starter
aarons915's Avatar
Quoted: 630 Post(s)
Liked: 560
In that case why not just get the Blades or the Reference lol? It's just money right? Actually, the R300 are very intriguing to me but I really don't like the finishes on the R series for one, also I like 3 identical front speakers so I would more than likely grab 3 R200c if I went with the R series.
post #35 of 87 Old 07-04-2018, 05:30 PM
KenM10759's Avatar
Liked: 1798
Who is the "they" who told you the LS50 uses a lower grade Uni-Q driver? It was Johan Coorg of KEF who had said the LS50 and R500 have the same Uni-Q driver, though crossovers are different because the R500 is a 3-way with twin LF drivers. I would be assuming, but the Uni-Q driver of the R300 should also be the same one used in the LS50. I'm fairly certain the Blade and Blade 2 get MUCH higher quality Uni-Q drivers. They don't even look the same as R series.
post #36 of 87 Old 07-04-2018, 05:40 PM - Thread Starter
aarons915's Avatar
Quoted: 630 Post(s)
Liked: 560
Hey Ken, not to derail my own thread lol, but I see you have R500 as well, how do you compare them with the LS50 for music in stereo? Do you think a 3 way gives up some of the magic of having all of the sound coming from a single point source or do you not notice a difference in that area?
post #37 of 87 Old 07-05-2018, 03:24 AM
KenM10759's Avatar
Liked: 1798
Here's the deal: I listen to the LS50's as near-field monitors, desktop. In this situation they're at their best, IMO. Soundstage is far more compact of course, though the definition seems better.
My R500's are in my living room as part of a 5.1 (soon 5.1.2) system. Being closer to each other and the R200c than they really should be, it's a very smooth front end for movies. When I listen to 2.1 music from the same listening position, it's just not as good as my desktop system.
When I take the time to move to a spot 5 or 6 feet from them, and centered, that's a game changer. In that situation, the R500 can be used as 2.0 for best effect, and then they absolutely smash the LS50's. Suddenly the soundstage is shifted to have extreme depth and breadth. It extends from being well behind to out in front of the actual speakers and though centered, also seemingly out far beyond their boundaries left and right.
Sitting in the right place and with the R500's face at 29" (0.8m) from the rear wall, these speakers can give quite a chill. This is really how they should be used, it's just not practical for me. There is absolutely no penalty in them being a 3-way, and in this listening position they're definitely better than the LS50's to my ears.
aarons915 and Lp85253 like this.
post #38 of 87 Old 07-06-2018, 04:38 AM
Quoted: 75 Post(s)
Liked: 7
Is that right ? so I am not informed properly, "they" as saleperson. He said KEF Blade 2 UniQ Driver is the exact same driver as R300. That's why I was leaning towards R300 than LS50s.
I never heard R300 but based on KEF Blade 2 listening I was sold on R300 mids/trebles. If LS50 has better mids/trebles than R300 then I have to look something other than KEFs as I was not impressed with LS50s.
post #39 of 87 Old 07-06-2018, 06:04 AM
KenM10759's Avatar
Liked: 1798
The Uni-Q driver in the Reference series and Blade/Blade 2 are the same.
In the current R series, I do think the mids and treble is a bit more laid-back than the LS50. The most direct comparison to me would be the LS50 to R100, as both are a single driver and it's the same one in both. The main differences then become the cabinet and the crossover. Look at the differences in the two plots and perhaps you can see how the LS50's deeper cabinet, improved port configuration, but primarily curved front baffle improves off-axis performance of the tweeter and affords deeper bass. The LS50 is a speaker which many people prefer to listen to slightly off-axis, and I am one. On axis, it can be a little "too truthful" for some ears.
Using the same Uni-Q driver in the R300 means it would be crossed over to the woofer sooner. The larger cabinet with the Uni-Q driver higher should mean a little more laid-back performance of the tweeter, and more pronounced mid-range into mid-bass from the large woofer. This is similar to what I find with my R500 speakers. I can be directly on-axis and not feel the same about them as the LS50. I think you'd really like the R300 for this reason.
ID:	2425028   Click image for larger version
audiofreak38 likes this.
post #40 of 87 Old 07-06-2018, 06:52 AM - Thread Starter
aarons915's Avatar
Quoted: 630 Post(s)
Liked: 560
Yes that makes sense, the Blade/R300 midrange unit doesn't need to be as stiff since it's not producing any deep bass which probably aids in it's midrange performance. I was surprised you prefer the R500 so easily over the LS50 since the highs are so different, the 2-5k region is slightly elevated in the LS50 and slightly recessed in the R500 so they will be a bit laid back in comparison. I am definitely one that gets fatigued by bright speakers but the LS50 seem to have an almost perfect amount of highs without being fatiguing to my ears.
post #41 of 87 Old 07-06-2018, 08:09 AM
Quoted: 1940 Post(s)
Liked: 1649
i would like to interject :always take sales rap from a sales rep with a BIG grain of salt.. you are likely to be more informed if you spend any time researching the product on AVS..... best of luck...
Zorba922 likes this.
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #42 of 87 Old 07-06-2018, 08:46 AM
Quoted: 75 Post(s)
Liked: 7
LOL SalesRap, ! indeed !
Lp85253 likes this.
post #43 of 87 Old 07-06-2018, 10:55 AM
Quoted: 874 Post(s)
Liked: 264
I was not impressed with ls50 eaither when compared with R300. But when a sub was added, ls50 beat R300 with or without sub handidly. It is in a different class but itself, more like reference speaker except with less bass that can be provided by a sub.
But if after adding a sub, you still don't like ls50, then definitely move on.
Sent from my SAMSUNG-SM-G930A using Tapatalk
SouthernCA is online now
post #44 of 87 Old 07-06-2018, 10:57 AM
Quoted: 874 Post(s)
Liked: 264
I talked with head of r&d at Kef. Ls50, r300 and blade all speakers are different. Ls50 is similar to blade but not the same. So don't listen to sales rep.
KenM10759 and Lp85253 like this.
post #45 of 87 Old 07-06-2018, 04:03 PM - Thread Starter
aarons915's Avatar
Quoted: 630 Post(s)
Liked: 560
This is why I always try to negate the bass advantages between speakers that I'm auditioning by using a crossover without the subs on, most people end up preferring a speaker that sounds more "full" or has more bass in other words. Also, with the Kef 2 ways, it's very important to keep the cone excursion down since it's acting as a waveguide for the tweeter and is very susceptible to intermodulation distortion. I find 100Hz to be perfect in my smallish room, in cases like Ken's nearfield setup I'm sure 80Hz would be fine.
audiofreak38 and gajCA like this.
post #46 of 87 Old 07-07-2018, 11:59 AM
Hifisound's Avatar
Quoted: 122 Post(s)
Liked: 32
Looks like LS50 and Q150 use the famous BBC Dip whereas Q100s doesn't and are much flatter!
Hifisound is offline
post #47 of 87 Old 07-07-2018, 01:14 PM
Zorba922's Avatar
Quoted: 6936 Post(s)
Liked: 5224
Heh, that would explain why I preferred the LS50 over the Q100. (Haven't heard the Q150.)
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #48 of 87 Old 07-07-2018, 01:24 PM
Quoted: 874 Post(s)
Liked: 264
Great. That should work, just watch out for cross over freq. slope. Because with that R300 or ls50 may still get frequencies below cross over point Did you say that you liked R300 in this set up?
post #49 of 87 Old 07-07-2018, 03:12 PM - Thread Starter
aarons915's Avatar
Quoted: 630 Post(s)
Liked: 560
That's just going off of a steady state in room curve, which should only be used to make conclusions relative to each other. If you check the Anechoic response of the LS50, there is no BBC dip. In actual listening sessions I think most people would say the LS50 is best followed by Q150 then Q100 as it really should be.
post #50 of 87 Old 07-07-2018, 04:10 PM - Thread Starter
aarons915's Avatar
Quoted: 630 Post(s)
Liked: 560
Yup I can do 2nd or 4th order slopes but I use a 2nd order high pass at 100Hz. I have the LS50, I haven't heard the R300, only the R500 but with dual subs I'm not giving up any bass over one of the bigger models.
post #51 of 87 Old 07-08-2018, 07:11 AM
Quoted: 874 Post(s)
Liked: 264
Deleted.
post #52 of 87 Old 07-08-2018, 07:14 AM
Quoted: 874 Post(s)
Liked: 264
Here is another thought that I shared with canadian411:
You may feel differently if a sub is included. I did.
Even though I felt ls50 had enough bass for me, it did not impress me when compared with several other speakers. But once a sub is engaged with all tested speakers, LS50 just jumped out as the best speaker. Cleaner, most natural with incredible transparency. So may be audition it again, but this time with a sub (unless you do not want to use a sub at home)
I think absence of bass did play a trick on my sound quality percention. I am not sure but the reason could be that our brains want to see balanced out put. Spekers that are lacking in deep bass will start to sound too bright but will sound natural when sufficient deep bass is present . So without sufficient bass, we tend to prefer speakers with limited treble extension. Just a guess...
noobtv and Lp85253 like this.
post #53 of 87 Old 07-08-2018, 08:32 AM
Zorba922's Avatar
Liked: 5224
Agree completely.
Speakers with little bass to my ears tend to sound "thin" rather than "bright" but with a sub, they immediately spring to life. Ascend 170, RBH R5Bi and Sony Core bookshelves all come to mind.
Zorba922 is offline
post #54 of 87 Old 07-08-2018, 09:08 AM - Thread Starter
aarons915's Avatar
Quoted: 630 Post(s)
Liked: 560
Absence of bass definitely plays a role in speaker preference, which is why I like to negate any advantages between the two. Harmans formula for speaker preference has the bass performance at about 33% of the overall preference, which is huge.
audiofreak38 and Zorba922 like this.
post #55 of 87 Old 07-08-2018, 09:30 AM
Nick V's Avatar
Quoted: 310 Post(s)
Liked: 303
I saw a video where KEF's Jack Oclee-Brown talks about the different drivers and variations of the drivers.
LS50 is trickled down from Blade (also the cabinet as well) and is a better driver than R series. Blade > Reference > LS50 > R Series > Q Series
Main System: Vizio P70 4K TV. Selah Vigore Speakers. KEF Q100 Rear L/R, Mirage BPS 400 LFE Sub. (2x)Rythmik FM8 Subs. Denon AVR-X4500H Receiver. Lyngdorf TDAI-3400 Integrated (2 channel). Oppo BDP-103. Zappiti Mini 4K HDR. GIK 242 Panels, Tri Traps, Monster Bass Trap. Various Vicoustic Desktop: Dynaudio BM6A mkII. Paradigm SUB10 w/ PBK. Cambridge DACMagic+ DAC. GIK 242 Panels, Monster Bass Trap Master Bedroom: Vizio M55 4K HDR. BG Radia In-Wall/Ceiling Speakers (5.2.2). NAD T758v3 Receiver
Nick V is offline
post #56 of 87 Old 07-08-2018, 01:01 PM
Quoted: 874 Post(s)
Liked: 264
I see what you are saying and it makes sense.
What I was pointing out was that you may make a different selection for a speaker when you test them with a sub compared to without a sub.
But test for yourself by auditioning the same two speakers with a sub and see if you prefer a different speaker.
Do let us know if what you find.
post #57 of 87 Old 07-08-2018, 02:27 PM - Thread Starter
aarons915's Avatar
Quoted: 630 Post(s)
Liked: 560
I know what you meant and I've done that. With the three Kefs I used the sub with them because their bass performance was similar enough that all blended with the subs just fine but in cases where the bass is a lot different I use a crossover without the subs on to try and reduce any bass advantage since that will sway my opinion. Some people don't agree with listening that way but I've got my subs flat to +/- about 1.5 decibels from 20-100Hz so I'm really not worried about bass performance of any speakers I audition.
post #58 of 87 Old 07-08-2018, 11:34 PM
Quoted: 874 Post(s)
Liked: 264
How did you rate the performance of three KEFs when you tested them with a sub. What you liked in which speaker?
post #59 of 87 Old 07-09-2018, 03:47 AM
Quoted: 75 Post(s)
Liked: 7
Do you have the link ?
post #60 of 87 Old 07-09-2018, 06:26 AM - Thread Starter
aarons915's Avatar
Quoted: 630 Post(s)
Liked: 560
Sorry I should have been more clear in my post, since they were all similar in bass I did use a sub with them crossed over at 100Hz, so the main differences I was comparing with my post above is 100Hz and up performance of each model. I measured them without the sub just to show relative differences in the bass but I did use a sub when listening.
Reply Speakers
